Projects 32 grille on Model A banger help please!
Discussion in 'Traditional Hot Rods' started by GASSERBOB, Mar 17, 2018.
  1. GASSERBOB
    GASSERBOB
    from USA
    I would like to put a 32 grill on my 29 Model A maybe. I am running a banger engine. I was wondering what radiator most of you guys were using?
  2. 28TudorAZ
    28TudorAZ
    You need the one that is about 4 inches shorter. then you build your brackets. I got an aluminium one off ebay.
  3. sloppy jalopies
    sloppy jalopies
    Try a Modine #397...
    Fits a '63ish Ford 6 cyl. pick up... sbc layout, centered filler, with the mounting flanges trimmed it fits in a '28-'29 shell... too small of a core, you can see part of the top tank...we like to use overhead lighting defusers, $13 at LOWZ does 2 shells...
    Moves the radiator back 3/8" to 1/2" [hood fit ?] ...
    You can just barely see the top tank in my buddy's '31 A tudor... DSCN0819.JPG DSCN0820.JPG
    continentaljohn and Okie Pete like this.
  4. trucker1
    trucker1
    Jamco built mine '32 style, but same height as the model A. You need to trim the lower sides up to drop the shell to keep your hood going at the right line.
  5. GASSERBOB
    GASSERBOB
    from USA
    Thanks for some information guys. Bob.
  6. 3banjos
    3banjos
    from NZ
    Stick with the Model A grille Bob, after all, that's what it is. :rolleyes:
  7. GASSERBOB
    GASSERBOB
    from USA
    I think your rite 3banjos. Every time I look at it seems to look better. It matches it better I think 004.JPG . Here is a picture of it. Bob.
  8. sloppy jalopies
    sloppy jalopies
    The model A shell screams look at me I'm a model A Ford... mmmmmm
    3banjos likes this.
  9. 63Compact
    63Compact
    Id leave it alone and drive it. It looks killer.
    Fordor Ron, 3banjos and Vanness like this.
  10. 3banjos
    3banjos
    from NZ
    ****, that looks great Bob. How does it perform with those trips.
  11. joee
    joee
    it's perfect....i have a 32 on mine and it's just a little off style
  12. GASSERBOB
    GASSERBOB
    from USA
    Ok guys . Thanks for helping me stay with the model A grille. 3banjos , there original 81's that Uncle Max did for me. He's great. I am just running the 2 for rite now. The engine is completely rebuilt with inserts . The head is 6 to 1 . Touring engine. Schwalms rebuilt it for me ,here in Pa. He's one of the best here in the USA. He ships a lot to Australia and to New Zealand. It runs real good. Thank you for the nice replies guys. Bob.......................
    bundybiker and Ric Dean like this.
  13. 28TudorAZ
    28TudorAZ
    Here is a good comparison for you with the hood off. I personally love the 32 grill. I kept the old one of course. I had a hole in my radiator and was thinking about it before that and thought if I am going to switch it out ....better do it now.
    Okie Pete likes this.
  14. X38
    X38
    All this grille talk! It is a radiator shell!
    A model A has no grille at all while the Deuce has a separate one within the radiator shell.
    hotrodtom likes this.
  15. Mr48chev
    I'm putting a 32 grill on my 31 but have to agree that the 28/29 looks better with the stock shell. I didn't have a shell at all nor a radiator so that is a moot point for my Vic.
  16. clem
    clem
    G***erbob,
    Cool car, like others have said, stay with the original shell.
    The ‘28 /‘29 s just don’t look right with a ‘32 grille and surround.
    Something to do with the height of the radiator/hood etc.
    If you don’t believe me just look at post 13.
  17. chev34ute
    chev34ute
    A 32 grill shell will fit a stock Model A radiator with very little effort. I cut the the bottom out of the shell by an inch or so and the shell slides over the radiator to the point where the hose sits neatly through the 32 surround.
  18. sloppy jalopies
    sloppy jalopies
    '28-'29 radiators are a little wider than the '30-'31s,
    gets tight at the upper edges of the sides... like dad said... measure before you buy...
  19. GASSERBOB
    GASSERBOB
    from USA
    I know that.
  20. GASSERBOB
    GASSERBOB
    from USA
    Thanks Clem . I see what your talking about. I will keep the 28-29 shell. Bob.
  21. GASSERBOB
    GASSERBOB
    from USA
    Thank you guys for all your replies. Bob...
  22. Never2old
    Never2old
    from so cal
  23. GASSERBOB
    GASSERBOB
    from USA
  24. Mr48chev
    Well I may have to change my opinion on the 32 shell on the 29 thing after seeing that.
    Sent from my VS988 using The H.A.M.B. mobile app
  25. GASSERBOB
    GASSERBOB
    from USA
    Yea that's what I thought to. Some you see they look real good. Some you see they don't look real good. That's why its hard to make my mind up. Bob...................
  26. Never2old
    Never2old
    from so cal
    Thanks for the compliments.
    I had it built both ways in my head, but I had to chose one.
    It gets upholstery starting this week.
  27. 28TudorAZ
    28TudorAZ
    Here is the pic in my avatar. 28 w/32 grill. I think its still old school because it was done a lot back in the day.
  28. 49 fordge
    49 fordge
    from Floral, Ar
    Man that is one good looking pickup!!!
  29. hardtimesainit
    hardtimesainit
    That is a fine looking A , and a great improvement over the original shell !
    Question; Part of the really 'clean' look of your ride is the way you mounted your headlights with full fenders.
    Where are those headlite mounts available....or did you fab those up ?
    Blue...my favorite color, other than shaker can Grey, eh !
