Technical "The Perfect Valve Lathe"
Discussion in 'The Hokey Ass Message Board' started by rustydusty, Apr 8, 2018.
  1. rustydusty
    rustydusty
    I was reading "Squirrels" thread on "old school" valve resurfacing, and remembered this tool I acquired from my Dads collection when he p***ed.
    Has anybody ever seen one? It's called: "The Perfect Valve Lathe", Pat'd May 11 1920... 0408181239.jpg
    302GMC and chryslerfan55 like this.
  2. tb33anda3rd
    tb33anda3rd
    what spins the valve?
  3. squirrel
    probably a separate portable drill?
  4. rustydusty
    rustydusty
    That's what I would ***ume...
    The thing is, where the valve clamps in the tool, would damage the stem if you spun it.
  5. s55mercury66
    s55mercury66
    from SW Wyoming
    Maybe an electric motor and a belt, with a pulley, adapter and collets on the valve end?
  6. Texas Webb
    Texas Webb
    Looks to be all hand operated.Is there a stone the handle spins?
  7. 270ci
    270ci
    I'm guessing there may have been a sleeve that you insert the valvestem into and clamp that into the fixture.
    There's an adjustable stop for the valve face, but there would have to also be a way to keep the valve from creeping in other direction and changing your cut depth.
    Cool piece, none the less. Interesting to see some of the earlier tools.
    Thanks for posting that up.
  8. Budget36
    Budget36
    looks to me like the handle adjusts to the valve size ,the bolt on the left adjusts where the valve sets, the bolt on the right holds the valve in place. I think it should have a little hand crank that would clamp on the valve stem to rotate it.
    I've a miniature version of that. I'll go and dig it out and post a pic.
  9. continentaljohn
    continentaljohn
    Old school image.jpg Valve job machines
    Dean Lowe and squirrel like this.
  10. 270ci
    270ci
    I'm thinking it took a little old school knack to get nice results.
  11. continentaljohn
    continentaljohn
    The front screw put the pressure against the carbide cutting block and the other screw put a light load on the valve stem. You can cut the valve by hand if you want but cordless drill works faster:D
  12. squirrel
    there you go....
    Thanks for the pics of all these neat old tools! gets me thinking
  13. Deuces
    Deuces
    I love it....:)
  14. rustydusty
    rustydusty
    I now see that I am missing a couple of parts. Thanks for posting that picture.
