1954 Mercury Monterey 2 Door Hard Top PROJECT Car The Car has been Dis-***embled, Frame was Sanded and Painted, Body is Very Very Straight, Most of the Rust Out has been Fixed, The Underside of the Body and Most of the Interior Floor Sheet Metal of the Car has been Sanded and Painted with POR-15 and then Sprayed with Lizard Skin Coating, which is a Bed Liner type of Material that Protects the Metal from Rust and Corrosion. The Inside of the Car has been coated with POR-15 as well, so this thing should Never Rust Again. Body is Currently in Mostly Bare Metal, except for the top has never been stripped. Interior is Original, Dirty but Not Trashed, Very Usable, No Carpet Included. More than 1 Set of Side Gl*** and Stainless Side Window Frames. Extra Stainless Steel Side Trim Parts Lots of Extra Parts, Everything that was Removed is Included Car Does Not Run, Start or Stop, You will Need a Trailer and a Pickup or Van for all of the parts Car is Currently apart and about ready to start going back together, All of the Hard Work Is Done. Car Includes: 1968 Ford 302, Rebuilt, Never Fired Ford C-4 Transmission Lincoln Versailles Front Disk Brakes Lincoln Versailles Lowered Spindles Ford Aerostar Front Springs, 1 Coil Cut 3" Rear Lowering Blocks New Ron Francis Wiring Kit Fender Skirts 14" 3 Bar Vintage Flipper Hub Caps Custom Hood with Ornament Removed and Scoop Cut Open Clear ***le In Hand Price is: $5,000.00 For Everything Listed $4,500.00 For Car WITHOUT Custom Hood, Vintage 14" 3 Bar Flipper Hub Caps & Fender Skirts No Tire Kickers, Don't Waste My Time Or Yours If You Are Not Seriously Interested! I Am Not Interested In Trades Of Any Kind, Cold Hard Cash Only! Call 425 - 3 Four 6 - Seven One Three 7 From 6:00 am - 7:00 pm Only Pacific Standard Time 7 Days A Week
