Technical 3 x 2 carb setup plumbing question?
Discussion in 'The Hokey Ass Message Board' started by jswilke, Apr 6, 2018.
  1. jswilke
    jswilke
    Offenhauser 3 x 2 manifold with 3 Rochester 2G carbs. Center carb has large port on base where my power brake vacuum hose is connected. Vacuum advance hose is connected to center carb ported vacuum source. I want to add PCV system...where is the best place to source PCV valve vacuum?
    There is an additional unused small 1/8" threaded vacuum port on rear of manifold. Is that sufficient for PCV plumbing...seems too small. Is it a bad idea to T the center carb base vacuum port to share it for both power brakes and added PCV vacuum?
  2. Good timing I am wrapping up a build of a 3x2 rochester setup on an Edelbrock intake.
    You want to use manifold vacuum for your distributor advance, Many carbs have the PCV / power brake teed in with the distributor advance and or transmission modulator. DSCN2795.JPG DSCN2796.JPG DSCN2797.JPG
  3. BJR
    BJR
    Use the 1/8" threaded vacuum port on rear of manifold for the distributor advance. T the pcv and brake booster off the center carb. The booster only uses vacuum when you step on the brake pedal, so it should be fine with the pcv.
  4. jswilke
    jswilke
    Thanks for the input. Sounds like "T"ing the center carb base port is the way to go to feed PS booster and PCV.
    Donut Dave and loudbang like this.
  5. theHIGHLANDER
    theHIGHLANDER
    If you Tee the power brake off the PCV it's like there's a vac leak to the booster. Don't ask how I know, it was maddening (!), but you want an independent source for power brake vacuum.
    Johnny Gee, shawnsauto1 and loudbang like this.
  6. jswilke
    jswilke
    Next question...who to trust to rebuild my 3 Rochester 2G carbs? I've read many disturbing posts regarding Charlie Price and ****ster...some are really old posts. Where does a guy go today to get honest good service?
  7. 28rpu
    28rpu
  8. theHIGHLANDER
    theHIGHLANDER
    Unless you're looking for restoration/replating it can be a DIY experience. Not nearly as intimidating as it 1st seems. About a 2-3hr job as a beginner, 1/2 that once you find your groove.
  9. Kan Kustom
    Kan Kustom
  10. jswilke
    jswilke
    I'm up to rebuilding myself. Sounds like Hotrodcarbs is a good source for kits and other parts.
  11. Atwater Mike
    Atwater Mike
    My wife read a page on the Rochester 2G, same evening rebuilt 4 of them for a customer's '41 Ford p/u, SBC 327, Man-A-Fre. She installed them, set up linkage, started it and adjusted to perfect idle.
    No backfire on accel, ran smooth as silk.
    She does have a background in Webers & Zeniths, however...Porsche...
  12. wuga
    wuga
    I just rebuilt three Rochester singles for my 235 on a Offy manifold. Got the kits from Mikes. http://www.carburetor-parts.com/ Good quality, great pricing and super fast delivery.
    Warren
