Technical Show Us Your Fabricated Parts
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Mar 29, 2018.
  1. 18n57
    18n57
    Fabricated this Hilborn-style injection set-up for my FED. Bought stacks and butterflies, built the rest. Ran great...haven’t seen the dragster in years, may be in Denver area. [​IMG][​IMG]
  2. Dave Mc
    Dave Mc
    I made wood patterns for the interior of my 33 C400 for the B pillars , above the doors and Sail panel with recess for interior lamps , then hammered aluminum over the wood , removed the wood and covered everything with leather , lined the door panels and behind rear seat with aluminum as well , also shaped aluminum over the interior rear wheel wells and made an access door to the trunk area, all covered with Leather
    33vicIn-2.jpg 33vicIn-3.jpg 33vicIn-4.jpg 33vicIn-6.jpg 33vicIn-b.jpg 33vicIn-a.jpg IMG_0345.JPG JelliPups5179 022.jpg
    brEad, chop job, loudbang and 6 others like this.
  3. atch
    atch
    Kudos; well done amigo.
    chop job, loudbang and Dave Mc like this.
  4. bobbytnm
    bobbytnm
  5. jailbar joe
    jailbar joe
    made the tray.the panel beneath the tray...the ford script is pressed into the panel...altered the chassis that much that you may as well say it is homemade
    that front panel started out as a flat sheet of tin...the headlight surrounds.the nerf bar
    the extractors and the whole exhaust sytem,mudgaurds and brackets,tray tilt system....4 inch chop and 4 inch channel
    not much on the car that is not home made
    Lepus, alanp561, pat59 and 2 others like this.
  6. Johnny99
    Johnny99
    More Willys junk,
    Jean pocket on door panel for registration, insurance card, and time slips, what a combo! Doo hickey on back of seat attaches to roll cage shoulder bar.
    Hackerbilt and loudbang like this.
  7. manyolcars
    manyolcars
    I made this bracket from a piece of angle iron. Cut a little piece off, turned it and welded it back on
  8. manyolcars
    manyolcars
    Henrys Model A coupe trunk floor was a serious compromise so he could have a rumble seat but it wasted a lot of room. I use my car as a daily driver and wanted all the space I could get so I designed and installed a dropped floor. The rumble seat was changed to a trunk. The before paint picture shows the 'spotwelds' made with 1/8" 6011 welding rod droppedfloornopaint.jpg droppedfloor.jpg
    chop job, Dave Mc, Hackerbilt and 3 others like this.
  9. Hackerbilt
    Hackerbilt
    A few other things...
    Side pipe hangers from Chevy truck lever shock arms. I guess thats repurposing more than fabricating...but I still had to make it all work and look correct.
    Rad shroud using a junkyard electric fan. Stopped the overheating issue right in its tracks!
    U joint cover to go between box and firewall. Seals everything up nice and tight.
    Roll bar from a sliced & diced Land Cruiser bar...some flanges and a piece of 2x3 tube.
    Brushed finish aluminum firewall from a repurposed old road sign. (and yes...the ugly ribbed plastic is now off the throttle cable! LoL)
    alanp561, RMR&C and fauj like this.
  10. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
  11. Marty Strode
    Marty Strode
  12. 31Apickup
    31Apickup
    Manyolcars, what did you do with the end of the trunk drain troughs so that they don't dump water into your new trunk floor?
    Donut Dave likes this.
  13. Fitnessguy
    Fitnessguy
    This is what I did for the gutter drains. Once the original panels are all in place this is all closed off and unseen.
    Hackerbilt likes this.
  14. This is a start of a lot of fabing started with2x4x3/16 tubing to cheep to buy a frame
  15. I built this grille for my '34 Plymouth. Bars are 1/4" solid steel. Yes it's heavy.
  16. Larry Anderson
    Larry Anderson
    RMR&C and loudbang like this.
  17. alanp561
    alanp561
    That's beautiful. I want to do the same to a '40 Oliver tractor grille shell but with stainless tube.
    loudbang and RMR&C like this.
  18. hotrod428
    hotrod428
    Here are some of the many parts I fabricated for this track T I built a couple years ago.
    IMG_20150928_140202368_HDR.jpg P4190023.JPG P9130018.JPG P9150021.JPG P4190019.JPG P1010114.JPG
  19. nunattax
    nunattax
    whats the teeny motor
  20. Paul
    Paul
    Editor
    looks like a Crosley
  21. lostone
    lostone
    from kansas
    Figured I'd go ahead and post pics of my model A frame. Scratch built from 2x4" tube, rear xmember scratch built from 2x3 tube.
    loudbang, Hackerbilt and RMR&C like this.
  22. Sheet Metal Intake for my XO/PP Bonneville Project Ford 271 CU IN ford six IMG_3091.JPG IMG_3102.JPG IMG_3104.JPG IMG_3108.JPG IMG_3109.JPG IMG_3113.JPG
  23. Rambling Rudy
    Rambling Rudy
    Made air cleaners and battery cover, these were on my 57 Pontiac 12514086_1061721490514706_4377148524439152932_o.jpg
  24. neilswheels
    neilswheels
    from England
    A lot of cool fab on here. I've been making headers for my 348. Drivers side and passenger side, tri y equal-ish length. Drivers side had to miss the steering box which was a massive pain, a lot more room on the passenger side, but still a lot of bendy bits
    brEad and saltflats like this.
  25. My guess is that tubular control arms, regardless if they are MII or not, fall in that area (which often seems murky)of being too modern. Nice work by the way.
    31Vicky with a hemi and fiftyv8 like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    I'm not bitter or bitching, I just want to get it.[/QUOTE]
    absolutely off topic. here is the section of the rules that covers that. I thought you had read it.
    5. As mentioned throughout these guidelines, the H.A.M.B. focuses on TRADITIONAL hot rods and customs. Posts pertaining to traditionally inspired, but not quite period perfect belong on the main forum found here. Please note that we don't focus on things such as modern fuel injected motors, big-inch wheels, frame clips, after market independent suspensions, etc... at all on the H.A.M.B.. As such, posts that stray away from the "traditional inspired" will be deleted.
  27. fiftyv8
    fiftyv8
    from CO & WA
    I hope my comments are not the kiss of death for your post, but I like it and it should be respected taking into account the thread title and the effort put into the product produced.
    In saying that there is also an old time independent rear thread running which in some cases could have exactly the same looking materials just fabricated in a different age and manner.
    5. As mentioned throughout these guidelines, the H.A.M.B. focuses on TRADITIONAL hot rods and customs. Posts pertaining to traditionally inspired, but not quite period perfect belong on the main forum found here. Please note that we don't focus on things such as modern fuel injected motors, big-inch wheels, frame clips, after market independent suspensions, etc... at all on the H.A.M.B.. As such, posts that stray away from the "traditional inspired" will be deleted.[/QUOTE]
    Thanks @Moriarity,
    Of course I read it,
    I thought it would be ok here because it's not a frame clip or "after market" and fabricated by my hands to my design. My bad.
    Moriarity likes this.
  28. spurgeonforge
    spurgeonforge
  29. saltflats
    saltflats
    from Missouri
    Choke cable bracket and lever.
    TagMan, prewarcars4me and brEad like this.
