1952-59 Ford '56 Ford Gasser (hope you have your speakers on!)
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Mar 14, 2018.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. Fairlane 62
    Fairlane 62
    Sounds and looks real good. Can i ask what you did for rear springs? I am building a 54 g***er which is the same frame and i'm at the point of installing the 57 9" rear, but the rear spring shackles attach to a "J" shaped bracket rather than directly to the frame like later cars do and I'm not sure if those brackets will hold up. But removing them will make the car sit lower and my wheel wells are already radiused.
    Thanks, James
