Projects 1930 Model A Progress
Discussion in 'Traditional Hot Rods' started by Paul F, Feb 4, 2018.
  1. Paul F
    Paul F
  2. mike bowling
    mike bowling
    I like doing things like that also- using different materials and finishes to highlight areas. They refer to it sometimes as "paint detailing" on a ch***is. You going to clear coat the raw steel? Do it with gloss, let it dry real good, then knock the shine down with 0000 steel wool ( very lightly).
    Here's my "Irish" green driveshaft, painted while listening to the "Dropkick Murphy's"
    biggeorge, catdad49 and Shadow Creek like this.
  3. Paul F
    Paul F
    Very nice...
  4. JOECOOL
    JOECOOL
    I am not a chopped top fan but its your car and I will still love it . Go for it .Save the pieces for conversation starters.
  5. Paul F
    Paul F
    So flux core mig welding runs hotter than gas due to reverse polarity...the old model A skin no likey flux core...
    JOYFLEA likes this.
  6. Paul F
    Paul F
    Going to pick up a tank for gas welding, got my regulator, so in the mean time I figure: use up the ****py flux core on the cage for the stability of the body after the chop. Pretty much ready now, my bro from another mo is going to come over to help in the festivities![​IMG][​IMG]
    Zombie57Ranchero, waxhead and JOYFLEA like this.
  7. GASSERBOB
    GASSERBOB
    from USA
    Hey Paul. I think your avatar picture of your car is on craigslist for sale.
  8. Paul F
    Paul F
    So I got my Argon tank, hose and regulator, setting up the right feed, heat, and gas mix...working a lot better! Practice, practice, practice
    JOYFLEA likes this.
  9. Paul F
    Paul F
    Decided to mount rear tail lights and license plate...fun stuff...two more weeks and it’s choppy chop time![​IMG]
    F&J, chop job, mike bowling and 6 others like this.
  10. waxhead
    waxhead
    from West Oz
    Love the winged surround that sits behind the handle.
    chevy54man, Paul F and catdad49 like this.
  11. sloppy jalopies
    sloppy jalopies
    IMO... before you cut the top off... set the body with the beltlines level...find a small [4"] carpenter's square with a level... cut a chunk of small square tube the length of your chop... tape it to the vertical... slide the square down the trailing edge of the quarter window till its level...mark at the top and bottom edges... this will tell you where to cut ... the edges will **** when you set the top back on... gonna need a couple cuts up into the roof as the '30-'31 coupe roof tops are wider / longer than the lower half...
    ... rock on !
    Paul F and JOYFLEA like this.
  12. Following this. I like your doing it for "therapy" at***ude.
    Now that's a NICE car as is.
    Paul F likes this.
  13. I have to agree with MAD 034, no chop and leave the fenders on. But, it's your car! Are you building a "banger" or ??? Most of all, have fun....
  14. sloppy jalopies
    sloppy jalopies
    I prefer channeling to chopping ... east coast...
    52 ford coe likes this.
  15. mike bowling
    mike bowling
    When laying out a 3" chop, I use 1" and 3" masking tape, "stacked", so that even if the layout is a little off, it's perfectly parallel. A shot of leftover paint, peel the tape off, and start cutting with a thin kerf
    4 1/2" disc in an angle grinder. I also put some tension up on the roof with a 2x4 through the windows 12-29-11 002.jpg 12-29-11 018.jpg DSCN1448.JPG and a chainfall so there's no chance of binding. This way you can do it yourself, and also lower the roof back down to fine tune before tacking in place. Key is to go slow.
    chop job and JOYFLEA like this.
  16. Dino 64
    Dino 64
    from Virginia
    I recently chopped my 31 coupe 2 3/4”. A few things I learned, with all due respect to others who have posted. Try to make your cuts close to the curvature of the windows and low on the A pillar. Cutting in a jig saw pattern in the rear will preserve the curve of the roof. This will also minimize distortion from welding as the body is stiffer near the curves and the belt line. And yes there will be pie cuts in many places to match the top to the bottom. Your on the right track, but I did my cut lines differently.
    Hope this helps, good luck with it. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    BradinNC, F&J, 40FORDPU and 9 others like this.
  17. mike bowling
    mike bowling
    Nice job, "Dino"!
    Dino 64 likes this.
  18. Dino 64
    Dino 64
    from Virginia
    Thanks Mike, means a lot coming from the A coupe guru [emoji41]
    wheeldog57 likes this.
  19. Rich B.
    Rich B.
    from Portage,IN
    I agree with Dino (great pics, and info!) I kept my cuts as low as possible.
    F&J, dwollam and Dino 64 like this.
  20. Dino 64
    Dino 64
    from Virginia
  21. Rich B.
    Rich B.
    from Portage,IN
    Thanks Dino! I'ts a 2" chop.
    Rich
    Dino 64 likes this.
  22. lodaddyo
    lodaddyo
    looks good. nice job on the chop!
    Dino 64 likes this.
  23. Paul F
    Paul F
    Well today was the day...so thankful for my bro coming over to help in the chop festivities...happy with the result, next up...welding the top on...[​IMG][​IMG][​IMG][​IMG][​IMG]
    Fitnessguy, Vanness, dwollam and 4 others like this.
  24. Paul F
    Paul F
    [​IMG][​IMG] more accomplished today, got the a pillars, b pillars, and the rear all welded up, sanded down, next up the doors...
  25. Paul F
    Paul F
    Ok I’m back...top is welded, sanded, filled, and all window trim and windshield frame is cut and done...next up, the body / ch***is separation...[​IMG][​IMG][​IMG]
  26. Dino 64
    Dino 64
    from Virginia
  27. Paul F
    Paul F
    Update: so I live in a rural area and people are just plain busy, so I had to figure out how to remove the body from the ch***is solo...So I purchased a 1 ton chain hoist, and a couple of tow straps and bam! Done! IMG_2744.JPG IMG_2741.JPG IMG_2773.JPG
    BradinNC, 32Dan, Speed~On and 3 others like this.
  28. Paul F
    Paul F
  29. Paul F
    Paul F
  30. Paul F
    Paul F
    JOYFLEA likes this.
