Projects Morris Minor Altered
Discussion in 'Traditional Hot Rods' started by RigorMorris, Apr 4, 2017.
  1. In a perfect world your front track width will be wider than the rear. Especially on a quarter mile basher where you want it to go straight. The wider front track width helps it track straight and true.
    Take a look at an FED that is properly the front axle is always wide.
    loudbang and RigorMorris like this.
  2. RigorMorris
    RigorMorris
  3. southcross2631
    southcross2631
    A stock width 50' s Chevy axle will put your wheels outside of the body where you want them . You will have to push your frame rails out to get your spring perches wide enough to match the Chevy axle.
    I drilled my Ford axle with a hole saw not too bad too do.
    With as wide as you want to go a speedway axle or Model A axle might look better. Not look as heavy on such a small car.
    Buggy spring crossmember would be easier for what you are trying to do.
    RigorMorris and loudbang like this.
  4. RigorMorris
    RigorMorris
    Had some time today to work on repairing the rotted out rockers.. also started cutting out rusted through portions to patch..
    This is after cutting rotted portion of rocker out.. I used 3x2 1/8" wall square tubing to Fab new rockers, I need to go back to Metal Supply Shop and get some 3/16" plate to box in bottom half of rocker
    Here you can see where I still need to box in bottom half of the rocker
    catdad49, loudbang and mgtstumpy like this.
  5. RigorMorris
    RigorMorris
    Installed front frame rail attachment. I need to decide how wide front frame rails will be and remove that section for the front cross member, 'this is the body / frame attachment points.. I'm not doing a kick up or Z'd frame, just straight frame kinda like a Model A but wider and stronger.. I was thinking 29"-31" wide inside frame rails.. I'm hoping SouthCross will chime in on how wide his frame is.. I'm building this as a unibody, frame is part of the body.. thanks any thought will be appreciated.
    catdad49 and loudbang like this.
  6. RigorMorris
    RigorMorris
    Been hammering on fenders and hood, getting them straightened out think I can save them.. should have rear end and ladder bar member in tomorrow.. pictures to follow..
    Peanut 1959 and catdad49 like this.
  7. southcross2631
    southcross2631
    Mine 28 1/2 from front to back measured from the inside of the rails. You boxed the rockers just like I do on my Morris Minor builds.
    I always use a kick up in front and back . These cars are squirrley enough without raising them up.
    My rocker height is 11in. in front and 10 in. out back to comply with the Southeast G***er rules. If I could it would be about 6 and 7. Good job so far.
    Remember an Anglia roll cage kit fits really well if you don't want to bend one up yourself.
    My last Morris was a street car with Mustang 2 front suspension and Fatman makes a crossmember
    RigorMorris, neilswheels and loudbang like this.
  8. RigorMorris
    RigorMorris
  9. RigorMorris
    RigorMorris
    Thanks SouthCross I really appreciate the info.. I'm going to stretch this wheelbase as much as possible..
  10. RigorMorris
    RigorMorris
    Thank you Never2Low.. these pictures help out a lot!
  11. southcross2631
    southcross2631
    You may regret it if the center of the ****** cross member is not removable. Unless the floors will come out and you can take the trans out through the door. I always try and build my cars knowing that they are going to have to come back apart at some time. Would hate to have to pull the motor to get the trans out.
    I drive em hard and break em and put them back together. My last Morris every bolt could be taken out and put back without even using a swivel.
    Peanut 1959, AHotRod and loudbang like this.
  12. RigorMorris
    RigorMorris
    Yes I'm making removable floors where I can pull ****** from the top.. it's not going to have interior just sheet metal panels that can easily be taken off to work on any part of the vehicle..
  13. RigorMorris
    RigorMorris
    Also the ladder bars mount to that same cross member.. they are 36" ladder bars
  14. southcross2631
    southcross2631
    My old school ladder bars will be 47 inches long . The mount will be part of my trans cross member ,but the center will be removable . It will be diagonally braced so I can remove the center and not loose strength. Bolting the transmission cross member will make it solid.
  15. RigorMorris
    RigorMorris
    Good idea! I think I'll do the same [emoji1303]
  16. RigorMorris
    RigorMorris
    Will buggy spring setup handle big block
  17. southcross2631
    southcross2631
    Look at some of the G***ers that are running a buggy spring under their stuff with big blocks.
    You are extending your frame and setting the motor back which will move some weight to the rear.
    Should be no problem.
    RigorMorris likes this.
  18. RigorMorris
    RigorMorris
    Thanks again SouthCross [emoji41]..
  19. RigorMorris
    RigorMorris
    I found out why my pinion angle was -10* at mock up... haha [emoji23]... well the guy before me had the ladder bars on upside down.. [emoji51]
  20. RigorMorris
    RigorMorris
    I think you can see how far down the pinion angle is pointing & ladder bars are pretty much parallel to ground, so flipped the ladder bars and we are at where we are supposed to be now.
    catdad49, fiat gasser and loudbang like this.
  21. southcross2631
    southcross2631
    What ever happened to your car? I have not seen a post since last May.
  22. RigorMorris
    RigorMorris
  23. RigorMorris
    RigorMorris
    Still working on it between other projects.. I’ve been working on the business coupe chop.. I took 10” out of rear side gl***..
    Peanut 1959 and loudbang like this.
  24. RigorMorris
    RigorMorris
  25. RigorMorris
    RigorMorris
    I have a Small Block Chevy 355cid that I’ve been building also, may go with the SBC instead of the BBC
    loudbang and AHotRod like this.
  26. southcross2631
    southcross2631
    OOh ! Chopped top. Very cool.
  27. RigorMorris
    RigorMorris
    SBC is all Eagle Rotating ***y, Forged Ultra Light Crank & Rods.. Sealed Power Speed Pro hypereutectic pistons..
  28. AHotRod
    AHotRod
    How fast do you want to go?
  29. Modded 105E
    Modded 105E
    Love it.
    I am in the Morris Minor owners club here in the uk.
    Happy to point you in the direction of Morris Minor parts if you need any.
  30. RigorMorris
    RigorMorris
    Thank You I will definitely take you up on the offer
