Hot Rods Travel tools for road trips
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Apr 1, 2018.
  1. Roothawg
    Roothawg
    I am planning a trip in May to the Hot Rod Hundred in Wisconsin and I am trying to put together the ultimate tool kit. I have limited space in the 35 pickup, so trying to maximize space. I don't wanna hafta haul tools into the hotel every night. I have a small box in the bed I plan on loading up.
    I am looking at one of the aluminum HF jacks, some of the bag jumper cables, foldable 4 way etc.
    Anyone know of a good tool kit in a case? I am searching Amazon, but it's hard to tell sometimes til you have it in your hands. What other invaluable tools do you carry? This trip will be close to 2,000 miles.
  2. Boneyard51
    Boneyard51
    I got one at Lowe’s self contained in a plastic box, saved my but many of times, take it every where with me. Bones
    Tri-power37, 49ratfink and Roothawg like this.
  3. Terrible80
    Terrible80
    I have one from Eastwood, like a small briefcase with end wrenches, ratchets, Allens and a multi tip screwdriver. Also Sears has them, different piece counts.
    Sent from my LG-TP450 using The H.A.M.B. mobile app
    Roothawg likes this.
  4. canning
    canning
    Duct tape, electrical tape and baling wire.
  5. Roothawg
    Roothawg
    That's how I built it....
    Clay Belt, TagMan, bubba55 and 4 others like this.
  6. Donuts & Peelouts
    Donuts & Peelouts
    from , CA
    ×2 on duct tape.
    Zip ties, every possible fluid like oil, coolant. A stop leak additive. A big hammer, a big flat head screw driver. Flash light, fuses. And a light that can be used like on a trailer if your head/tail lights fail.
    bobwop likes this.
  7. Beanscoot
    Beanscoot
    I will add a length of electrical wire, some fuel hose and filter, headlamp, and a breaker bar with correct socket to fit the wheel nuts.
  8. 40Standard
    40Standard
    from Indy
    all you really need is a AAA card, cell phone & your Fellow Pages
    trollst, Elcohaulic and Marcia like this.
  9. plym_46
    plym_46
    from central NY
    AAA card,cell phone!!! I carry a head gasket, a spare set up distributor, plugs, and fan belt. Small tool kit, fluids. Battery jumper pack basically to run my GPS.
    Clay Belt and Knghtcadi like this.
  10. cracker head
    cracker head
    I carry all the same basic wrenches, sockets,pliers I built the car with. Long hauls I carry one of those small piece of **** jacks that comes in a plastic case. Zip ties, bailing wire and duck tape for the rest of the **** that won’t tighten back up.
  11. pat59
    pat59
    Or go over the whole car beforehand to help eliminate any travel issues.
    squirrel, Jalopy Joker and Montana1 like this.
  12. AldeanFan
    AldeanFan
    Vicegrips, Big f’n Hammer, pry bar and zip ties
    Also think about any unusual or specialty tools you’d need for your car. I need a funny shaped wrench to change the condenser on my Y block so I carry it on the car.
    chop job and Donuts & Peelouts like this.
  13. Montana1
    Montana1
    I always say, "An ounce of prevention is worth a pound of cure." That being said just crawl around the truck and look at everything before you go.
    Make sure you have some extra fuses, a flashlight, a jug of water, some extra oil, a bottle of brake fluid, and take along any special tools you might need.
    For instance, I have allen head bolts on my shorty headers. I had to cut off an allen wrench to get in next to the outside pipes. It's in my tool box under the seat. Take some extra exhaust gaskets too and some RTV.
    They don't always break down next to NAPA, or O'reilly's!
    Enjoy the trip! :)
    Knghtcadi likes this.
  14. 41rodderz
    41rodderz
    from Oregon
    All the above ;)
  15. Side cutters,there's wire everywhere,test light and a length of electrical wire with alligator clips already fitted.
  16. gnichols
    gnichols
    from Tampa, FL
    There are a few other, older threads on this. Gary
  17. Roothawg
    Roothawg
  18. AldeanFan
    AldeanFan
    I carry this socket set in each of my cars, bought on sale 70% off.
    Takes up very little room and is probably more sockets than I would need on the side of the road
  19. bobwop
    bobwop
    from Arley, AL
    don't forget a fire extinguisher.
    I hope we can meet. I am not sure about participating in the event, but it is on the calendar.
    I am very close to the starting point, so don't be bashful if I can be of any ***istance.
    chop job and Roothawg like this.
  20. sevenhills1952
    sevenhills1952
    A bottle Jack and a bottle of Jack.
    Actually if you run a thermostat I like to drill three 3/8" holes in it so even if it sticks coolant still flows. Stupid to mention but when checking tire pressure check the spare. A Delco one wire alternator is good, easy to connect one wire to battery +. Try it at home garage first, you may need to fabricate a bracket. V belt (s).
    Like mentioned I like those big plastic boxes and some things like 4 way lug wrench I drilled holes in top and zip tied to lid. Saves space. Get one of those cheap Swiss Army knives that has everything even pliers.
    Sent from my SM-S320VL using Tapatalk
  21. squirrel
    do you have 4 different size lug nuts on your truck?
    If space is at a premium, only bring what you might use.
    pat59 and guthriesmith like this.
  22. sevenhills1952
    sevenhills1952
    I forgot to mention an electric fuel pump, fuel hose and clamps. And buy or make a long clip lead wire with alligator clip ends. If you have space an 8"x8x12"(or so) wood block can be handy.
    patmanta likes this.
  23. Boneyard51
    Boneyard51
    Roothawg, take it from another “ Okie” head to Lowe’s and get that $100 or so tool kit. It’s anout 3 inches thick and will lay in the floor of your pickup , won’t kill you if someone steals it, readily replaceable. I’ve had mine for two years, won’t leave the house without it. Like I said , saved my **** many times. Bones
    Edit : if you get it ,add a 7/16 wrench, I guess it was designed my foreigners, because they omitted that wrench. Bones
  24. HOTRODPRIMER
    HOTRODPRIMER
    Maybe it's just me but regardless of what I packed in the way of tools I never have exactly what I need at the time.
    For years,I never even carried a screwdriver and was fortunate I didn't need it,but I was traveling with friends that obsessed with caring too many tools and parts and had I need anything they had it.
    I now care a small box of tools and after last years flat on the all Deuce Run I now carry a tire plugging kit and a small compressor that plugs into a power take off. HRP
    Normant93 and Roothawg like this.
  25. Roothawg
    Roothawg
    I tend to fly by the seat of my pants. My wife is the planner in the family. I am trying to change my evil ways, but I admit it.
    Hi everyone, My name is Root and I am not a planner......
    NashRodMan and Normant93 like this.
  26. TagMan
    TagMan
    Doesn't matter what tools you take with you - the tool you need, won't be there !
  27. Bandit Billy
    Bandit Billy
    If I'm headed to the middle of no where I always bring my Glock. If I'm taking a stroll in the middle of the night I'm not doing it unarmed. It gets tucked in the ditty bag with the small battery jump box, one of those travel socket kits/screw drivers in a zippered pouch I got from a snap on rep as a present years ago, a couple of LED flashlights, my electrical multi tester, tape, zip ties, duct tape, air gauge, distributor wrench, a Bible, a copy of Crosby, Stills Nash and Young's Deja vu and the number for a good attorney.
  28. DDDenny
    What, no "Freebird"!:eek:
  29. Blues4U
    Blues4U
    from So Cal
    Here's a tip if you're ever traveling south to CA, pull the magazine out of the gun (and make sure there is no cartridge in chamber), and store both the gun and the mag in the bag, just put a small luggage lock on it, and you'll be legal (should you ever be searched). CA gun laws require the gun to be unloaded and in a locked container, but "container" is not specified, and a zippered pouch with a luggage lock has been accepted as compliant in court. Also, it's OK that both the mag and the gun are together in the same compartment, you just can't have the mag in the guy. It's not likely that you would ever be searched, but you never know, and this way you would be in compliance.
    Sorry to the admin's, I don't mean to spin this thread off topic, and I hope it doesn't devolve into a bunch of gun discussion, I just wanted to help out anybody who travels to this state with a firearm to prevent unwanted visits to our jails and our court systems.
  30. Roothawg
    Roothawg
    It doesn't matter where I go, I'm armed.
    Fordor Ron and Clay Belt like this.
