Did they ever make a stainless steel droped I-beam axle?????? The reason I ask I got an old axle and4 link kit with a frame everything was stainless steel . Axle is hard, when grinding through off yellow-orange sparks. But is magent. My drill bits won't drill it like most axle.I can drill 17X1" holes in most axle with 1 bit this thing 1 bit does 1 hole if lucky.
The Deuce Factory produced a stainless I beam with filled ends for a number of years. They offered it plain or polished with or without holes. I have them under my deuce 3 window, deuce delivery and deuce 5 window. When they closed So-Cal sold them for a while but their cost got prohibitive and they stopped making them. The magnetism is due to the type of stainless used to make the axle. I have a new stainless refrigerator but you can still use magnets on the door for the grand kids pictures.
The ends are not filled it also polish like stainless. It was a very fuff finish. And had a1/2wide parting line. I thought it was cast but does not work like cast
That sure looks like a forged axle and as krylon mentioned there are grades of stainless that are magnetic. The 400 series grades fall into that category and they are heat treatable. - EM
Don't use ***anium coated drill bits on stainless they get too hot and you'll smoke them- find some good machinists drill bits
If it has a 1/2" parting line, its most likely forged. Think of the parting line on a crankshaft, wide is forged, narrow/sharp; cast.
It was at least1/2" wide the axle is new.well20-30 years ago new .. I did final get all 17 -1" holes drilled And got the black on next red in resess.
True if you were going to paint it I bet someone would have swapped you an already drilled one plus beer for a stainless one
Shinny does not fit this project.it is being built on the cheep and would look strang with just 1 polished or chrome part on it. If I ever need it for something that needs a shinny axle I will swap it out.
It’s a same it’s not showing off as a beautiful piece,it’s a fine looking axle but it is his after all aye. Who are we to say what a bloke should do with his own gear.
