Projects Time for another '32 pickup.
Discussion in 'Traditional Hot Rods' started by edwardlloyd, Jul 12, 2017.
  1. edwardlloyd
    edwardlloyd
    from Germany
    I'm not in the UK. Germany is where I'm based. It's allowed here on pre-72 cars as it was standard up until then. The 32 pickup didn't even come with safety gl*** at all as standard.
    Sent from my SM-G935F using The H.A.M.B. mobile app
  2. edwardlloyd
    edwardlloyd
    from Germany
    Like most pickups, the 32 has a little bit of room behind the seat. It's not much but it'll hold a tool role, a jack and some spare fluids. I'll also put in that nifty set from Bob Drake to remove hubcaps.
    To stop things rattling around I carpeted the area using some off cuts from a local factory who makes carpets for Mercedes Benz. The front edge carpet was located using a gold anodized carpet trim. The cab back carpet was stuck on with double sided tape and the floor bit just rests on the floor.
    I also converted a late model Ford jack. Welded a lug nut on the end and used a section of torque tube welded to the top as a cradle for the axles. I coated that with beads of silicon to prevent the axles getting scratched.
    [​IMG][​IMG]
    mgtstumpy, brEad and chryslerfan55 like this.
  3. edwardlloyd
    edwardlloyd
    from Germany
    Also fitted the header instrument panel and wired that all up.
    Next up - fitting the windshield.[​IMG]
  4. alchemy
    alchemy
    Sorry, I should have seen that you are German. But I still prefer safety gl***.
    When I was installing some new gl*** in my 32 sedan I found the setting tape was too thick for the gl*** to fit into my tracks. I ended up using just 3M black urethane to glue them in. If I had to do the windshield I would probably do the same process. Then the rough edge of the setting tape wouldn't show either. You can wipe the urethane smooth before it dries and make a nice water-tight edge.
  5. You can get a security film that they use in rally cars that addresses this problem. Demon Tweeks carry it.
  6. Deuce Lover
    Deuce Lover
    Just found your thread.My compliments. On the fuel gauge -run a 5/16 -24 die on the threads to clean them as they get corroded over the years.That's what I do in the gauge rebuilding process.The speedo turtle on a 32 originally was mounted on the bottom side angled up on the right side.In '33 they mounted on the top and pointed to the left side.
  7. edwardlloyd
    edwardlloyd
    from Germany
    Thanks. Yes you're right. However finding a die small enough to fit is the problem. It's really close to the back of the gauge.
  8. edwardlloyd
    edwardlloyd
    from Germany
    Set back. No. 2.
    I'd found a great looking aluminium remote oil filter housing. It uses the stock Flathead filters and even the lid is the same. However I've never seen one like this.
    Unfortunately it was cracked around the inlet boss. I found someone who claimed he could weld it.
    Anyway he couldn't! He made a real dogs dinner out of it and now it's definitely not restorable:-(
    So on Saturday I drove over to David Pontones and he had another one! And it was perfect.
    These filters came from Argentina and they might be locally made. I've only ever seen two.
    Today I cleaned it up and mounted it on the firewall. Very relieved!
    [​IMG][​IMG]
  9. alchemy
    alchemy
    Was that made for an actual cartridge, or a roll of toilet paper? I've got a few different filter canisters that were actually made to hold TP, and think that there must be a proper cartridge out there somewhere with the proper dimensions to fit them.
  10. edwardlloyd
    edwardlloyd
    from Germany
    Well the Ford cartridge fits in there but I'm not sure how it's supposed to work. Still not figured out how the cleaned oil in the center of the filter gets into the central tube.
  11. louisb
    louisb
    Sweet looking filter holder. To bad this first one was ruined.
    --louis
  12. edwardlloyd
    edwardlloyd
    from Germany
    I worked out how the filter flows. There's a tiny hole in the side of the tube inside the canister. It was blocked.
    loudbang and Stogy like this.
  13. alchemy
    alchemy
    Make sure you have a restricted fitting on the inlet to that canister. Flathead Fords needed this restriction to keep up pressure in the rest of the system, since the filter is only doing 5% of the oil at a time. I don't remember the size of the hole in this fitting, but I think it's around 1/16". See if you can find the measurement in a flathead reference book.
    chryslerfan55, loudbang and Stogy like this.
  14. edwardlloyd
    edwardlloyd
    from Germany
    Yes I've got that mounted. I was doing the engine side oil lines today but ran out of copper tubing so the rest will have to wait.
  15. edwardlloyd
    edwardlloyd
    from Germany
    No matter what, you can never fit the rubbing strips on the bed on your own. Unless you've got arms like a chimpanzee.
    So today Henry came to work with his dad and helped me fit the strips.[​IMG]
    mgtstumpy, louisb, waxhead and 7 others like this.
  16. Petejoe
    Petejoe
    from Zoar, Ohio
    Good job Henry. Way to get them started dad. Make sure he’s having fun.
    chryslerfan55, Stogy and loudbang like this.
  17. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Edward, Do you have any shots of the box structure/framework by chance? or could take a few shots of yours while its on its side? I'm helping a friend put his box together using new structure pieces from MAC's using original sides and I'm not sure if they sent the wrong parts.
    Brandon
  18. edwardlloyd
    edwardlloyd
    from Germany
    Brandon, Ive built a new one before and it's a mystery at first how it goes together. I'll take some pictures for you.
    Best advice I can give you now is.
    Start building the subframe first building it on your ch***is.
    You'll need the rear mounts too which don't come with the bed set.
    chryslerfan55, Stogy and jalopykid like this.
  19. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Thanks Edward, some pics will definitely help a lot!
    Stogy likes this.
  20. avachace
    avachace
  21. edwardlloyd
    edwardlloyd
    from Germany
    Here's some photos of the bed subframe taken from the front to the rear. The side rails have cut outs to clear the frame at the top of the kickup. The center crossmember also has cut outs to clear the frame.
    The first photos are of the rear mount which you'll need to source or make.
    The crossmembers have holes for the D nuts which you need to install before ***embly.
    The bed kit comes with loads of rivets to rivet the bed together but you can ***emble with nuts, bolts and lockwashers instead.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  22. PRIMER STUDIO
    PRIMER STUDIO
    from Butte,MT
    Thanks Edward! that helps out a ton!
  23. edwardlloyd
    edwardlloyd
    from Germany
    I've been making progress on the 32 pickup lately. The F1 steering box is fitted but I haven't got the nut to secure the Pitman arm on the sector shaft. Macs don't sell one. Can anyone tell me where I can buy a new one? That'd be great.
    Only a few hundred small things to do and it'll be ready for it's first test drive. 20180605_141734.jpg
    brEad likes this.
  24. Deuce Lover
    Deuce Lover
    What is the size? 1 inch? Will the orig '32-34 work if you have one? I can check with a buddy in Calif when they wake up.Its 6:30 AM there now.
  25. alchemy
    alchemy
    Any pitman nut from 32-48 p***enger cars, and of course the later F-1 will fit on there.
    Stogy likes this.
  26. Corn Fed
    Corn Fed
  27. edwardlloyd
    edwardlloyd
    from Germany
    I found out why my banjo axle was leaking so badly. My axle builder hadn't put even the thinnest gasket on one side.
    I need to seal it somehow.
    Would it hurt to install the thinnest gasket available? Should I apply a thin smear of silicon to the gasket to ensure a good seal? Or is this going to throw off the bearing settings too much? I suppose I could use a shim under the bearing to compensate. The gasket set does come with shims. But that would mean pulling the new bearing which may be difficult. 20180618_144723.jpeg
    brEad likes this.
  28. m.kozlowski
    m.kozlowski
    Smear a little bit of sealant (rather not silicone) on that and put it together. Should be good.
  29. edwardlloyd
    edwardlloyd
    from Germany
    The truck is very nearly finished. I'll post pictures as soon as it's finished and washed.
    On to another matter. I'm looking for another original 1932 front crossmember to repair the next 32 frame.
    Has anyone out there got one stashed away I could have? Strange how most 32s run Model-A front crossmembers but the original ones are still hard to find!
  30. edwardlloyd
    edwardlloyd
    from Germany
    I spend the afternoon cleaning and polishing the truck. Here it is - finished. 20180807_182640.jpeg 20180807_182605.jpeg 20180807_182509.jpeg 20180807_182500.jpeg 20180807_182432.jpeg 20180807_182549.jpeg 20180807_182517.jpeg
