Projects Painting intake silver
Discussion in 'Traditional Hot Rods' started by 46international, Apr 16, 2018.
  1. I'm going to pull the intake off of my Y block so I can replace the choke heater tube and was thinking about painting it silver before reinstalling it. Thing is, I would like to brighten up the car a little, the car is dark maroon with a black frame and engine without a lot of chrome. Anyone out there done this? any pictures? I just don't want to look like a hack that wants an aluminum manifold but too cheap to buy one.
    HOTRODPRIMER and loudbang like this.
    Hollywood-East likes this.
  3. Jalopy Joker
    Jalopy Joker
    heat, leaks, exposure to weather, etc will quickly discolor silver paint
    46international and HOTRODPRIMER like this.
  4. have you thought about powder coating it? maybe ceramic coat to match your headers?
  5. I have painted intakes with success. I haven’t painted one silver though
    I blast them clean and prep like painting a car. I use an epoxy sealer with automotive grade paint.
    I wouldn’t recommend spary can silver
  6. HOTRODPRIMER
    HOTRODPRIMER
    I'm afraid if you paint it silver your going to get the "I wanted a aluminum intake but was too cheap to buy one" look. HRP
    kadillackid, blowby, squirrel and 2 others like this.
  7. I use VHT brand Cast Coat Aluminum. Has held up well for me, + if it gets a fuel stain or whatever, just touch it up with a quick spritz !!!
  8. well I would use heat paint just like what's on the exhaust. but I think HRP put this one to rest.
    HOTRODPRIMER likes this.
  9. Hollywood-East
    Hollywood-East
    What HRP said ∆. Good looking ride, I'd be more concerned with cleaner... Now a vintage caddy cleaner ( or period) , Boom.. Daddy's home! IM(not so)HO
  10. Deuces
    Deuces
    Chevy Orange would look pretty cool..... :cool::D:cool:
  11. LM14
    LM14
    from Iowa
    This one is aluminum but I had it powdercoated silver for easier maintenance. Well worth it.
    SPark
    46international and Deuces like this.
  12. I like the amount and quality of the bling you (the O.P.) have in your photo. A dark color cast iron intake makes a nice counterpoint to the brightwork.
    46international and blowby like this.
  13. HOTRODPRIMER
    HOTRODPRIMER
    You do have a good looking car. HRP
    46international likes this.
  14. squirrel
    Think about sending the intake to the chrome shop, to get it smoothed and chrome plated.
    That would be the right way to do it.
  15. justpassinthru
    justpassinthru
    Krylon makes a color called Dull Aluminum.
    We use it a lot for brackets, bolts etc. and on exhaust. It will not burn off of header collector pipes.
    It also does not look like cheesy aluminum screen door silver and wont come off on your hands.
    Bill
  16. evintho
    evintho
  17. XXL__
    XXL__
  18. DDDenny
    Just one guys opinion.....yuck.
    I say the same thing every time I see a silver painted transmission case.
    46international and Bandit Billy like this.
  19. Hollywood-East
    Hollywood-East
    Now you said that, red rear end cover, an axle lights come to mind... Not that there's Anything wrong with that..
  20. This is the good stuff... another vote for it. Cheap silver paint will look like hell in no time.
  21. inliner54
    inliner54
    I’d have it ceramic coated. Low maintenance, easy to clean, gas oil and brake fluid won’t harm the finish.
  22. Bandit Billy
    Bandit Billy
    Why not just put an aluminum manifold on it? Tumble it or polish it, call it done. It's a cool car, she deserves a present.
  23. Engine man
    Engine man
    from Wisconsin
    Don't worry about what anyone else thinks. Do what you want to.
    46international and INVISIBLEKID like this.
  24. Dooley
    Dooley
    from Buffalo NY
    20180306_131639.jpg Painted my aluminum one with the cast look paint from Duplicolor
    OT manifold
  25. DDDenny
    Now that looks great, I did something similar on my master cylinder.
    This is Rustoleum, I believe they have other shades also.
    The metallic is vey fine and not shiny like in this photo, that was from the camera flash.
    46international, Dooley and upspirate like this.
  26. jimmy six
    jimmy six
    The exhaust cross over needs special care. When you have the manifold off you can get the inside coated too. Make sure to use and the "truck" gaskets which have smaller openings and a metal seal.
  27. NWRacing
    NWRacing
    Cast Blast is the sister product to Aluma Blast it gives a raw cast iron grey look and is tough as nails. It may be enough to set it off without the cheesy Alumilike look
  28. The issue I have with 'Cast Blast' is it contains iron as a pigment and that can rust....
  29. NWRacing
    NWRacing
    I have an entire engine I painted with it 7 years ago that still looks good. My only issue has been around the exhaust ports, it will rust/burn off but I just touch it up every year or so. Intake has never had any issues
  30. It got exposed to moisture here in the NW. Rusted on my daily-driver, also rusted on a motor while stored on an engine stand in my garage. Don't get me wrong, it's great paint (all SEM paints are) but it will do this.
