Projects Original paint coupe
Discussion in 'Traditional Hot Rods' started by duncan, Jun 30, 2016.
  1. Elvis100
    Elvis100
  2. Body mounted to finalize metalwork
    Thor1, brEad, MR CLEAN and 5 others like this.
  3. dumprat
    dumprat
    from b.c.
    Looking good Ron!
  4. Thor1 likes this.
  5. Last edited: Mar 5, 2018
    Thor1, ss34coupe, brEad and 4 others like this.
  6. Nailhead A-V8
    Nailhead A-V8
    you made that look easy ;-)
  7. Thor1, chop job, dumprat and 2 others like this.
  8. Thor1 and brEad like this.
  9. MR CLEAN
    MR CLEAN
    duncan,
    Great Progress in your build, keep going!!!!
    MR CLEAN
    duncan likes this.
  10. Atwater Mike
    Atwater Mike
    Metal s***chery at its best. Thanks for having me along, Duncan...My '27 tub is less 'nervous' now...
    Thor1 and PhredH like this.
  11. Thor1 likes this.
  12. Thor1 likes this.
  13. Thor1 and ss34coupe like this.
  14. chop job
    chop job
    from Wisconsin
    You do very nice work. Very nice hot rod!
    duncan likes this.
  15. Thor1, brEad and ss34coupe like this.
  16. Thanks for the supportive comments.
  17. avachace
    avachace
  18. Back from Portland swap meet, time to get back at it.
  19. Suicide doors that fly open and hyper-extend are a real pain. I have 3 days into repairing the rt door rear edge, hinges and getting the door back to length and aligned. Photos of the procedure.
    Thor1, -Brent-, Runnin shine and 4 others like this.
  20. Johnboy34
    Johnboy34
    from Seattle,Wa
    Nice!
    Sent from my SM-G900V using The H.A.M.B. mobile app
  21. ss34coupe
    ss34coupe
    Looking good!
    duncan likes this.
  22. Elvis100
    Elvis100
    I had the same problem on my three window, the bent hinges that were a problem were on the door. I ended up drilling out the rivets and using the 20 ton to get them straightened out.
    Thor1 likes this.
  23. Rocky
    Rocky
    Classified Editor
    Love the transmission hump. I've been dreading that job for my 34.
    Thor1 likes this.
  24.
  25. You can do it. I used 18 gauge, but I think 20 g would be strong enough. Make a quicky wooden buck like in the photos and go from there, roll the piece to basic contour with a slip roll or over a gas bottle with 20g. go around the perimeter, defining the flange area with your smallest bead set, on a cheapo bead roller to start tipping it up and use your shinker/stretcher to work it the rest of the way. You'll need some heat for the tight corners. I'm not saying its easy, but with a little thought, as to which way you want to move the metal, it can be done. I got lucky and did it in one try, but if it screws up, start over. D
    rpm56 and brEad like this.
  26. Thor1, brEad, dumprat and 2 others like this.
  27. Thor1, redzula, brEad and 3 others like this.
