Hot Rods mark viii seats in 64 t-bird
Discussion in 'The Hokey Ass Message Board' started by sho1off, Dec 14, 2016.
  1. sho1off
    sho1off
    from Buffalo MN
    ok got it working
    add the orage wire to the diver seat with bl/w wires and evething work
  2. sho1off
    sho1off
    from Buffalo MN
  3. sho1off
    sho1off
    from Buffalo MN
    i am still promis whit my posts!!!!!!!
  4. Glad you got them working
    What's next on the list
  5. sho1off
    sho1off
    from Buffalo MN
    not so fast
    front and back dont work
    look for front seat posin swicth
  6. sho1off
    sho1off
    from Buffalo MN
    door shut
    door open
    seat occupied
  7. That's all stuff in the solid state module. It wants input from everything and wants to control everything.
    So far, I haven't been able to fool one of them into working
  8. sho1off
    sho1off
    from Buffalo MN
    got the p*** to work i have one wire left over bk/br
    + bl/w , bl/w , o , w/p , db/o
    - bk , bk , gv/r
  9. sho1off
    sho1off
    from Buffalo MN
  10. sho1off
    sho1off
    from Buffalo MN
  11. sho1off
    sho1off
    from Buffalo MN
    The time I have into them I could used p***ing side module off 94-96 w/o memory the p***in side works with the ****ons
    There's ****on on the bottom of the module to re set it I just learned wort a try.
  12. sho1off
    sho1off
    from Buffalo MN
    Or go for the relays setup
  13. sho1off
    sho1off
    from Buffalo MN
    ****on on it
    didnt work
    it the car with ever thing hookup clers memory but i dont have the car
  14. sho1off
    sho1off
    from Buffalo MN
  15. Like I said earlier, I've not yet been able to fool a seat module into working. As far as I'm concerned you have to go around the module and make the motors work the old fashioned way. Maybe someone else knows how but I do not. Also in the old fashioned way, the switches were complicated polarity reversing units and that's that it was all in the switch. In the new stuff the switches are just simple center off style so you need a complex relay to reverse the polarity.
    This is one way on how to control a DC motor that reverses.
    There are others as well but this is pretty easy to follow.
    Good for Windows and seats.
    You'll need 2 relays for each motor you wish to control by each switch.
    Where it gets tricky is when one of them seat switches has a position that controls 2 motors at the same time. Most of the time- if it's wired correctly for each switch then the switch will work the pair of relay automatically.
    In this drawing the switches are hot and provide power to the relay's pulling coil, that's ok as long as the wires for the switch are the same size as the wires for the motor. Most of the time I'll set them up so the switches provide the ground to the relay's pulling coil.
  16. sho1off
    sho1off
    from Buffalo MN
    i both one ebay for p***erg seat
    call me 763 283 1805
  17. sho1off
    sho1off
    from Buffalo MN
  18. sho1off
    sho1off
    from Buffalo MN
    got it working on the dirver side
    here how
    used p***ing seat memory mod with the cable to the seat ****ens
    F4LB14A699
    memory and cable for $25 on ebay
    bucaues its upside down the cables are short and you have to duck tape mod to hold it done
    does anbody no how to get spell check on the hamb
    i had a stock 7 years ago
  19. tstevenkennedy
    tstevenkennedy
    I'm trying to replicate this same scenario with these seats in a GM A body Buick. I tried calling the number in this link, but to no avail. I tried looking up the part number for the body side harness of the module, no luck. I'm looking for that plug to use to put power to modules on both sides and use seats. Memory harness, cheap on eBay. [​IMG]
    Sent from my SM-G955U using Tapatalk
  20. sho1off
    sho1off
    from Buffalo MN
  21. sho1off
    sho1off
    from Buffalo MN
    cabel you need it in the car
    junk yard well cut it out
  22. tstevenkennedy
    tstevenkennedy
    I got it. Now trying to find exact word to power up. I even got the memory switch.[​IMG][​IMG][​IMG]
  23. tstevenkennedy
    tstevenkennedy
    I went further back and read the comments. I now have the black with orange left over on p***enger side. But black w orange in driver's side goes to memory switch. Left over on driver's side is
    Red w/ purple, 2 white, grey w/ blue, black w/brown.
  24. sho1off
    sho1off
    from Buffalo MN
    pos and neg are the same in the posting for p***ing side
    look at post #39
  25. sho1off
    sho1off
    from Buffalo MN
    i didnt use memoy swich
    your on owe from there
