Hot Rods Project, Inherited 1924 Model T Ford “Lil’ Sue”(30's two seat speedster)
Discussion in 'The Hokey Ass Message Board' started by Doc Wright, Mar 22, 2018.
  1. Doc Wright
    Doc Wright
    My late great-grandfather had a large amount of “spare” parts for Model Ts and I was able to get some stuff to start building a pick-up hot rod, will be posting more pics and updates, stay tuned.
  2. Deuces
    Deuces
  3. rusty valley
    rusty valley
    model T's are a lot of bang for your buck. good info at the MTFCA, (model t ford club of america) web site. great forum there, lots of interesting subjects. have fun, skip
  4. Doc Wright
    Doc Wright
    Quick Photoshop of an idea I'm throwing around
  5. Doc Wright
    Doc Wright
    I'll check them out, thanks man.
  6. iwanaflattie
    iwanaflattie
    Suscribed.
    Doc Wright likes this.
  7. Doc Wright
    Doc Wright
    Messed around a bit tonight with the initial mock up, might be missing a few parts.
    [​IMG] [​IMG]
  8. RMR&C
    RMR&C
    from NW Montana
    Looks like a great start!
  9. Jalopy Joker
    Jalopy Joker
  10. Doc Wright
    Doc Wright
  11. HOTRODPRIMER
    HOTRODPRIMER
    Reminds me of racinman's rig. HRP
  12. Doc Wright
    Doc Wright
    That is a kool setup, very much along the lines of what I'm thinking :cool:
    HOTRODPRIMER likes this.
  13. avachace
    avachace
  14. ct1932ford
    ct1932ford
    This looks like fun!:cool:
  15. Doc Wright
    Doc Wright
    A little bit of progress removing rust from the frame, some small pitting is present so using a filler primer to smooth her back out. Also found a great bullet hole through one of the headlight housings, probably going to paint the housing and leave the hole there for posterity. :)
    Okie Pete, kidcampbell71 and Vanness like this.
  16. Doc Wright
    Doc Wright
    Rough sketch of the soon to be ‘25 Model T speedster. Can’t wait to start building this body! Gonna be fun [emoji16]
    Okie Pete and RMR&C like this.
  17. iwanaflattie
    iwanaflattie
    What are you using to form the body panels?
  18. Doc Wright
    Doc Wright
    I'm going to build the base framework out of tube steel and the body shape itself will be geometrically simple with no/ minimal complex curves.
  19. cederholm
    cederholm
  20. Blue One
    Blue One
    from Alberta
    Interesting, but you will find out that its in no way comparable to Lego. :D
  21. Doc Wright
    Doc Wright
    Just really big dirty rusty parts missing LEGOs. :D
  22. Blue One
    Blue One
    from Alberta
    Yes, and those big rusty parts won't snap together as easily as Legos either. ;)
    Clay Belt likes this.
  23. Doc Wright
    Doc Wright
    That just makes it all the more fun [​IMG]
    Okie Pete likes this.
  24. The37Kid
    The37Kid
    Greaty start for a Speedster, looks like 1925 era parts for the most part. First step is going to Lang's Old Car Parts website and getting a catalog. Don is a HAMB member, doesn't post often but he has a few really nice Vintage T Hot Rods, plus every part you will need to build yours. Bob
  25. Doc Wright
    Doc Wright
    Just sent in a catalogue request [emoji106] thank you for the tip man!
  26. Doc Wright
    Doc Wright
    After much elbow grease I was able to discover a fresh coat of black paint under all that rust :)
    brEad, Okie Pete and kidcampbell71 like this.
  27. Doc Wright
    Doc Wright
    Just received my bible in the mail, read a bit so far and it’s more information than I know what to do with [emoji23]
    Okie Pete, kidcampbell71 and 27Tudor like this.
  28. Doc Wright
    Doc Wright
    Started back on the T finally again today, took some measurements of the rear of the frame. I’m going to make kustom lowering rear frame horns, looking for 5” drop right now but I’m doing more research on the lowest I can be before the rear-end starts back feeding fluid into the motor.
    [​IMG][​IMG]
  29. Doc Wright
    Doc Wright
    Had to stay home a bit recently [emoji855] I took a little time to start cleaning up the headlights, one is an original ford script while the other seems to be an older repop with a bullet hole for the extra touch of good luck!
    [​IMG][​IMG][​IMG][​IMG]
  30. iwanaflattie
    iwanaflattie
    Nice to see some progress!!!
