Anyone here into large scale (1/8) car models???
Discussion in 'The Antiquated' started by Deuces, Dec 10, 2010.
  1. BIG-JIM
    BIG-JIM
    from CT
    This is a 1/8th scale truck cab I'm working on. It's loosely based on a 32 ford truck.
  2. BIG-JIM
    BIG-JIM
    from CT
    20170916_185040~2.jpg 20170916_185023~2.jpg 20170916_185003~2.jpg 20170916_185055~2.jpg
    I'm also working on a 33/34 ford roadster. Has a ways to go though.
    Deuces, Bandit Billy, timwhit and 3 others like this.
  3. Deuces
    Deuces
    Nice work Jim....:)
    BIG-JIM likes this.
  4. BIG-JIM
    BIG-JIM
    from CT
    Deuces, I have a bunch of bodies in the works. So far the 33 coupe, 32 pickup, 47 pickup, and the 32 three window are done. As well as a bunch of American graffiti parts, bobbed rear fenders, chopped grill, eight gauge dash, valve covers, rear bumper/Nerf bar, 47 Chevy tail lights man-a-fre manifold, frogmouth air scoops, and I'm working on the headers and reverse steelies. Im also currently having a 32&33 Vicki designed with a 34 Chevy coupe on the way. Other bodies include 32 Tudor, 28-29 Tudor a 34 Tudor and the 33 roadster. And believe it or not there is some talk of a Henry J. God I'm tired just typing all that. Stay tuned.
    Deuces, kiwijeff, 41 coupe and 3 others like this.
  5. BIG-JIM
    BIG-JIM
    from CT
    Some more pictures. Also working on a cowl steering box.
    Deuces, Jigger, kiwijeff and 4 others like this.
  6. BIG-JIM
    BIG-JIM
    from CT
    I'll also be adding a cowl Schroeder steering box and vintage fluid shock absorbers to my list of things I cast.
  7. Deuces
    Deuces
    Lotz of kool stuff there Jim.....o_O;):)
    rodncustomdreams likes this.
  8. BIG-JIM
    BIG-JIM
    from CT
    I try man! Its nice to have choices.
    Deuces likes this.
  9. Spex84
    Spex84
    from Canada
    Big Jim, that is some seriously impressive stuff!
    Was just visiting this thread because I've been working on a 3D model of a '30 coupe body to put up on Shapeways in 1/8 and 1/16 scale:
    Deuces, Jigger, BIG-JIM and 7 others like this.
  10. Mojo
    Mojo
    Beautiful body shell. What program do you like to use? Is it from scanned data, or did you draw it from pictures?
    Deuces likes this.
  11. elroy
    elroy
    please tell me the truck cab is going into production. where do I send my money!!!!!!!!
    Deuces likes this.
  12. Deuces
    Deuces
    Bump to the top.....;):)
  13. jim32
    jim32
    I am still hopping for some to make a '32 5 window body available.
    Deuces and rodncustomdreams like this.
  14. topher5150
    topher5150
    Is that chopped. I've always wanted to an unchopped model a coupe on the big deuce frame with the Flathead
    Sent from my XT1254 using The H.A.M.B. mobile app
  15. gnichols
    gnichols
    from Tampa, FL
    I WANT ONE!!! PLEASE!!! Gary
    Deuces likes this.
  16. gnichols
    gnichols
    from Tampa, FL
    When can I get one (or more). Ever consider it's 28-29 little brother? Gary
    Deuces likes this.
  17. Spex84
    Spex84
    from Canada
    Thanks fellas!
    Mojo--the '30 is modeled from scratch, based on photo reference and some dimensions pulled from diagrams and a Monogram '30 coupe model in 1/24 scale. Lots of photo reference, as both the diagrams and the Monogram model are not 100% accurate! The old, original version was modeled in 3D max, but now I'm learning Zbrush for future projects.
    Topher5150--it's un-chopped. I plan to do a chopped version as well.
    The '30 coupe is currently available on Shapeways HERE
    Unlike with styrene or resin bodies, a certain amount of bodywork will be needed to clean up the fine deposition lines from the 3D printing process.
    An example of the work that goes into cleaning up a 3D printed body in the "white, flexible" material from Shapeways can be seen here (basically, it needs a skim coat of filler and a bunch of sanding): http://www.modelcarsmag.com/forums/topic/123408-18-tdr-nova/
  18. gnichols
    gnichols
    from Tampa, FL
    Sorry bud, that's nearly 300 bucks more that I'd expect to pay for a body. Good luck. Gary
  19. Spex84
    Spex84
    from Canada
    You and me both Gary!
    I'm hoping that with time, printing costs will drop, or I'll develop the means to produce them in resin...even so, they'd probably end up being over a hundred bucks each just to cover materials and time.
    If you're looking for a '29 roadster at all, "Matthews Foundry" does one in resin. Looks like he starts with a hand-sculpted clay master. Looks like the website isn't complete yet, but some a couple of his bodies are up on Ebay, looks like they're in the $150 range https://matthewsfoundry.com/
    Deuces, BIG-JIM and rodncustomdreams like this.
  20. Mojo
    Mojo
    Spex84 - I hadn't considered Z Brush, i'll look into it. I had been trying to learn a cad program (SpaceClaim), but had considered trying Rhino3D, because it has really great 3d printing support. I have almost no experience with3d modeling, so if I'm going in, I want to find a program that does what I'm looking for.
    Shapeways is pretty expensive, but with printers you're paying for the technology. Here's an interesting video showing the difference between a cheap and expensive print. The technology and design of the printer is directly responsible for the quality of the print.
  21. Mojo
    Mojo
    We're still at the beginning of being able print model cars and parts. It's going to open up a lot of interesting possibilities and problems. It's possible to do a scan of a part or car, clean up that scan and rework it for printing, then print it out in the scale you want at the quality you want. Lots of work to get it to happen, but it's obtainable.
    One other interesting possibility is printing out rigid multi-piece molds for resin casting. They would need some finishing, but with a rigid mold, you can be sure the parts will come out with no warping. It would be the best of both worlds, a strong, correct mold, and the ability to cast a bunch of parts cheaply.
    The problems are with legalities. A lot like it is with the resin casting industry. It's possible to pull a car from a video game, and modify it for printing. But if you sell copies, who is owed money? GM, or the company that scanned the model and created it as a file? Or both? It's going to be interesting.
    Attached is a screenshot of a 55 Chevy 150 from the game Forza Motorsport 7 as an example.
  22. BIG-JIM
    BIG-JIM
    from CT
    Yes it's in production along with many others. Shoot me an email. CHEBY33@GMAIL.COM
    Deuces likes this.
  23. edcodesign
    edcodesign
    image.jpeg image.jpeg Jim, Here is the one I traded for, l built it last year.
    Jigger, 41 coupe, BIG-JIM and 3 others like this.
  24. BIG-JIM
    BIG-JIM
    from CT
    Deuces and edcodesign like this.
  25. BIG-JIM
    BIG-JIM
    from CT
    Did you ever do anything with this body?
    Deuces likes this.
  26. Mojo
    Mojo
    I didn't, no. I sold it on ebay late last year to a gentleman who built an incredible "tether car" type model with it. Comp Coupe - Red 003.jpg Comp Coupe - Red 005.jpg
    rodncustomdreams, gnichols and Deuces like this.
  27. BIG-JIM
    BIG-JIM
    from CT
    That came out nice. Thanks forgetting back to me.
    Deuces likes this.
  28. Deuces
    Deuces
  29. Deuces and rodncustomdreams like this.
  30. 2NDCHANCE
    2NDCHANCE
    I know where there is an ***embled "Big Deuce" kit sitting in a ba*****t....price is right...free. Are they worth grabbing in "already ***embled...mostly there form? Maybe just some minor re-gluing needed. Gary
    Deuces likes this.
