Projects 1936 Ford custom build
Discussion in 'Traditional Customs' started by Youngster51, Apr 16, 2018.
  1. Youngster51
    Youngster51
    from Fresno ca.
    This will be my first build thread any ideas or thoughts are appreciated. I picked up this 1936 Ford custom about 6 months ago looks to be an old Carson top style car as all work done on car is brazed with some lead still remaining. Some time in its life a lot of the lead was melted out and got a heavy layer of bondo. The rear fenders are molded and scalloped flush mount skirts tapered running boards heavy chop and 37 ford headlights sunk in front fenders. First picture is of when I picked it up and added caps and installed skirts. Since then I pulled the sbc and t5 out installed some bracing fixed some patch areas switched frames installed a 8ba flathead with a 350 auto and sanded the bondo out of the body line. Currently working on the driver side windshield post making it look more like a cabriolet still needs a lot of work. Ill upadate it more as work goes. Thanks
    rodncustomdreams and Special Ed like this.
  2. chaddilac
    chaddilac
    Pics please!!!
  3. Youngster51
    Youngster51
    from Fresno ca.
  4. Youngster51
    Youngster51
    from Fresno ca.
  5. stanlow69
    stanlow69
    What ever you do, don't change the stance.
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    Neat car. I like your direction. Please keep us updated as you go.
  8. 0nedon
    0nedon
    Looks like much-O fun. Good luck with it.
  9. chaddilac
    chaddilac
    Wow!!! Very cool!!
  10. Youngster51
    Youngster51
    from Fresno ca.
    I am going to open up the window channel again and install roll up windows with the help of my friend who is in his 80’s he has built many hot rods and customs he brought over stainless window channel pieces from 60’s ford t birds and mustangs and made a template from an original cabriolet window frame to piece together for the 36
  11. Youngster51
    Youngster51
    from Fresno ca.
  12. brady1929
    brady1929
  13. lakepipes
    lakepipes
    from australia
    Nice car, can you post some ch***is shots seeing it’s alread out from under the car?
  14. 40FORDPU
    40FORDPU
    Thanks for posting..looking forward to your progress.
  15. Neat.. those 37 lights look right for that car.
  16. Youngster51
    Youngster51
    from Fresno ca.
  17. Youngster51
    Youngster51
    from Fresno ca.
    Here’s some pictures of when I was getting the new ch***is ready before I put it under the 36 still have to shorten the drive line
  18. Youngster51
    Youngster51
    from Fresno ca.
    08E610EB-88CE-471F-BCA1-7773749A2F40.jpeg Here’s a picture of the old ch***is nothing wrong with it just a got a good deal on the other frame came out of a running driving 36 sedan that the guy had switched to a tci frame I cleaned it up installed the flathead with 350 trans using a wilcap adapter and put it under my car I have some extra 36 sheetmetal that I want to put together into a 3 window coupe I’m going to put on this frame after I finish this car
    Surf City likes this.
  19. straykatkustoms
    straykatkustoms
    Very Kool, thank you for keeping us updated.
  20. okndnx
    okndnx
    from Porum, OK
    That is a great looking car
    Youngster51 likes this.
  21. lakepipes
    lakepipes
    from australia
    Thanks for the ch***is pics, I was interested to see how your rear was lowered. Those are big *** blocks
  22. love the progress so far dude! great to see something being done with the body of the car!
  23. Itchy-Pit
    Itchy-Pit
    Would be interested in the front fenders if you are not going to re-use
  24. roger didonato
    roger didonato
    Absolutly beautiful start I'm building a 36 ute coupe from Australia There are pics some where but I'll post more.
