Hot Rods Aftermarket Floor Shift Options for a Turbo 400
Discussion in 'The Hokey Ass Message Board' started by kbuhagiar, Apr 17, 2018.
  1. kbuhagiar
    kbuhagiar
    Hello Folks,
    I'm in the process of changing floor shifters in my 56 Chevy, and I'm considering a Lokar cable-control unit. I like to bang the gears on the Turbo 400 every now and then and I am wondering if that's possible with the Lokar. I know it's not a ratchet shifter, but I was hoping there was some sort of positive stop (detent?) from first to second, and then second to drive, that would keep me from pushing the lever, say, from first all the way to drive.
    Can anybody with experience with these shifters provide this info?
    Thanks in advance.
  2. David Gersic
    David Gersic
    from DeKalb, IL
    There are stops, but that’s not what they’re intended for...
    razoo lew likes this.
  3. 49ratfink
    49ratfink
    you need a stick shift to bang gears.
  4. slowmotion
    slowmotion
    The turbo 400 I had, put it in drive, mat it, and it'd bang gears better'n I could dream of. :eek:
    egads likes this.
  5. DDDenny
    Never thought I'd read bang'n gears and Lokar shifter in the same sentence!
  6. Get yerself a Gennie shifter. I think it'll hold up better for that. Mine has for me.
    sidevalve8ba likes this.
  7. DDDenny
    Full manual valve body and a B&M series 60 shifter on my turbo 400.
  8. low down A
    low down A
    impossible to bang gears in a automatic. you move the gear selector and the tranny shifts
  9. mediumriser
    mediumriser
    from Ohio
    YOU BEAT ME TO IT. Hahahaha
    LilBlue82 and 49ratfink like this.
  10. uncleandy 65
    uncleandy 65
    I have a turbo 400 and a Lokar shifter and this is the last combo you want for bangin gears.
    egads, 49ratfink and flynbrian48 like this.
  11. flynbrian48
    flynbrian48
    And never, ever, EVER trust the neutral safety switch in one. Talk about banging gears...
    egads, 49ratfink and zzford like this.
  12. badvolvo
    badvolvo
    Not with my lokar, looks good but does not locate the gears well.
    Hurst quarter stick in my OT ride bangs the gears with a pg and manual valve body.
  13. 392
    392
    I'm sure you were serious but it is funny.
  14. How do you bang gears in an automatic? I have an OT vehicle that will pull the front tires but has a 3500 RPM stall convertor, reworked internals, and manual valve body and can't bang gears like my OT manual 6 Speed car.
  15. kbuhagiar
    kbuhagiar
    Jesus H Christ, y'all know what I mean...manual shifting of the gears.
    THIS would be my first choice, if they still made them.
  16. bangngears
    bangngears
    from ofallon mo
    Stick shift cars are driven, automatics are steered:p
  17. Ebbsspeed
    Ebbsspeed
    We weren't sure if YOU knew what you meant. And just to make sure........
    ........."banging gears" and "automatic transmissions" are mutually exclusive.
    :rolleyes:
    LilBlue82 likes this.
  18. squirrel
    With a manual, you'd be bangin' synchros, right? not gears?
    With a slushbox, you're bangin' clutches.
    Anyways, no, a street rod shifter is not a racing shifter. Get a racing shifter if you want to do the racing thing.
    what shifter did you have before the change?
    Johnny Gee and zzford like this.
  19. low down A
    low down A
    I can only assume that you mean what you say.
  20. i have a Lokar shifter in my `30 coupe with 283/th350.....sometimes i will hold it in 2nd past it's normal shift point as i get on it and then slip it up to 3rd
    is that considered banging gears?
  21. bangngears
    bangngears
    from ofallon mo
    Stickshift cars are driven, automatics are steered:p
  22. Gman0046
    Gman0046
    Banging gears with a 400TH doesn't compute.
    49ratfink likes this.
  23. squirrel
    nope, it's more like tappin' gears
  24. 49ratfink
    49ratfink
    if I still had my high school GTO I'd take you for a ride and show you what banging gears is. actually pulled the T handle off the shift lever one time going into second gear, grabbed the stub and went for 3rd. :)
  25. egads
    egads
  26. kbuhagiar
    kbuhagiar
    Wow, tough crowd...:D
    B&M Hammer Shifter, and I'm definitely not a fan. It's a fricken rattle trap. Are all ratchet shifters this bad?
    Then again I've only had the car a couple of months, and its my first auto trans floor shifter. Just looking for something that would allow for 'spirited' driving. In the past I've driven buddies' cars that had Hurst Dual-Gates and AutoStick 1, loved those, but can't find'em anymore.
    rmorris and Luke stone like this.
  27. doyoulikesleds
    doyoulikesleds
    only played with one lokar and that was enough to cure me
  28. LM14
    LM14
    from Iowa
    Had a Lokar on my '57 F100, it as "mushy" at best. Detents in tranny were more precise than shifter was. Had a B&M Star Shifter in an OT car years ago. That thing you can hit as hard as you want and it just goes one gear at a time. Very positive on the stops. Full ratchet shifter or common shifter in the same unit. Would do another if the car was right.
    SPark
  29. kbuhagiar
    kbuhagiar
    The responses here pretty much echo everything else I've heard about the Lokar, so that's out.
    Since they seem to be the only other alternative I am looking again at other ratchet shifters, specifically the B&M Quicksilver and the Hurst Pro-Matic 2. I've seen the Quicksilver in another ride, looks OK but I've never driven one. I like the Hurst because... it looks like a Hurst, never seen one in person.
    This would be so much easier if they still made the AutoStick. :cool:
  30. wvenfield
    wvenfield
    Find one. I found one at a garage sale awhile back. (sorry, sold it)
