Projects 1932 Roadster Project
Discussion in 'Traditional Hot Rods' started by AULIZ, Jan 4, 2018.
  1. AULIZ
    AULIZ
    Hello
    Understand what you mean.
    I have had this hand brake system two of my hot rods. Good springs inside of backing plates (cable springs), right adjusted shoes and this brake is working fine. Im not make any "handbrake U-turns" with my hot rod. Only use handbrake when parking and God Bless, we do not have here same kind of hills and mountings like for example in SF, Norway, Austria,....
    Aulis
    catdad49 likes this.
  2. Bandit Billy
    Bandit Billy
    I'm going out on a limb here but maybe the train toilet doesn't pull as tight as you like @alchemy . :cool:
  3. deuceman32
    deuceman32
    The 2 bolt master used in the Lacys' kit is from 1962-66 full size Chev p***enger, 63-66 ChevyII and Chevelle and a handful of Buick/Olds/Pontiacs from the same year range. It was produced in both 7/8" and 1" bore sizes depending on whether or not the car had metallic shoes and/or power ***ist. For example, the Dorman numbers are M40000 for the 1" bore and M36242 for the 7/8" bore.
    Hamtown Al and loudbang like this.
  4. banjorear
    banjorear
    Thank you!
  5. AULIZ
    AULIZ
    IMG_4965d.jpg Fuel lines made. Few pics included.
    I increase here this Mcculloch supercharger oil pressure question picture. I have try to find out where oil pressure must install and what is byp***, but not good result. All pictures I have found from internet are not took so that I can see how tubes are going there. Two will tell all that, but those are so small that cant make those bigger....¨
    M-39, M-40 info is wellcome or if You have McCulloch in Your hot rod , please, take good picture and share it.
    Aulis
    IMG_4953b.jpg IMG_4954b.jpg IMG_4955b.jpg IMG_4958b.jpg IMG_4959b.jpg IMG_4960b.jpg
    Stogy, Hamtown Al, catdad49 and 2 others like this.
  6. AULIZ
    AULIZ
    Yesterday supercharger oil problem solved and tubes made.
  7. AULIZ
    AULIZ
    Spark plug wiring ready. 1/2" OD brown vintage wire.
    Stogy, catdad49, Gotgas and 5 others like this.
  8. AULIZ
    AULIZ
    off topic, but my own thread, so doesn´t matter:
    Italmeccanica engine is rebuilt and this week I can continue working with roadster Project.
    Powerful engine, but I had problems with head studs. Never blow out head gaskets, but too many "soft" studs.
    I piece engine after used it all last summer. Now I have plugged total 30 thread/hole and made new holes middle of plugs + 7/16" threads. After that I plane decs straight and test moment all up to 90lbs.
  9. continentaljohn
    continentaljohn
    Awesome build thanks for sharing
  10. 1-SHOT
    1-SHOT
    from Denton
    Why did you not use King Serts they are larger than Helicoils and we use them in our midget motor and have not had any problem with them. They are basically the same as you did, but you don't have to drill and tap them once installed.
  11. DDDenny
  12. 1-SHOT
    1-SHOT
    from Denton
    Sorry about my spelling auto correct got me. At least you found them, French Grimes put me on them at the Chili Bowl.
    French Grimes is known for starting Race Saver the 305 sprint car series , also his ignition work and fuel injection work is well known in sprint and NASCAR . Super smart man. Did a lot of work with Brodix also.
  13. AULIZ
    AULIZ
    Sorry, I didn´t know about those King serts. Maybe somebody import those to Finland, but I didnt knew those products. So,...I decided to make those 3/4" UNC thread plugs (cut bolts and glue using Loc***e 270), new hole middle of plug and new 7/16UNC thread. Works, but takes time to make all.
    Aulis
    Joseph C. Sievers and catdad49 like this.
  14. AULIZ
    AULIZ
    "professional" (poor!) painting room is slowly grow up to my property. I still have one old 3meter x 6meter pit tent left. Not so good condition, but ok for me. Tarpaulin walls and it´s ready. I paint all primer, epoxy and filler in tent and only final 2K paint in my friends paintshop.
    Save time and money,....this is hot rodding.
  15. 1-SHOT
    1-SHOT
    from Denton
    I really like your build on your roadster.
  16. AULIZ
    AULIZ
    Thank You.
    A
  17. brady1929
    brady1929
  18. AULIZ
    AULIZ
    Thanks, good info. I will use that steering box in my 5w coupe Project. I remove shaft from gear and cut it shorter from that end.
    I have in my grey coupe very long steering shaft/tube (F1). I have moved seat 3-4inc back. Not easy to go in and out, but very good to drive long trip....
    aulis
  19. catdad49
    catdad49
    Aulis, you build some great stuff! Thanks for sharing, Carp.
  20. AULIZ
    AULIZ
    1243b.jpg Thank You. Last days I have been lazy. Poorman´s paintingroom is ready another side of my yard.
    Cant begin to paint because nights and days are too cold. Normally this time year "thermic spring" is normal, but now we have extra much snow and cold...... Tent is warm very easily if outside is around zero decrees celcius, but if its minus 6dec like today (sunny but cold), there is not enough warm inside tent.
    Today empty frame and lifted up engine/****** to wait final installation.
    Tomorrow need to weld frame, make some holes and after that I all are ready for painting.
    Frame and body same colour, old style Basic acryl.
    Aulis
  21. avachace
    avachace
  22. AULIZ
    AULIZ
    Thank You. Pictures coming later today.
    A
  23. AULIZ
    AULIZ
    frame welding, new rivets,.... Front shock mounting sleeves are not welded in picture. Later welded those from inside.
    Aulis
    Stogy, AndersF and riccard81 like this.
  24. AULIZ
    AULIZ
    Today I painted industrial epoxy primer some frame parts.
    Tomorrow frame, fuel tank, maybe some body parts or brakes parts.
    Looks cold outside...hahaa!
    Aulis
    nb. Now days are going longer and longer. Every week daily bright time is continue 60minutes.....
    Aulis
    The 39 guy, Just Gary and Stogy like this.
  25. AULIZ
    AULIZ
    Frame and inspector.
    Today I bought 3litre paint (body and frame) and 1litre (axles, springs, pedals, wishbones..). Glasurit 2K acryl.
    a
    biggeorge, Hamtown Al and AndersF like this.
  26. The37Kid
    The37Kid
    What a great build, sorry it took so long for me to find it. I really like the paint booth.:) Bob
  27. AULIZ
    AULIZ
    two days business trip. Dayjob is delay my hobby....not good . no.
    Days are sunny and warm, but still too much snow. Normally this time year we do not have snow at all..... Pro paintingroom is very good. Chip Foose would be happy to have painting room like that when they built those "bling bling" cars.
    Today I painted epoxy primer and filler (wet + wet) some parts.
    Also washed body (surface cleaner). Tomorrow I paint body, fuel tank and doors.
    I bought from here HamB some velocity stacks (seller has ad. in "parts for sale").
    Good aluminum and low price. I fixed 1hour those and now looks good when sit on carbs.
    Aulis IMG_5010b.jpg IMG_5011.JPG IMG_5012b.jpg View attachment 3844675 IMG_5019h.jpg IMG_5021b.jpg IMG_5022b.jpg
  28. AULIZ
    AULIZ
    Doors, tank and body painted.
    2kg epoxy primer
    2kg filler
    Still need to paint rearaxle and driveshaft + brakes....
    Need to change ring and pinion before painting.
    Aulis
    The 39 guy, catdad49, Stogy and 6 others like this.
  29. outstanding work Auliz.. Loving this build.
  30. AULIZ
    AULIZ
    Thank You Sir. All would go better if we had here normal spring weather. This year we have snow very much (10-20") and very cold. Last years end of March snow has gone and days are warm.....
    Today I piece rear axle and change ring and pinion. Need to built some kind of stand where I can lift rear axle vertical. If weather is going better, I want to paint (Final 2K acryl) axles, frame, small stuff before Eastern or during Eastern.
    4litre (gal) paint + harder + thinner... has been bought last week. total approx 220euro (260usd).
