Technical ***March 2018 Banger Meet - Equinox Time***
Discussion in 'Traditional Hot Rods' started by Jiminy, Feb 28, 2018.
  1. Gearhead-DK
    Gearhead-DK
    4-banger music :)
    GASSERBOB and ROCKER77 like this.
  2. V4F
    V4F
    from middle ca.
    bummer on head gasket . how did you get the heat wrap looking so good ? when I try it looks like a 12 yr old did it
  3. V4F
    V4F
    from middle ca.
    now you guys in Denmark are havin to much fun ! like the music !
    Gearhead-DK likes this.
  4. Crazydaddyo
    Crazydaddyo
    John,
    Good eye on the pilot hole. I didn't think about that. I will have to check it out before final ***embly.
  5. Bluto
    Bluto
    AT LEAST IT'S AN EASY FIX. :eek:
  6. unless it is in the car............................
    Crazydaddyo likes this.
  7. green73
    green73
    I Start with a single wrap as tight as I can get it. I don't use the metal zip tie deals that the wrap kits come with I use Safety Wire and Safety Wire pliers (Aircraft Avionics guy by trade). After the first wrap I secure it with safety wire. keep wrapping as tight as I can get with 1/4-1/2 overlap. If it starts to loosen I loop safety wire around the loose spot and press on. Each tube is it's own run. Last wrap gets safety wire, then on to the collector. I have in the past done a continuous lacing of the safety wire from the header flange to collector in a criss-cross/ over/under pattern. that was on a SBC set of headers. I don't think I have any pics. It was a huge useless PITA, but looked spiffy.
    ROCKER77 likes this.
  8. Bluto
    Bluto
    JOHN
    ONE OF MY WIVES WAS LIKE THAT! I DID JUST TRADE HER IN IN-FAVOR OF THE CURRENT MODEL :cool:
    Old Dawg likes this.
  9. V4F
    V4F
    from middle ca.
    green73 , thank you . just patients . did you wet it first ? ............
  10. green73
    green73
    Nah. Never even thought of that.
  11. V4F
    V4F
    from middle ca.
    thanks ............. steve
  12. jim1932
    jim1932
    so what are the differences between an AA and a BB hogshead if trying to mount a modern trans to a B motor? Can I use a stock pan with the BB?
  13. Hard to tell from this pic but there are two authentic Ford Model B parts behind the mounting plate.
    Twisted out another driveshaft flange today, rev limiter and ****ter shield worked flawless.
    Only have to repair driveshaft.
  14. winduptoy
    winduptoy
    What's the NSF on the pan, you running this in the kitchen?
    Sent from my XT1254 using The H.A.M.B. mobile app
  15. That is a water tank on the floor for return.
    There is no oil pan on this motor, just dry sump scavenge.
    My wife doesn't let me do that anymore, no parts in dishwasher, no ceramic coatings in the oven.
    She's such a killjoy.......
    Outback and Old Dawg like this.
  16. winduptoy
    winduptoy
    OK, now I get it. Thank You
    Our wives must know one another... at least they know where we are;
    either in the shop or on HAMB
  17. Great site guys. Enjoying. Its good to see new stuff on the A's and ideas. Mine is a work in progress. Plan for mine is keep it simple.
    winduptoy likes this.
  18. Crazydaddyo
    Crazydaddyo
    John,
    I thought El Mirage was closed this week end? Did you bust it up in the car or on the dyno?
  19. Dan,
    I did it at home on the brake.
    Was pulling about 200ft# at about 4200 when it became exciting...........
    J
  20. Binger
    Binger
    from wyoming
  21. waxhead
    waxhead
    from West Oz
  22. V4F
    V4F
    from middle ca.
    this is me .... for the newbies . john do not look .......... steve Wife a ford.jpg
    GASSERBOB, Outback, waxhead and 2 others like this.
  23. Steve,
    I hope to hell you are not telling me not to look.
    I dig the **** out of your car, in fact, I am jealous.
    You get to drive it every day. That motor has some very sound engineering and build quality, everyone here would be proud to own. Trust me, my T is in so many pcs that I think the license plates have rusted away..........
    Enjoy the hobby and have some fun, John
    PS, does she have a sister??
  24. V4F
    V4F
    from middle ca.
    LOL john you have so much more than I do . I have worked hard on it . thank you much . means a lot ....... steve
    may have a sister but a wayward sister that never talks to us . as many motors as stan has put out I'm sure there must be at least 1 !!!
  25. RussTee
    RussTee
    Hot English bangers have been shifting our heap of ford y and 8 and 10hp parts and have decided there are enough parts to build a traditional style 50s special along the lines of a trials special. The Poms built a great many of these including many factory specials the likes of Mistrals Dallows Bucklers Cheetahs and maybe a dozen more as well as many homebuilt specials it looks like a lot of fun and cheap as it will be built for off road use either track or hillclimb so wont have to be certified something that is becoming very expensive and limiting here though I will admit needed for road vehicals.
    I have a ford 100e motor Ford y and Prefect running gear A set of y wheels and prefect wide five wheels and drums.
    It is possible to split the front beam axel and make it independent as it is with the rear both these mods were common in the fifties and many firms produced kits for this.
    To make it interesting I have a Wilmont overhead conversion for the 100e motor and many Buckler and Mistral parts including gearboxes ch***is twincarb manifolds ect . Comments welcome
    Outback likes this.
  26. V4F
    V4F
    from middle ca.
    any pix of what you are building (old original cars) . I'm not familiar with what you are after .
  27. Bluto
    Bluto
    RUSS
    I'VE RESTORED SEVERAL LOTUS 9'S AND 11'S BE CAREFUL WITH THE COIL OVER SHOCKS. CHATMAN'S MISTAKE WAS USING EYE TO EYE SHOCKS THAT BOUND BECAUSE THE MOUNTS WERE NOT IN THE SAME PLANE AND RUBBER BUSHED. AS THE GO INTO BUMP TRAVEL THE SHOCKS WOULD TWIST AND BIND LIMITING TRAVEL. A FEW INCHES. I ENDED UP USING UNI-BALLS INSTEAD OR RUBBER THIS WOULD ALLOW THE SHOCKS TO TWIST BUT CONTINUE TO TRAVEL. I USED KONI LOTUS EUROPA OR ELITE REARS IN THE REAR AND LOTUS 7 FRONTS IN THE FRONT. THESE WERE COIL OVER TO START WITH AND LOOKED CORRECT. ... TO CHECK FOR BIND YOU MOVE THE SHOCK UP FROM STATIC. IT'S ALL PRETTY SIMPLE TO MEASURE AND GET THE MOST TRAVEL. ONCE ESTABLISHED IT'S JUST A JOB OF MAKING A COLLAR TO RETAIN THE SPRING ..NO REAL NEED FOR CRANK-UP/DOWN EXPENSIVE TYPE SHOCKS.
    I THINK I STILL HAVE AN 11 LM CORNER AROUND HERE SOMEWHERE.
    THEY ALL HANDLE LIKE A 3-LEGGED CHICKEN BUT SCOOT AROUND PRETTY GOOD AS LONG AS YOU KEEP THE TIRES NARROW.
    HAVE FUN.
  28. RussTee
    RussTee
    Thanks Jim thats the advise I need going to go as much as possible the historic way(there are even rules for that) but should be a lot of fun they do limit the tires to 6 inches wide haha maybe as much fun as an old ****** can handle on a steep hill in the rough. I think a hot 100e has a bit of grunt too.
  29. RussTee
    RussTee
    V4F do a search for mk5 buckler cars this is sort of what I am looking at also remember the Lotus 7 grew out of this sort of car great fun for low cost especially when you got the parts laying about I had overlooked this stuff but do remember the fun we had in the sixties racing these things they are a good learning curve and can move surprisingly fast the current trials specials sort of grew out of them they have their own website under sporting trials specials great fun for young and old HAHA
    Old Dawg and Outback like this.
  30. V4F
    V4F
    from middle ca.
    russtee like this ? cool car
