I have a 39 zephyr coupe sedan(only 800 produced)
Discussion in 'Traditional Customs' started by rpent, Mar 16, 2018.
  1. rpent
    rpent
    The car has been butchered with an s10 frame that I want to discard.The original frame is gone.I want to build it as a tail dragger custom with air bags in the rear to get it as low as possible.Does any of you hambers know where I can get the original frame specs.I also would appreciate any input as to ch***is solutions for me.Im all so thinking of chopping the top about 3 inches.[​IMG]
    Sent from my SM-G950U using The H.A.M.B. mobile app
  2. I hate to ask this but what makes it a coupe sedan. :confused:
    If it were me I would do one of two things, I would look for an original frame or a Ford Product from the same era. The Ford or Merc frame will probably be too short but you got to back half it anyway if you're gonna bag it. Use the frame rails and get the front axle where it is supposed to be, then back half it. Or I would just consider that all it has is a perimeter frame, get some 2x4x1/8 tubing and start measuring the body to see where your rails have to lie and go from there.
    osage orange and rpent like this.
  3. twenty gallons
    twenty gallons
    I can add thru experience that Art Morrison will build you an EXCELLENT frame specifically for this model and make it go as low as you want it to go, a bit expensive, but you get what you pay for...
  4. 'Mo
    'Mo
    I like your signature, twenty gallons. :cool:
    Hnstray and The37Kid like this.
  5. 'Mo
    'Mo
    If you're chopping the top, you can also fit the body to the frame (rather than vice versa).
    An extreme case, just for example...
    (EDIT: BTW, Ray Ericson and Doug Thompson were both involved with this build!)
  6. rpent
    rpent
    Thanks something to ponder.
  7. a Lincoln zephyr?
    they are unibody
    Frankie47, Hnstray, Chris and 2 others like this.
  8. rpent
    rpent
    Thats a good option.Emailed and got a ball park figure of 20k. And it stuck in my throat when I swallowed.At least I would know it was done right.
  9. rpent
    rpent
    Ford made 800 2dr sedans in 39 and they called them a coupe sedan.
  10. it was designated as an H-70
    cool car
    if its built like regular Lincoln Zephyr it was a unibody
    wonder how bad someone cut that up to do that S10 abomination to it?
    DECO RIDES, a fibergl*** Zephyr body, uses a Fatman fab ch***is
    google 'S****e" a custom Zephyr built a while ago, used a late GM car ch***is( I think)
    that would make a killer tail dragger
  11. vtwhead
    vtwhead
  12. rpent
    rpent
    Yeah they cut the floor and the original frame out ....I checked with fat man fab and they said the frame they may wouldn't fit an original Zephyr.
  13. that car deserves a nice ch***is
    a well planned build and execution on that car would get a lot of attention
    as well as bump up the $$$ of it
    are you up to building a ch***is from scratch?
    read this article http://www.decorides.com/elementsofstyle.htm
    chryslerfan55 and rpent like this.
  14. mr57
    mr57
    With only 800 made I hope you have the trunk lid...
  15. Graystoke
    Graystoke
    I like your plan !
  16. rpent
    rpent
  17. The37Kid
    The37Kid
    Got to follow this project, so many great cars & builds that are linked to it. Bob
    rpent likes this.
  18. rpent
    rpent
    Yes I have trunk lid and hood.missing small stuff like headlight rings,chrome trim and bumpers.
    chryslerfan55 and mr57 like this.
  19. rpent
    rpent
  20. Beanscoot
    Beanscoot
    Are Capri pants traditional?
    Edit: I guess they are, this picture proves it!
    mgtstumpy and chryslerfan55 like this.
  21. lucas doolin
    lucas doolin
    Anthony Myrick, post: 12485162, "a Lincoln zephyr? they are unibody"
    Not really. They have a normal (for the period) Fomoco type frame to which the body is riveted/welded in an attempt to avoid squeaks and provide additional rigidity, but this does not make it unibody, at least in the sense of not using an underlying frame (as compared with current automotive design). Lucas
    Atwater Mike and chryslerfan55 like this.
    a unibody by definition
    it may look different than today's unibodys but this is one
    mgtstumpy, Hnstray, rpent and 2 others like this.
  23. typo41
    typo41
    Yea and they were called "Clam Diggers"
  24. J. A. Miller
    J. A. Miller
    from Central NY
    They were also called " Pedal Pushers" up in my neck of the woods.
  25. Thanks
    They were called both where I grew up. Seems to me like in my mind Clam diggers were normal cloth and peddle pushers were stretch pants. No one told me that that I recall so it was probably just a little kids mind. :D
  26. rpent
    rpent
  27. rpent
    rpent
  28. Possible. I know where some old ch***is deminsion books are. I just don’t know how far back they go
    rpent likes this.
  29. BamaMav
    BamaMav
    from Berry, AL
