Projects The Kidney Killer
Discussion in 'The Hokey Ass Message Board' started by 31Ford_RPU, Nov 18, 2017.
  1. 31Ford_RPU
    31Ford_RPU
    Been building bikes for a while so I decided since I had a new Speedway T Bucket body sitting in the garage, it was time to switch gears and build a bucket
    Plan is to use the body I have, 28' - 29' Model A grill, SBC, Ford 8" rear end on a homebuilt 2x3 frame
    Chucky, chryslerfan55, slim38 and 3 others like this.
  2. brady1929
    brady1929
  3. Chucky
    Chucky
    Worthy of a bump.
  4. That XS is killer
  5. mad mikey
    mad mikey
    Get to building, and keep us posted. You have some nice parts , and the bike is really cool.
  6. butch27
    butch27
    You're going to have fun--Check <tbucketeer.com.>
  7. 31Ford_RPU
    31Ford_RPU
    Haven't posted an update due to slow progress. Picked up a 25' Buick grill and started the chop.. 8" down and 2" narrow in the bottom. Need to get a pic with the bottom back on. Also picked up a 66' Buick 300, 16x4 steelies, Firestone dirt tracks, and a shortened bed
    29258031_1840644272655149_6254339635657310208_n.jpg 29339444_1840644159321827_6573087493908856832_n.jpg
  8. captainjunk#2
    captainjunk#2
    cool build i have an old buick grill shell like that to , i think it looks nicer than a T shell , it still has the enamel buick badge also
  9. captain scarlet
    captain scarlet
    from Detroit
    Great start. The grille looks great.
  10. Unkl Ian
    Unkl Ian
    NICE grill.
  11. 31Ford_RPU
    31Ford_RPU
    Posies front spring finally arrived, spindles and hubs mounted, front tires touched down today for the first time full mounted. Wonderful wife held up one headlight to get a look at headlight mounts DSCN5853.JPG DSCN5850.JPG
    Deuces, GASSERBOB and rust&patina like this.
  12. 41rodderz
    41rodderz
    from Oregon
    You have a great helper:) I really like the grille. Dig it when someone uses different parts from the norm. Gives it a unique yet cool character:cool:
  13. GASSERBOB
    GASSERBOB
    from USA
    Looking good . Keep us updated. Bob...............
  14. fiftyv8
    fiftyv8
    from CO & WA
    So the tie rod is going to run above the top of the ch***is rails???
  15. 31Ford_RPU
    31Ford_RPU
    The tie rods will actually run under the frame I just havent bent the factory arms down yet for clearance
  16. 31Ford_RPU
    31Ford_RPU
    Both headlight mounts are made just need to be blended. Also cut the bed down a few more inches and contoured it to fit the body and am starting the Ford 8" axle brackets
  17. That's what I call hot rodding.
    Keep up the good work.
