Projects 1955 Chevy Southeast Gassers Build
Discussion in 'Traditional Hot Rods' started by Zak Hall, Oct 29, 2017.
  1. 6sally6
    6sally6
    Since I never built a g***er I just "don't know".......so I'll axe What function does the heim joint play(connected to the motor mount position) when you already have motor plates positioning the engine?!
    Sorta like wearing a belt AND suspenders?!!!
    "I got's to know man....I got's to know."
    6sally6
  2. Zak Hall
    Zak Hall
    The rod with the hiems doesn’t hold it side to side, or from twisting. The front plate and mid plate hold it. The only thing is where they are flat plates they allow the engine to spring forward and backwards. The hiem rod just prevents that movement.
  3. Zak Hall
    Zak Hall
    0C333CD7-65D8-4A63-9905-65BAFD66EB96.png Here’s a better explaination from S&W
  4. 6sally6
    6sally6
    interesting!
    Never thought of that. IF the engine plates were STEEL....would that stop the front/back movement?
    6sally6 Learn'in every day!
    Bowtie Coupe and loudbang like this.
  5. Zak Hall
    Zak Hall
    Actually the mid plate is steel. The steel plates are actually thinner than the aluminum plates to keep them at a comparable weight, so they still spring. You’d need like a 3/16 steel plate and that would weigh a ton. Lol
    Bowtie Coupe, powrshftr and loudbang like this.
  6. Zak Hall
    Zak Hall
    60309ACE-2E25-4792-A605-132474F3CF87.jpeg DADE89FA-639E-46C6-BF03-3EFEDECAEA09.jpeg BF36FE48-0E83-41A2-8966-60EA5ECD01E6.jpeg ACA8409B-47FD-4505-AB39-4C9BB5F5DCDC.jpeg 4148BEA3-E050-495C-B535-3B16E3C9F43F.jpeg 33C452CD-264F-4CB1-82BB-8C97E7878FEF.jpeg 62B37996-6C36-44D8-92EC-3113BA0841EC.jpeg 54751CCE-9875-486D-BAE6-596643290257.jpeg Got the wheel tubs made and installed. Now we can get to work on the quarters.
    catdad49, AHotRod, Floater03 and 5 others like this.
  7. Jimbo17
    Jimbo17
    Building a g***er is never an easy project but you are doing an excellent job!
    Jimbo
  8. wick22
    wick22
    hey zak what kinda front shocks do yall like to run on the straight axles?
    loudbang and Bowtie Coupe like this.
  9. Zak Hall
    Zak Hall
    Any kind of front shock in a 90/10 or 70/30. This one has speedway 90/10 shocks, my 57 has Lakewood shocks.
  10. Zak Hall
    Zak Hall
    A182204C-1D25-433D-BAB5-76340A7F7E3B.jpeg 101A23C0-34F1-4834-9BDA-6E0890063984.jpeg 0ADFE960-D56E-48FB-8EF0-8561A3CE4F55.jpeg 2D34E782-6357-4447-8755-9DA338002814.jpeg 12198060-1551-45B9-AA07-E8DD8BA9620D.jpeg 896B3FCE-746F-436C-9120-4F6B0B160FBB.jpeg 1395BA8F-F81A-49B1-86FA-5A1ED439F9F4.jpeg 8F8A109F-2F5F-42B6-9121-C25E24BE0B43.jpeg Bodywork and waiting on parts has slowed us down some but we’re staying after it persistently. Got one door hung and fitted properly, and both quarter patches put in. Quarters came out good for our first time doing them.
  11. Higgy's Henry
    Higgy's Henry
    Keep up the good work boys!!!
    loudbang and Zak Hall like this.
  12. Zak Hall
    Zak Hall
    7051F834-17C8-48B5-89E7-C4878C2CCE1A.jpeg CDC25821-A812-4E0E-A54E-37C36DA35150.jpeg Starting to look like a 55!
  13. Zak Hall
    Zak Hall
    2B6FEAF3-30A3-4767-AC9D-1AE5BC2ECD4D.jpeg E9A193FD-2276-49F0-9182-5C789590CF69.jpeg 4CC0A671-CE66-4872-BE82-D11F43689F1D.jpeg 9F7802D5-F837-4905-8D30-C96954F42D97.jpeg Got the tilt kit bent up and gl***ed in. Gonna work on tilting it tonight.
  14. 6sally6
    6sally6
    [/ATTACH] . Got one door hung and fitted properly, and both quarter patches put in. Quarters came out good for our first time doing them.[/QUOTE]
    Door looks "well-hung"!!
    Keep up the good work....
    6sally6
    loudbang, Zak Hall and Bowtie Coupe like this.
  15. Zak Hall
    Zak Hall
    241512FE-3373-48AC-9819-CC6DEB2B991A.jpeg 827BDD86-5634-42FB-98CA-781173A137C6.jpeg B8490DB0-21F6-47A6-B312-F81367D4C964.jpeg 167163D9-E472-423C-B06C-DC702D13E44C.jpeg 71C26509-4684-44F7-99B4-3F01176FAD38.jpeg 68ACA048-6E7F-42A6-8A6C-08E35A455FDB.jpeg AD967030-0157-4449-9A4D-25BC71BE2623.jpeg B33A647D-3736-42A7-B5E0-C7DB37334891.jpeg 80B56FBA-BA43-4D80-A57A-6FC230F1C69A.jpeg Got the fender flare/lips done. It’s starting to get “the look”.
  16. loudbang
    DANG you guys are moving right along. :)
    enloe, Bowtie Coupe and Zak Hall like this.
  17. COCONUTS
    COCONUTS
    Man, these cars do have a lot of work completed on them to make them race worthy, much more now than the old days of B-Gas (maybe I was just lazy back then). I wonder why they don't have a cl*** for altered wheelbase vehicles? Well keep up the good work and I guess you build these cars for the future pounding they are subject to.
    Bowtie Coupe, loudbang and Zak Hall like this.
  18. DDDenny
    I'm gonna say it's probably because Quain already has his hands full with the gas cl***.
  19. Zak Hall
    Zak Hall
    They do have two AFX/altered WB cars that run exhibition between rounds, and Quain is open to others joining in with them, as long as they’re 4 speed and meet the SEGA visual rules. They’re allowed to run on alcohol in afx too. BE4B0E4C-AB62-4957-BF09-CB32059B0064.jpeg
  20. Zak Hall
    Zak Hall
    6DE05D1B-0978-414F-8038-7AE6E25F27E7.jpeg B625BE8E-9096-486C-880F-D97248AD5B90.jpeg 0870F8A5-DE91-4F5E-AC47-E6727EA9D51D.jpeg E00026B9-E40C-4B8F-AB6E-2F582D42E6B2.jpeg A15051D3-F9CF-46EA-9F23-C469C8DD1BAA.jpeg 213CC40C-FCF0-4DC5-9FE4-76B3F23CA9D5.jpeg 8E7DFE74-1D8E-46C9-B316-52A1FFED3235.jpeg 365F95CD-A678-4F39-982E-29A420B84B6D.jpeg Well it’s left our garage for the first time since we started on it. Got it over to our friend and fellow Southeast G***ers racer Kelvin Cannons garage so we can get the body work done and get the metal in sealer primer so we can start sticking it together. The more I look at this car the more I believe that dads 55 is gonna be killer.
  21. Doctorterry
    Doctorterry
    What!? I didn't know you guys let altered wheel base cars run! Man... I really need to put a 4 speed in mine
  22. southcross2631
    southcross2631
    Good luck in Knoxville this weekend. Will be there cheering for you.
    Zak Hall likes this.
  23. 6sally6
    6sally6
    WOW!!!!!!!!!!!!!!! Hubie and Houston tribute carz!!!!!
    Now I KNOW I gotta go see the SEGA here in Myrtle Beach!!!!!!!!!!!
    Sure dates me though!!! I saw both of these guys the first-time-around!!(In the real deal!)
    6sally6
  24. 6sally6
    6sally6
    Does that fellow in the orange T-shirt realize he has a jack stand sticking outta his fanny?!! (Check the second picture!!)
    ( ; ........ jus fool'in!!
    6sally6
    brEad and Zak Hall like this.
  25. Zak Hall
    Zak Hall
    Haha that’s dad! He was holding it so when we rolled the car up on the trailer we could scotch it.
    catdad49 and Bowtie Coupe like this.
  26. enloe
    enloe
    from east , tn.
    You don’t have to hunt a place to sit if you have a if you have a jackstand hanging out of your ***
    -Brent-, brEad, catdad49 and 4 others like this.
  27. Fogger
    Fogger
    I built my '55 G***er over 50 years ago from an East LA wrecking yard find. It's been covered here on the HAMB. Tube axle with Willy's spindles, '57 Olds/Pontiac rear, always a 4-speed and both a small block and a 427 big block. Ran 11.21 at 121mph with a carbureted 327 small block and a best of 10.80s at 129 with the big block. Last race for me was the '67 Winter Nationals in B/Gas. During the tech inspection my wheelbase was 2" too long because I had built the car to run brackets. I should have just raced in the altered cl*** but we moved the axle back to maintain the stock wheelbase. I sold the car after the Winter Nationals and lost track of who owned it. I've been told that it was restored as a stock '55 and all the suspension, rollbar, etc was removed. It would have made a perfect nostalgia g***er for the current Southern G***er events. To create the flair on the rear quarters I brazed copper tubing to the opening and used bondo for the flair. Your project is coming along great and will be a fun ride. Good luck with the completion. IMG_3534.jpg
  28. 56sedandelivery
    56sedandelivery
    ^^^^^Beautiful car; seen several pics of "White Lightning" here on the HAMB and elsewhere ^^^^^. Nothing looks better on a Tri-Five Chevrolet than white paint and Cragar S/S rims. I am Butch/56sedandelivery.
  29. chevy57dude
    chevy57dude
    The Cragar S/S wheel was made for Tri 5s, IMHO
  30. DDDenny
    It sure is nice to be surrounded by like minded people!
