Projects 41 chevrolet coupe inspiration.
Discussion in 'Traditional Customs' started by Lono, Mar 14, 2018.
  1. Lono
    Lono
    Apparently it's got a camaro clip up front. I'd rather it had been original but I don't mind a little creature comforts. The sofa isn't too pretty in there and I agree that there's a change needed there too.
  2. Lono
    Lono
    They look sweet sitting lo. Funny how the lower they go the fatter the fenders look.
  3. 'Mo
    'Mo
    '41 Chevies are beautiful, even unchanged.
    I love customs, but this one (from Kustomrama), done in 1961, is just about as nice as any other.
    If you do get it (hopefully), just make it run, make it safe, and enjoy it while thinking about what changes to make later.
    Okie Pete, Fern 54 and Lono like this.
  4. Lono
    Lono
    Bit of a sleepless night. Quiet busy in the mental shop, cutting, sanding, filling, changing fluids. Swear I'm worn out this morning.
    before the construction begins, some other work is in order. Change the fluids and the owner says there's a vacuum leak he can't find. I'll get more details on that and try to isolate it. Then it'll be run around the block a little and then start pecking at things.
    First thing is the stance. I see it has blocks already from a picture but can't tell how big. 3 inch is the magic number out back, the front, we'll let's get it on solid concrete and see what I can do.
    Then it'll be tires and skirts to accommodate any additional lowering I need to do. Most likely the belt line trim is going to go and the trunk handle will get shaved and liscence plate relocated. That should be enough for the first week.
  5. Lono
    Lono
  6. NashRodMan
    NashRodMan
    In that case, Lono, dropped spindles would be the best way to go.
    Lono likes this.
  7. Lono
    Lono
    I agree but I've been reading about camaro srop spindles rubbing on wheels. It could be the drivers are running big fats up front, I don't know. Right now it's drums all around and apparently have about 30 miles on since install. I think you have to switch out to disk on all drop spindles.
    On old fords and chevs, I've changed out to are star coils or cut out the lower spring cup and reinstalled with 1 inch lowering blocks. Both have given great rides and doesn't change the geometry. I need to see the camaro front end to know that I can do.
    On my 60 olds, I switched out with 1968 firebird 400 coils. It dropped it 3 inches, improved the ride and tightened up the sway.
  8. Rogue63
    Rogue63
    from New York
    Haveing a clip like that gives you a lot to work with good steering good brakes and simpler engine swap. It’s a win win
    Lono likes this.
  9. Just Gary
    Just Gary
    Scooter has a nice black '41 coupe, slightly lowered with tan steelies. :cool: Hopefully he'll post some pix.
    Scooterville likes this.
  10. Rogue63
    Rogue63
    from New York
    I’m running 17’s it gives me clearance for 13” rotors. Stops perfect. It’s not a heavy car but rides fantastic. I always make super drivable then cosmetics. See too many starts and no finishes
    Lono likes this.
  11. Dave Mc
    Dave Mc
    My 41 Special Deluxe w/ 6 cyl. 3 on the tree ,I traded this one for my 53 cad IMG_0401.JPG IMG_0402.JPG IMG_0403.JPG
    Hnstray, Okie Pete, upspirate and 4 others like this.
  12. Rogue63
    Rogue63
    from New York
  13. Lono
    Lono
    Slobber.
    where there's smoke there's fire. Driving 350 mile tomorrow to look it over with cash in hand. I couldn't last till monday. Fingers crossed.
    'Mo likes this.
  14. Rogue63
    Rogue63
    from New York
    I would have left already. Check numbers. Data plate under p*** side front seat under rug. A lot of different letters for same model. Likely AH or I’ve seen AA.
    Lono likes this.
  15. Rogue63
    Rogue63
    from New York
    Good luck.
    Lono and 'Mo like this.
  16. Scooterville
    Scooterville
    Hey looking forward to seeing your progress. Here's mine. I ultimately would like to build a non adjustable suspension taildragger (Chopped, skirts, custom early 50's hubcaps) but not sure if I'll ever get there. This is the day it was delivered to me in April 2014.
  17. Scooterville
    Scooterville
    Added spider cap/ rings, chrome bumpers, and louvered the hood and trunk lid. Has a small block 283 and 4spd on the floor with a HAMB #41 Shift knob :). 4" drop in the rear, and up front I cut 2-1/2 coils from the springs. 51275357802__0EB48D01-F7B8-4D55-AAC0-55CB78D5F97A (2).JPG IMG_20170402_160304_693.jpg IMG_20170402_160322_052.jpg IMG_20170402_183402_572.jpg
  18. Scooterville
    Scooterville
  19. Rogue63
    Rogue63
    from New York
    Nice I’m looking into chop. They are very comfortable.
  20. Scooterville
    Scooterville
    More random pics...
    12744611_551200585036138_960682303511384509_n.jpg JMichael_b.jpg 100_4697 (Medium).JPG 10252062_878759978859771_4072492503724660836_n.jpg
    FortyNiner, Just Gary and Fern 54 like this.
  21. donno
    donno
    '41 is one of my favorites. No one else has asked, so I will. What's that "box" on the fire wall? Good luck.
  22. Rogue63
    Rogue63
    from New York
    Looks like a crude attempt to hide wires in a conduit. Industrial way of cleaning up engine compartment. Probably wrong.
    Lono likes this.
  23. Lono
    Lono
    I think you're right.
  24. Lono
    Lono
  25. Scooterville
    Scooterville
  26. Scooterville
    Scooterville
    I meant to say 2-1/2" of the coil spring was cut. lol
    FortyNiner and Lono like this.
  27. Lono
    Lono
    Looking at that hood again, there must be some heavy mud action going on or some major shrinkage to get rid of the rib up the center of that hood.
  28. Lono
    Lono
    Thinking of taillight treatments, has anyone seen a part of pre60 vette taillights installed in the fenders. Just looking at them wondering if the angle is right.
  29. Rogue63
    Rogue63
    from New York
    They fit 49 50 Chevy. I used Pontiac [​IMG]
    Fern 54, Lono and Scooterville like this.
  30. Scooterville
    Scooterville
    How bout in the bumper guards? That would be cool too.
