Shoebox Coupe Mild Custom Build.
Discussion in 'The Hokey Ass Message Board' started by kiwiandy, Oct 21, 2011.
  1. kiwiandy
    kiwiandy
    Thanks, much appreciated. I'm going to do a stocktake of what I have and what I need soon. It was bought as a project in pieces so I'm not sure what I need?
    Cheers
  2. kiwiandy
    kiwiandy
    Car likes this.
  3. kiwiandy
    kiwiandy
    Car and 26 T Ford RPU like this.
  4. kiwiandy
    kiwiandy
    Taken a week out of work to go and help on my coupe. Decided to remove the rear quarters and clean out and blast the area behind.cut around behind the seams as I'm keeping those. Front fenders and rear quarters off to get blasted and epoxy finished before ***embly and refit.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  5. 26 T Ford RPU
    26 T Ford RPU
    Big job !! nobody would believe what you have done on it after its all finished. JW
    kiwiandy likes this.
  6. kiwiandy
    kiwiandy
    Ain't that the truth. I have a hard time believing it myself sometimes!
    26 T Ford RPU likes this.
  7. kiwiandy
    kiwiandy
    Fenders rear area blasted then painted before re***embly of the internal frames[​IMG][​IMG][​IMG][​IMG][​IMG]
    Car, Hnstray and 26 T Ford RPU like this.
  8. kiwiandy
    kiwiandy
  9. patterg2003
    patterg2003
    That car will last another 50 years with all the hidden rust taken care of. It is disappointing to see a great cl***ic with nice paint rusting from the inside out. Well done!
  10. kiwiandy
    kiwiandy
    Thanks. Yes with the epoxy etch and rust proofing after painting, it should be good for another 50 years!
  11. ROBERT JAM
    ROBERT JAM
    I Enjoy this keep us up on the progress
  12. Finnrodder
    Finnrodder
    from Finland
    Thats pretty ******** way to do it,but in a good way.Great work!
  13. kiwiandy
    kiwiandy
    Thanks. The sheet metal forward of the firewall is away being blasted and put into primer. Can then hang it and gap it. Going to also blast the areas behind the rear quarters before they go back on. Ideally will then separate the body from the ch***is and get into some mechanical work
  14. kiwiandy
    kiwiandy
    Thanks man. Been checking in on your project as well!
  15. kiwiandy
    kiwiandy
  16. kiwiandy
    kiwiandy
    Some more progress pics IMG_7311.JPG IMG_7312.JPG IMG_7319.JPG IMG_7321.JPG IMG_7320.JPG IMG_7317.JPG IMG_7309.JPG
  17. tub1
    tub1
    from tasmania
    absolutely wonderful work from guys that know what they are doing well done look forward to more progress pics
  18. kiwiandy
    kiwiandy
    And after many many years it's off for abrasive blasting and epoxy primer.
    The quarters will then be s***ched back onto the body along with the rear panels.
    The body will then be lifted and I'll start on the ch***is
  19. 26 T Ford RPU
    26 T Ford RPU
    Great work and progress.:cool::D JW
  20. NashRodMan
    NashRodMan
    You are a patient man. It's gonna be nice when done!
  21. warhorseracing
    warhorseracing
    from cameron wv
    Beautiful work to restore the car. My '51 was not in that bad of shape but I know your frustration of hopes of a quick paint and drive to what you find when you finally start prepping it.
  22. kiwiandy
    kiwiandy
    And finally after 13 years it's seeing some primer. I'm certainly not going to miss sanding back the bare metal and coating with keyphos every six months [​IMG] [​IMG][​IMG][​IMG][​IMG][​IMG]
    Car, warhorseracing and 26 T Ford RPU like this.
  23. B4bazz
    B4bazz
    Great progress Andy, not much more to pull apart is there!
  24. kiwiandy
    kiwiandy
    Haha! Yeah it's about as far as it can go. Will s***ch the quarters and rear back on them remove from the ch***is again. Preparing to order the trans and probably engine.
  25. kiwiandy
    kiwiandy
    I need one of these
  26. choptop40
    choptop40
    Great effort...shoeboxes rule....
  27. kiwiandy
    kiwiandy
    Went out to do a little more work today. Got to see the underside up on the hoist. Really happy how they've turned out.
    I've put down a deposit on an Olds engine and trans so once the trans arrives I'll place it, make mounts and can then finish the tunnel.
    The door corners have been radius'd and the rear quarters are off for blasting before being refit. I decided to also radius the fuel filler flap as it was a feature of the 'factory custom' Ford. Looking forward to seeing how it looks in primer.[​IMG][​IMG][​IMG]
  28. kiwiandy
    kiwiandy
    Car, daddio211, beater32 and 2 others like this.
  29. kiwiandy
    kiwiandy
    [​IMG][​IMG]
    The under body has now had the seams sealed and a coat of Wurth underbody coating applied. This will be painted black to make it cleanable.
    [​IMG][​IMG]
    The ch***is is away for blasting and will also be painted.
    I've ordered my Olds Rocket and T350 trans from Tony at Ross Race Engines so looking forward to that arriving later this year.
    Car, daddio211 and 26 T Ford RPU like this.
  30. HOTRODPRIMER
    HOTRODPRIMER
    `Having recently joining the shoebox club I have been reading all the threads, this build is exceptional and your work is amazing. HRP
