Hot Rods Let's see your 2 Barrel Air Cleaners
Discussion in 'The Hokey Ass Message Board' started by Fitnessguy, Mar 13, 2018.
  1. Fitnessguy
    Fitnessguy
    Been doing some looking online at pics of different 2 barrel air cleaners so thought i would throw this thread up and see what everyone's got on here. Looking for something a little more unique for my 3 deuce set up that i am putting on my 409. I like the frog mouth and the nicson spark arresters but thought i would see what else there is before i decide what i want to go with. so let's see em!!
    nochop and loudbang like this.
  2. hrm2k
    hrm2k
    I got a set of some spun aluminum covers for my strombergs. The ones off Speedway seem to really strangle the incoming air unless they have louvers
  3. 47ragtop
    47ragtop
    You said show me your 2 barrel air cleaners . Might take a little adapting for 3 deuces. :):)
  4. Fitnessguy
    Fitnessguy
    What brand are those?
  5. Fitnessguy
    Fitnessguy
    Ya I guess I should have clarified a little further! Ha ha single air cleaners for the three deuce set up!
    loudbang, Clay Belt and 47ragtop like this.
  6. Bandit Billy
    Bandit Billy
    How bout some clam shells?
  7. Toner283
    Toner283
    Badger Chrome scoops on rochester 2GCs on my 283.
    Stogy, mcnally351, loudbang and 4 others like this.
  8. Steves46
    Steves46
    from Florida
    Here's mine from Orbrien Truckers.
  9. hrm2k
    hrm2k
    A friend of mine got them for me. I believe the name starts with an M................I'll get that information for you. They were pretty expensive................if I remember right, they were a little over $50 each
  10. jnaki
    jnaki
    upload_2018-3-14_4-29-22.png upload_2018-3-14_4-29-38.png stock
    upload_2018-3-14_4-29-53.png for mountain driving at high elevations and the drags at sea level
    Hello,
    On our old 1958 Chevy Impala, we ran several different set ups for the 348/280 hp motor. The stock set up was the big black, circular, air cleaner that covered all three 2 barrel carbs. It was the best for daily driving and also for long distance driving. The inner air filter kept everything out of the carbs, but still allowed it to breathe with the two big front inlets.
    We also used the chrome caps for each carb with wing nuts. This made the carbs whistle at the drags, but seemed to allow more air into the 3x2 set up. Most stock cl*** racers took that giant black air cleaner off and put these little chrome caps on their set ups. We also saw these chrome caps on gas coupes and roadsters.
    One other use for the chrome caps was up in the 8000 ft local, So Cal mountains. It allowed more light air to get in the carbs, even after adjustments were made for smoother running at higher elevations. The newbies up there just did not know why their sea level cars did not run right. Easy pickings for top eliminator.
    Filters? None, unless you used the original stock air cleaner. But there were all sorts of stuff in the air on the drag strip. Plus at Lions, every day around 1-2 pm, the West winds from the ocean started blowing across the surface of the strip. It did not help when the winds shifted and picked up dirt from the adjoining farmer’s plowed or unplowed fields.
    Jnaki
    When we had some extra money, we had the top plate of the huge stock air cleaner chromed, got some chrome valve covers and put on a couple of Moon Breathers. That spiffed up the engine compartment for a while.
    Don’t discount out that huge air cleaner. There was a 32 roadster that had a big 348 in it and ran the stock, black air cleaner for all three carbs. It looked neat and on those cruises, did the job. It fit under the top hood with the sides open and no one could see the big air cleaner until the top was taken off. (or you peeked under) Most roadsters will have some sort of chrome individual air cleaner for the carbs. This one 32 did his own thing.
  11. Stogy
    Stogy
    Fitness you can edit your thread ***le...perhaps to...
    LET'S SEE YOUR 3 x 2 BARREL AIR CLEANERS
    hrm2k likes this.
  12. Fitnessguy
    Fitnessguy
    Ya I’ve always liked those, I forgot they made them smaller like that, I always think of the ones for the 4 barrel
  13. Fitnessguy
    Fitnessguy
    Sweet history as always Jnaki! You had me dreaming of lions and forgetting about the topic! Ha ha i have actually thought about the big original style cleaner as well. So many choices! Thanks for the story!
    jnaki likes this.
  14. I love those tops, I am using one of those with a different base on a 4 bbl on my current project.
    You could make an 8 out of two of those and a multi carb base for trips or 2 fours.
  15. egads
    egads
    O'brien Truckers 15"on 2 holley two's. They make a longer one ,18"for three two's 044.jpg
    joel, '51 Norm, rustymetal and 5 others like this.
  16. crminal
    crminal
    ^^^Nice Y^^^
    stik70, lothiandon1940 and egads like this.
  17. wackdaddy
    wackdaddy
    Obrien Truckers 4 1/2" od tall IMG_8905.JPG
    Shadow Creek likes this.
  18. blowby
    blowby
    from Nicasio Ca
    Here's a few I've made/used. Old Triumph motorcycle air cleaners
    Made these out of Harley horn covers
    Speedway frog's mouth one way
    and the other
    wraymen, funk 49, dana barlow and 4 others like this.
  19. alchemy
    alchemy
  20. FrankenRodz
    FrankenRodz
    Frankie47, nochop and loudbang like this.
  21. KoolKat-57
    KoolKat-57
    from Dublin, OH
    latest shots 022.JPG These were the only ones for A tri-power that I could find at the time that sat lower on the carbs.
    I have never seen them since.
    KK
    loudbang and 270ci like this.
  22. Bandit Billy
    Bandit Billy
    Before my engine outgrew the physical constraints of my engine bay I had the idea of building a cowl plenum style air cleaner and use the cowl vent to ram air into it. I even thought it would be cool if the vent door was power activated and opened via a turbo 400 kick-down switch on the gas pedal so it would be wide open at WOT.
    I miss opioids.
    loudbang and Hollywood-East like this.
  23. brett4christ
    brett4christ
    Go to the HAMB Cl***ifieds and search for "Grace & Co." in the subject line. Chris ( @graceandco here) makes the best out there, in my opinion. Small batch/high quality operation. Comes in raw, chrome, and black powdercoat with stainless or br*** screen! Br*** tags also available.
    graceandcospeedshop.com
    (No, I'm not Chris, and I didn't sleep at a Holiday Inn last night!) ;)
  24. choppedtudor
    choppedtudor
  25. mit311
    mit311
    loudbang and Fitnessguy like this.
  26. 270ci
    270ci
    Home built to filter and sorta hide a couple Holley twos.
    loudbang, KoolKat-57 and egads like this.
  27. Fitnessguy
    Fitnessguy
    whoa those are funky looking in a cool way! always like the unique stuff!
    choppedtudor likes this.
  28. hrm2k
    hrm2k
    lothiandon1940 likes this.
  29. Fitnessguy
    Fitnessguy
  30. Fitnessguy
    Fitnessguy
    Tuesday bump, keep them air cleaner pics coming!!
