Project 29 Tudor in Mass.
Discussion in 'Traditional Hot Rods' started by Mikel50, Apr 17, 2015.
  1. sloppy jalopies
    sloppy jalopies
    Good stuff... I like to use the model A body to bumper bracket braces... then drill out the rivets... each bracket makes 2 seat anchors...
    I also use them, welded to the front of the A's firewall it makes front body mounts like '33-'34 trucks. DSCN2701.JPG DSCN2702.JPG
  2. Mikel50
    Mikel50
    Got both of the rear seat (front mounts) fabricated this evening...chipping away.
  3. barrnone50
    barrnone50
    from texas
    Looks Great the seat and the floor look fantastic !! Are going to build a fire wall between gas tank and seat?
    Keep up the good work..
    George
  4. Mikel50
    Mikel50
    Yes Sir,
    Thank you for the good words !
    That’s one of my my next steps after the tank is installed and plumbing/filler mocked up . After the mounts are made and the seat is in its final location, I’ll know what I have for room.
    I plan to use the 1” box tube I used as body bracing and some 18/20 ga to build an accessible bulkhead for the tank.
  5. NashRodMan
    NashRodMan
    Looking sweet Mike! I think you found a new trade!! Master fabricator. You are giving me lots of ideas!! lol
    I didn't think you could fit a tank back there and still have a seat. Now I know.
    loudbang and Mikel50 like this.
  6. Mikel50
    Mikel50
    Thanks Paul,
    there’s always a way ! master certainly not ...Just trying to keep things moving !
  7. sloppy jalopies
    sloppy jalopies
    Looking fine mike... about this point a buddy had to find a spot for his battery box... been 2 months so far... car runs with it strapped to the rear floor, but...
  8. Mikel50
    Mikel50
    Haha. I won’t be doing that ... getting closer to figuring that out though
  9. The rear seat does look good, on my '30 tudor I used a stock rear seat cut down (from front to back) to make it shorter for the gas tank in the rear. I wish I had done more to make it lower like you did. Maybe next winter I'll redo it.
    Great job.
    chryslerfan55, JOYFLEA and Mikel50 like this.
  10. Mikel50
    Mikel50
    Thank you.
    With the chop, channel and kicked rear I’m fortunate to have the ability to run a seat period.
    I’m just trying to make it all work.
    I’m 5’9” have about 1”-1.5” of head room as it sits now.
    I’m getting there.
    chryslerfan55 and patmanta like this.
  11. Mikel50
    Mikel50
    Arrived home from work today to see my radiator arrived plus a whole bunch of other things.
    I wanted to see how things fit so I set the radiator in place.
    Without a hood it’s not bad, however with a hood I think it’s going to sit a touch high ... about an inch.
    So Looks like something going under the knife.
    [​IMG][​IMG]
    I had electrical problems with my Tig welder a while back. Eastwood shipped me a new one that showed up yesterday. I was actually hoping for a check ... looks like I’m stuck with this one. Hoping it’s works out.
    Fruits of eBay sales - What every day should be like [emoji1370]
  12. NashRodMan
    NashRodMan
    Christmas time!!!! Lol
    Mikel50 likes this.
  13. Mikel50
    Mikel50
    No coal for this guy !!
  14. JOYFLEA
    JOYFLEA
    Check your socks .
    NashRodMan and loudbang like this.
  15. mike bowling
    mike bowling
    going by your pic ture you shoul d h av e room- hood goes on TOP of grille s hell, no? Only problem I had was filler neck didn't stick out fa r enough.
    F #cking b and age !!!!
  16. Dick Stevens
    Dick Stevens
    That's what it looks like to me, too.
  17. Mikel50
    Mikel50
    Hahah. I can just picture you cursing at your keyboard
    I’ll take some better pics. Filler is perfect. Tucked low enough and far back enough there shouldn’t be an issue.
    It just appeared the shell sat a touch high
    We shall see.
    I’ve got a plan [emoji1362][emoji16]
    chryslerfan55, loudbang and JOYFLEA like this.
  18. mike bowling
    mike bowling
    I bet you DO!
    So far you're doing great- how soon are you open for outside work?
    "Bog Hopper's Hot Rods"
    chryslerfan55 and Mikel50 like this.
  19. Mikel50
    Mikel50
    Not till it’s warm and sunny. This frozen tundra ****s ... 70° would be okay.
    chryslerfan55 and biggeorge like this.
  20. Mikel50
    Mikel50
    Spent some time tonight straightening out my bandsaw.
    Made a new taller stand from 24” to 32” .. used the old sheetmetal legs as gussets and added wheels, metal catch can, and a handle to move it around ... gave it a quick paint job and it’s good to go.
    What a great tool to have.
    Naturally I used it to make the stand for it... only seemed fitting.
    The precision and (no dust) is the best part.
  21. Dick Stevens
    Dick Stevens
    Is there an echo in here?!?! :D:p:rolleyes:
  22. Mikel50
    Mikel50
    Huh. No clue. Something went wrong.
  23. Mikel50
    Mikel50
    Scored a whole bunch of ViseGrip and Craftsman hand tools the other day plus some old C clamps... had them soaking in diesel fuel to loosen things up... media blasted them today and sprayed them with a few coats of zinc paint to clean them up.
    These were all “s**** metal” according to the woman and I did her a favor by taking them.
    I gave her a few bucks ($20) because I felt guilty.
    After that I got the grill shell mounted to the radiator.
    Made sure the hose kit fit properly and got the support rods cut to length and secured.
    It was a good day
    Onward [emoji1371]
    [​IMG][​IMG]
    [​IMG][​IMG]
  24. Dick Stevens
    Dick Stevens
    You should feel guilty, you scored well over $200 worth of Dewitt Vice Grips and Craftsman locking pliers not to count the clamps! The Dewitt Vice Grips are worth their weight in gold, almost :rolleyes:
  25. Mikel50
    Mikel50
    Oh well ... shame on me.
    I just thought I was lucky cause of st patty’s weekend ! [emoji256]
    She didn’t even want the $20 lol.
    The s**** guy was coming to take it all for zero. They were all rusted. Most didn’t work ... but they do now !!
    It was all I had on me anyways haha... the bad part that’s only some of what I got.
    I’ll save the rest for another day.
    The Kendall Oil drum is what caught my eye first. [​IMG]
    The tools were a bonus [emoji16][emoji1360]
  26. NashRodMan
    NashRodMan
    Hey Mike, any update here? We only allow a break in progress and posting if you are busy doing family stuff! :rolleyes:;)
    Mikel50 likes this.
  27. sloppy jalopies
    sloppy jalopies
    on the ride home did you think of what he did and how long since her old man used them ?
  28. Mikel50
    Mikel50
    I got the whole story from the wife.
    He was a dodge mechanic at a local dealership.
    He hadn’t used them in a while seeing they were all rusted and not functioning
    She had a huge snap on box for sale that was chock full of tools.
    I didn’t have the 3G’s on me haha.
    This stuff was “s**** metal” as I had mentioned before.
    She didn’t care about the rusty tools.
  29. Mikel50
    Mikel50
    Here’s my official call out huh.
    Work has been super busy past few weeks ...(Self employed painter)
    Kids keep me pretty busy and life in general but c’mon.
    You know I’m out here picking away at things.
    TIG Welding 101 has been my focus the past week.
    Built myself a torch holder as one of my many ”learning projects “
    Finally getting comfortable enough to start burning metal together on the car.
    Been fine tuning my seat mounts and working on the 3rd rendition of my p*** seat hinge mounts.
    [​IMG][​IMG][​IMG]
    Off topic.
    I built myself a new set of ramps for my car trailer.
    Mine weren’t readily available to me and I needed my trailer so I spent some time this week building them.
    These should hold up well ... however they’re heavy as hell.
    I wanted to TIG weld them for practice.
    Used a full bottle of argon but it’s worth the $30
  30. Mikel50
    Mikel50
    I also finished up the rear seat mounts and got the fuel tank mocked up in its final position.
    My next big task is to build the bulkhead / firewall for it.
    I fine tuned all my floor pans getting everything fitted nice and tight. [​IMG]
    Picked up a nice set of NOS Kaiser Tail lights on eBay
    Have all the parts for a banjo rebuild for the rear.
    That’s heading out soon to get overhauled.
    Once that’s complete, I’m going to pull the body off and do some rear suspension changes and get brakes and fuel system plumbed.
    Little steps but it’s still moving in the right direction.
