Projects It's 3/27, so show off your 327's!
Discussion in 'The Hokey Ass Message Board' started by 1pickup, Mar 27, 2017.
  1. DDDenny
    1pickup, LOWDUG37, Stogy and 5 others like this.
  2. Speed Gems
    Speed Gems
    Stogy and Deuces like this.
  3. J. A. Miller
    J. A. Miller
    from Central NY
    48stude,
    That looks fantastic!!! What color is that gold?
  4. blackout78666
    blackout78666
    327 sprint car engine. Flat tappet cam. Lehman front cover. Crank drive water pump. Cam drive pump. Cirello magneto. Early hilborn injection( Thanks Frank!!!) Ported 461 heads with screw in studs. 11:1 compression. Should take the alky well and make for a fun ride!
    1pickup, Stogy, Jalopy Joker and 4 others like this.
  5. enloe
    enloe
    from east , tn.
    image.jpg Working on changing the heater core so I can hear mine run again.
    1pickup, Stogy, Deuces and 3 others like this.
  6. Dennis D
    Dennis D
    Mine with the "sleeper" 283 covers. :D D
  7. Tweety
    Tweety
    Happy 3/27 to everyone! Here are a few of my small journal 327. Bored .030, comp 262H, offy tri power with Ford 94's.
  8. 61cad
    61cad
  9. DDDenny
    Those valve covers were also used on the 67 Z/28 302's, 67 L79 327's and 67 Camaro SS 350's.
    OEM chrome plated.
  10. 48stude
    48stude
    It's a Zips water pump riser with a six cylinder pump. Bill
    Stogy, Deuces and Speed Gems like this.
  11. 48stude
    48stude
    I started with Anniversary Gold, but it was too yellow against the maroon that I plan to use. I mixed a little maroon with it and darkened it up a little .I think it looks closer to Aztec gold now. Bill
    Deuces and J. A. Miller like this.
  12. catdad49
    catdad49
  13. 1pickup
    1pickup
    ^^ That's a beauty!^^
    And, you beat me to it this year! Thanks for posting.
    Deuces likes this.
  14. 1pickup
    1pickup
    oops, the gold one I'm referring to.
    Deuces likes this.
  15. HOTRODPRIMER
    HOTRODPRIMER
    My last 327. HRP
    1pickup, catdad49, Stogy and 3 others like this.
  16. bobbytnm
    bobbytnm
    Packard 327
    I posted a pic of mine last year, not much has changed but its getting closer and closer to being bolted into place
  17. blue 49
    blue 49
    from Iowa
    Mine again after a winter upgrade. I swapped the power pack heads for double humps, a little bit hotter cam, C3Bx intake and M/T valve covers. I have a duel point distributor to go in, too. 010.JPG
    Gary
    1pickup, Deuces, Jalopy Joker and 3 others like this.
  18. Marty Strode
    Marty Strode
    I just picked one up, to use in my '40 PU. It replaces a fresh 283 that I had planned for the project. IMG_1321.JPG
    1pickup, Stogy, Deuces and 4 others like this.
  19. DDDenny
    :cool:
    Specs man, specs.
  20. Gman0046
    Gman0046
    My 327 is a numbers matching 300 HP thats now .060 over with TRW domed forged pistons, Fuelie 202 heads, Comp Cams XE262H cam and valve springs, headers, balanced with a Holley 670 CFM Street Avenger carburetor. Couldn't be any happier with its performance with a Muncie M21 and a 3.73 positraction rear. Really pulls through all rpm ranges and has a ground pounding idle. IMG_0647.JPG
    1pickup, Shadow Creek, Deuces and 6 others like this.
  21. DDDenny
    Gman,your 63 is one of my faves here on the HAMB, I bet that is a lot of fun.
    I never took engine photos but with a good imagination one can picture the stock (and tired) 250 horse 327 in this Impala I owned a long ago. The car was not very inspiring to drive with the three speed column shift so I did a complete stock appearing Muncie changeover and I gotta say it totally woke that car up.
    1pickup, gotta56forme, Stogy and 4 others like this.
  22. Marty Strode
    Marty Strode
    A buddy of mine and I got a matched pair out of a boat, both had been rebuilt and .040 over, I got the one that was reverse rotation. It's getting freshened up, with a 260 Erson camshaft, and this Edelbrock tri-power, along with a set of fenderwell headers. Should make a nice package with a Saginaw 3 speed on the column. IMG_1281.JPG
    1pickup, catdad49, Stogy and 5 others like this.
  23. 31hotrodguy
    31hotrodguy
    Standard bore, 11:1 factory forged pistons,.crap 71 LT1 heads with z28 springs, Isky cam, Edlebrock intake, 59 348 WCFB, accel dist, Muncie 4spd. 35yr old build in my daily driver 57 210 sedan. Picture taken tonight at work. Lol [emoji3] Happy 327 day![​IMG]
    Sent from my SM-G550T using The H.A.M.B. mobile app
  24. jchav62
    jchav62
    It's 3/27 again! Happy Rev day... :) IMG_20140406_114643[1].jpg
  25. enloe
    enloe
    from east , tn.
    This was after we got it running we will be on the road in the next little bit.
    It had not been started and run for any length of time since 85 before this.
    1pickup, MO_JUNK, catdad49 and 5 others like this.
  26. Taboo56Chevy
    Taboo56Chevy
    The engine of choice in our garage, we have a few 327's powering our cars.
    The motor in Miss Taboo is a 66 327. Bored 30 over, full race isky cam (no clue on specs been in there for decades), camel hump 1.94's and topped with 6x2's
    The next 327 is my grandparents 55 Chevy. Its a 65 block, bored 30 over, forged pop up pistons, Comp Extreme Synergy cam, 1.6 roller rockers in stock 1.94 heads, topped with a fully chromed out tri power set up. This motor moves!
    Last 327 is the one powering my 68 Camaro as this is the original motor for the car. Its still a true 327, never bored and didnt need it when i had it out. Original crank, rods and pistons. Factory 2.02 camel humps, Z/28 30/30 cam, factory over the counter 69 Z/28 style aluminum intake with a correct looking Holley carb.
    All engines****embled and detailed in the garage, its one of my favorite things to do on a restoration.
    1pickup, MO_JUNK, LOWDUG37 and 8 others like this.
  27. Russco
    Russco
    from Central IL
    My .030 over ‘65 with 461 heads and a 471 blower.
  28. Both are 327 Turbo-Fire valve covers. The later ones have a deeper V. Funny they were throwaways when I was a kid now that I want some they are higher than a cats back. LOL
    I got a 327 that is a factory stroker. Does that count? :rolleyes:
    Stogy, tb33anda3rd, Deuces and 2 others like this.
  29. alfin32
    alfin32
    from Essex, Ma.
    .030" over, Schneider solid lifters, Fuelie heads, WCFB's, IMG_6002.JPG 2 1/2" Ram Horns.
    1pickup, rod1, wheeldog57 and 10 others like this.
  30. bowie
    bowie
    882B58A5-8247-4BAD-BCDE-2DCC185F3FE7.jpeg Not to pretty but she’s a 1967 HT code 350 horse version .
