Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Blue One
    Blue One
    from Alberta
    Sorry Fred :) I like Houston but I think I’d have a hard time with the extra humidity over the Dallas area.
  2. Blues4U
    Blues4U
    from So Cal
    Are you sure you don't want to hang that exhaust with some straps to allow some movement?
  3. tfeverfred
    tfeverfred
    Lived here most of my life and I'm still not used to it. But I'm into roadsters. Go figure.
    Blue One likes this.
  4. Blue One
    Blue One
    from Alberta
    I’ve seen plenty of exhaust systems mounted the same way with the high temperature grommets that I used.
    There’s no room for things to swing around everything is pretty tight running the exhaust through the frame and tucked up like that.
    If I used straps it would be hitting things and rattling all the time :mad:
    My buddy did his T exhaust the same way over 20 years ago and it works fine and is still working.
    loudbang and Blues4U like this.
  5. Blue One
    Blue One
    from Alberta
    Similar to me here in Alberta where we have almost 6 months of winter (it seems like at times.)
    And here I am with motorcycles and a roadster :D
    Then I’d like to move to the rainy west coast o_O :)
    But I did have a top built for the roadster :cool:
  6. atch
    atch
    I think that in my next life I'm going to live in Alberta in the summer; Houston in the winter; and central Missouri spring and fall.
    ...now back to this exquisite build that I've been following since day one...
    brEad, loudbang, brad2v and 1 other person like this.
  7. crminal
    crminal
    Blue, it’s looking amazing! Detail, detail, detail.....
    loudbang and Blue One like this.
  8. Blue One
    Blue One
    from Alberta
    E-brake cables cut to length and connected adjusted and secured :cool:
    Rear tires can go back on and then I’ll start with the brake plumbing.
    0C7AC5E4-DF6F-4962-8408-F87E7A00A358.jpeg D6AADF5C-4889-4F47-9363-BEAA7B427A26.jpeg
    Stogy, loudbang, AndersF and 6 others like this.
  9. Blue One
    Blue One
    from Alberta
    Brake lines bent and installed from the master cylinder to the adjustable proportioning valve.
    Mounted with the small 3/16” made for you line clamps.
    It was quite a job figuring all that out :D
    Then I made frame brackets and installed the rear brake hoses.:cool:
    1975A0CA-49D2-447E-ACA0-1474F25AC740.jpeg FE58B7EE-C48B-4449-93A1-75A6B3925C56.jpeg C0D10B96-FE72-4B9F-92EE-E56C4A8AC297.jpeg 3275F390-9448-4F5E-9E34-CAA3BF9FAE28.jpeg 1530D131-3F49-4B28-8255-C941683D0385.jpeg 961B8FAF-67BB-4549-824C-8EF90EAC2074.jpeg
  10. tfeverfred
    tfeverfred
    Looks outstanding, Blue!:cool:
  11. Tim
    Tim
    from KCMO
    Dig those clamps
  12. 26 T Ford RPU
    26 T Ford RPU
    Very, very tidy, Larry. Are you the new Mr Fussy?:D:D JW
  13. DDDenny
    What Fred said!
  14. Blue One
    Blue One
    from Alberta
    :D I’ll admit I like things tidy and detailed.
    I guess it’s the tradesman in me and a lifetime of construction work where pride in your work at the end of the day meant something. :cool:
  15. Dick Stevens
    Dick Stevens
    Very nice indeed, the results are outstanding and show that it is worth the extra effort! :cool:
  16. 26 T Ford RPU
    26 T Ford RPU
    If you show you RPU you will need mirrors as you cant leave all that work hidden away.:cool::D JW
    brEad, Blue One and loudbang like this.
  17. loudbang
    Absolutely first rate work. :p
    Blue One and 26 T Ford RPU like this.
  18. GASSERBOB
    GASSERBOB
    from USA
    Beautiful ,beautiful work. Show winner there for sure Blue. Bob....................
  19. nutbush
    nutbush
    from Texas
    Great build and info. If I missed it I apologize but could you please post info on where you sourced your Marmans. Thanks!
  20. Blue One
    Blue One
    from Alberta
  21. bobbytnm
    bobbytnm
    Wow
    Your truck is a work of art.
    Things are really looking good!
    Bobby
  22. Blue One
    Blue One
    from Alberta
    I wanted to use a mechanical fuel pump on the Y Block so I went out and picked one up.
    Initially I had planned to mount an AC Delco fuel filter inside the frame rail underneath.
    Surprise, the fuel pump has a filter built into the bottom of it.
    Another surprise, it has the exact same threaded filter canister and uses the same filters.
    The canisters can apparently be a real ***** to remove once they have been in service, it seems that using a regular strap style filter wrench can collapse the canister, not good for something you don’t plan to replace.
    I did a little searching and since I couldn’t find the appropriate wrench I decided to make my own that fits nicely into the 3 small depressions
    in the bottom of the canister.
    Filter changes will be easy. :cool:
    DDC05051-3D89-473B-8F5D-9A3622CE94AB.jpeg 8B2C9225-EA00-4647-863F-13C381CC93A4.jpeg 83D1F770-A8AA-493F-B6A8-3A0BB5792EAA.jpeg 13B63ADB-1761-478E-A269-7DCD1E2A415A.jpeg 4ECC3BBD-4741-4512-AF65-2E3F5A00631E.jpeg FA170626-BE7F-49F0-8BF0-4B335523F262.jpeg
    Stogy, loudbang, brad2v and 8 others like this.
  23. Dick Stevens
    Dick Stevens
    Good job, looks like it will work well, just don't forget where you put it, I have a bad habit of doing that and can't find it when I need it. o_O
    loudbang, 57tailgater and Blue One like this.
  24. Blues4U
    Blues4U
    from So Cal
    Smear a bit of grease on that gasket before installing it, it will help you remove the filter later by preventing the gasket from sticking to the filter base.
  25. Tim_with_a_T
    Tim_with_a_T
    Where did you find that frame mount filter bracket? Me likey...
  26. Blue One
    Blue One
    from Alberta
  27. DesmoDog
    DesmoDog
    Fun fact about Marman joints. The company was started in the '30s by Zeppo Marx, of Marx Brothers fame. I've been working in the exhaust industry for 25+ years now and we use those for testing (emissions, flow benches, etc) but not so much in OEM applications. The off road equipment guys (Caterpillar, etc) use them I think?
    Anywhos, yeah, Zeppo Marx. The clamps are used for a lot more than holding exhaust systems together. The military used/uses them to secure cargo, including stuff like nuclear bombs. They're also used on spacecraft for things like holding the stages to rockets together (automatically releasing when needed)
    tomkelly88, brad2v, loudbang and 3 others like this.
  28. 41rodderz
    41rodderz
    from Oregon
    Love to see them coming back to life:)
  29. Blue One
    Blue One
    from Alberta
    I wanted to run my front brake lines through the frame and searched for a set of through the frame bulkhead fittings.
    Everything seemed to be equipped with #3 AN fittings on the brake hose end.
    I finally found a set from SSBC with 1/8” NPT thread on both ends so that I could use NPT to inverted flare fittings using my rubber brake hoses.
    I took my hoses to the local brake shop and had the female frame tab fittings cut off and some 3/8-24 male swivel ends crimped on.
    It all worked out nicely and now I’m ready to run the brake lines.
    CC001594-6FDA-4DC0-BDCB-BF369E18230E.jpeg EF502890-01D5-4633-BD47-5099691BA382.jpeg 43D0B405-13B0-4979-8B10-61816FFEA0EC.jpeg 01841DBE-7E6E-4961-98A5-A7CAC56E02AF.jpeg 5DFE2B6E-1241-454E-95EE-F9325412E7E5.jpeg 75706BC5-6EF9-4CEA-ABBA-571944E7FA30.jpeg
    brEad, OFT, brad2v and 6 others like this.
  30. tfeverfred
    tfeverfred
    I "liked" it, but I couldn't see beyond all that damn CHROME.:D
    26 T Ford RPU and Blue One like this.
