Hot Rods Wanted: Ideas on how to recess or set back firewall in '64 Comet
Discussion in 'The Hokey Ass Message Board' started by fairlaniac, Apr 5, 2018.
  1. fairlaniac
    fairlaniac
    from Denver, PA
    I'm looking at pushing back my firewall in my '64 Comet about 2-3 inches. I've never done this and I'm not afraid to try it either. I'm also thinking of smoothing it. So I'm thinking of making a pattern and cut it from a sheet but that is all the further my thought process goes. Do I keep a flange on the perimeter and weld it in? Do I cut the existing short of the factory firewall flange and try to **** weld or lap weld it in place? Are there any threads showing some good practices?
    Thank you in advance.
    Doug
  2. mgtstumpy
    mgtstumpy
    Why do you need the recess, stuffing in an FE? Personally I prefer to **** weld things together rather than overlap; it's more work but do it once, do it right. This is a recent HAMB thread where a reversed Model A (30) was used in a 57 Chevy g***er to facilitate with engine set back. Not for the feint hearted as there is a fair amount of work involved, however it achieves / exceeds what others would do.[​IMG]
  3. NewGuyOldFord
    NewGuyOldFord
    My prostreet 64 falcon was moved back about that much. They cut the firewall right where the section behind the hood starts to go down under the hood and made a flat sheet metal firewall. Keep in mind it will all but eliminate the cowl channel for the fresh air to enter the heater, wipers don't really have much room and shortening the pedal hanger is going to be needed. May not be a concern of yours but just giving you the heads up. Mine is set up for a motor plated 460 and c4. Also, it really screwed up the hood hinge area the way they did it. Not a big deal if you are going to run a "pin on" hood. BART.
  4. NewGuyOldFord
    NewGuyOldFord
  5. fairlaniac
    fairlaniac
    from Denver, PA
    Yes, a 427FE is going in. I like **** welds but you know the issue. A lot of work. Thank you for the info.
  6. fairlaniac
    fairlaniac
    from Denver, PA
    Very cool, thank you. I'm thinking of cutting under the cowl and move it back, not affecting the wipers, heater, etc... I'm thinking a flat panel or recessed like a box. Just getting ideas. Any closer pics of your front end minus fender aprons? I have a MII steering.[​IMG]
  7. NewGuyOldFord
    NewGuyOldFord
    Mine was done by a ch***is shop outside Maple Grove years ago. The previous owner was in over his head after getting the bill for the frame, cage, stretching wheel openings, strange 9 inch with ladder bars and coils and the front rack and pinion steering that is based off the mustang II. The car is getting a 393 Windsor, G-Force 5 speed and a Detroit Locker with 5.25 gears for the street. It has 29.5X19X15(If I remember correctly) tires on the back. I see you're not too far from Hershey. Isn't Denver by Cocalico/Anville area? I also have a 66 fairlane GT that my parents bought in 1967. Needs a complete makeover though.
  8. NewGuyOldFord
    NewGuyOldFord
    I'll try to dig up some more pictures for you.
  9. DDDenny
  10. NewGuyOldFord
    NewGuyOldFord
  11. Unkl Ian
    Unkl Ian
    Wheelbarrow tub.
  12. mrconcdid
    mrconcdid
    from Florida
    You can recess the original firewall or make a complete new box. I made this one in two pieces, also keep in mind you will have to modify the trans tunnel. Its not very fancy, but worked just fine.
    MrC.
    fairlaniac likes this.
  13. fairlaniac
    fairlaniac
    from Denver, PA
    Yes, I'm in the Cocalico school district Denver/Reinholds. have you picked up your G-Force yet? I'd like to get one but they are not cheap. I too have a 1966 Fairlane.[​IMG]
  14. NewGuyOldFord
    NewGuyOldFord
    Mine is done and sitting in my garage. My friends machine shop in Newport did the gear blanks for them so they gave him a good deal on a kit and he p***ed it on to me. They definitely aren't cheap.
  15. Hollywood-East
    Hollywood-East
  16. NewGuyOldFord
    NewGuyOldFord
    Fairlaniac, I got the more street friendly version of the G-Force. They make two different ones. Straight cut gears or a street version. They claim I can still use the clutch to pull out and then shift without the clutch after and that downshifting will take a little getting used to. I also got their carbon fiber ***embly kit and all new G-Force synchros and blocking rings. It was over $3,000 but not what I paid through my friend. I've never had oil in mine yet. The tubbed and caged falcon was put on the back burner to try to get some other projects further along.
  17. chopped
    chopped
    Or a split gas tank
  18. sunbeam
    sunbeam
    One of the first comet setbacks
  19. Weedburner
    Weedburner
    from Wa State
    Here's a link to an OT car I built that has 10" of setback... http://grannys.tripod.com/20102.html
    I basically removed the firewall and tunnel in one piece, trimmed some off the back, and re-installed. The car still has all of it's original firewall, but the center portion has been moved back to the base of the windshield. If you need a donor car for a larger tunnel, Mazda RX-7's are great donors as they were originally rotary powered, so their equivalent to a crankshaft is way up in the middle of their engine. This requires their transmission to sit a lot higher than the typical piston powered car, which translates to a huge transmission tunnel like in the link above. A T56 6spd will even fit in an RX-7's stock tunnel.
