Technical mig gas regulator
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 16, 2018.
  1. topher5150
    topher5150
    I bought a used Miller Sidekick a while back, and the guy I got it from gave me a Victor CF153 with the purchase. I was looking at the regulator yesterday and its stamped for CO2 does this make a difference in which bottle, or gas I get?
  2. models916
    models916
    Regulator should only fit the correct bottle for CO2
  3. Chavezk21
    Chavezk21
    Double check with welding supply place. Mine was for co2, but I use with 75/25 argon co2 mix. Welds way cleaner.
    Dave Mc likes this.
  4. topher5150
    topher5150
    I'm just patching up the frame, and maybe going to do the floor boards so it doesn't have to look to pretty.
  5. treb11
    treb11
    It will work just fine.
  6. seb fontana
    seb fontana
    from ct
    You can get adapters to mix and match..
  7. gene-koning
    gene-koning
    I've been a sub-dealer for welding and cutting g***es for 25 years.
    As far as I know, the valves for all the cylinders containing gas for welders are the same, and they all use the same regulators. The welding g***es are Argon, CO2, and any combination % of these two. There are also welding gas mixes with varying % of Helium mixed with the Argon and CO2. Helium, nitrogen, and oxygen cylinders also use the same valves and regulators. There is a liquid CO2 for Beveridge that uses a different valve.
    Cutting g***es, acetylene, propalein, and propane have a different valve and require a different regulator. Some of the old cutting gas cylinders have a male valve, but most of the newer cylinders have a female valve. There is an adapter to connect the two versions for cutting gas regulators. Some of the small cutting gas cylinders have a smaller valve that requires a smaller regulator or an adapter to use the standard cutting regulators.
    I'm sure I've missed something, this is off the top of my head. Gene
  8. sunbeam
    sunbeam
    The hookup to the bottle is different but that can be changed out. Argon regulator will have external threads on the nut co2 internal threads.
  9. topher5150
    topher5150
    I have a male end
  10. sunbeam
    sunbeam
    It will work OK. They both just flow a shielding gas if it fits the bottle go with it.
