Event Coverage Welcome to the 2018 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 12, 2017.
  1. rocketsled59
    rocketsled59
    Late night Sabotage throttle stop!!' And the ford wins!!!!!
  2. rocketsled59
    rocketsled59
  3. bonlesshotdog25
    bonlesshotdog25
    Just something nice and bright for u too fallow back to the pits lol
    Tickety Boo, Gammz, saltflats and 2 others like this.
  4. rocketsled59
    rocketsled59
  5. rocketsled59
    rocketsled59
    There's strength in numbers. Us shitbox ford guys gotta stick together. We sneak around and give the Chevy boys sbf firing orders during the night. That ain't cheating either. That's making things fair!!
  6. SLCK64
    SLCK64
    Aren’t those orange triangles for slow moving “field cars”?
  7. Gammz
    Gammz
    from Lincoln Ne
    Probably one of the best ones I’ve heard yet!!! I like this kid already!!
    loudbang, rocketsled59, enloe and 2 others like this.
  8. Tickety Boo
    Tickety Boo
    from Wisconsin
    I better recheck that throttle stop and maybe borrow my buddy's enclosed trailer.:p
    There was a rumor going around that the ghost of Grumpy Jenkins is with us and he was last seen standing by the Lakeshore Shaker holding a .010 hammer right before the shims fell out. :oops:
  9. saltflats
    saltflats
    from Missouri
    The last time I seen Da Grump he was getting in a Ford rental car. :eek:
    I didn't have the hart to take a picture of that. ;)
  10. Tickety Boo
    Tickety Boo
    from Wisconsin
    Wonder if he got a rash? :eek:
  11. Gammz
    Gammz
    from Lincoln Ne
    Yeah. A rash of hot chicks wanting to bear his children. That’s been my experience anyway. Lol
  12. saltflats
    saltflats
    from Missouri
    I just spent 6 hours getting the valve geometry sorted out on Nathan's FE last night.
    I now have a little more respect for you ford guys....... unless you guys are just throwing the parts on.
  13. rocketsled59
    rocketsled59
    Yeah. I’ll just take a sohc 427. I’ll deal with 9’ of chain and no pushrods!
  14. saltflats
    saltflats
    from Missouri
    Nathan thinks he need one of those also so he can complete his set.
    521 inch Boss......check
    467 inch tunnel wedge FE......check
    427 SOHC...............
  15. powrshftr
    powrshftr
    That is the best comeback I’ve heard in forever!
    My hat is off to you,Brother![emoji16]
    Scott
    loudbang, enloe, rocketsled59 and 3 others like this.
  16. rocketsled59
    rocketsled59
    That’s a nice list. My list sucks It is just broken shit I need to get around to fixing.
  17. SLCK64
    SLCK64
    Ehhhh idk about that....not sure if that was tongue in cheek or.....I suppose like anything there is just a learning curve with the cam timing
    “So what is the SOHC? Essentially, it’s a two-valve, single-overhead-cam conversion of Ford’s 427ci FE V8. The heads were predominantly cast-iron (though later aluminum heads were available) with a roller chain cam-drive—a 6-foot-long timing chain. The choice of chaindrive over a geardrive setup decreased development time and costs, but increased timing variables from the chain’s habit of stretching under load. This resulted in the need to vary the cam timing from one side of the engine to the other to take up the chain slack. With the chain rotating in one direction, the cams also rotate in the same direction, resulting in one cam rotating toward the intake follower and the other away from the follower. To fix this, each bank requires a unique camshaft, with one a mirror of the other, so opening and closing ramps are correctly located.”
    http://www.hotrod.com/articles/90-day-wonder-sohc-427-cammer/
  18. saltflats
    saltflats
    from Missouri
    I tell you it's a wonder that after 6 hours of checking and measuring then degeeing that at the 4th hour we didn't have a bunch of broke shit.
    Nathan is learning patience and a few car things along the way.
    Sad thing the car is one year to new for the Meltdown but he can run the Victory NSS with me.
    The truth is the body work is the stuff that is killin us.
  19. rocketsled59
    rocketsled59
    It sucks... bad.
  20. makes me glad I have a hemi. Shaft mounted rockers make it easy. To degree it set the engine on tdc. set the lifters at split overlap. set the intake .020 higher than the exhaust and you should be right there. only two more days until the the hemis birthday. Fords and chevies stay off the street.
  21. The cams also
    Need to be degreed differently because of chain "whip"
    chryslerfan55 and powrshftr like this.
  22. SLCK64
    SLCK64
    I suppose Kaase may have helped solve any of the inherent issues with the SOHC. Anyone got $50,000.00 USD I can have?
    http://jonkaaseracingengines.com/shop/engines/kaase-sohc-engines/
    Lol would be great in the Comet and would really put some extra oomph in the ‘revenge’ side of “Halley’s Revenge”! (That’s what I named my ‘64 Comet)
  23. They do make a gear drive for the sohc. Lots of gears in that gear drive. Makes a cool sound.
    SLCK64 and saltflats like this.
  24. powrshftr
    powrshftr
    So my oldest Boy came out tonight to help get some stuff done on the car,and we got the column yanked out,disassembled and pulled that monstrosity of a pedal assembly (nightmare,would recommend it to nobody),knocked the old bushings out,cut the core support to give more room when pulling the engine/trans,and spent a bunch of time with a really awesome kid that I don’t get to see nearly enough due to a busy work schedule for me,and a busy social life for him.
    He also had some photos of some weld testing he’s doing at school,and I’m pretty impressed with how far he’s progressed.
  25. wrenchbender
    wrenchbender
    Why have one of those ford things when you can have this for way less by the way do the headers make my engine look small lmao
  26. powrshftr
    powrshftr
    Daaaaaaaaaaaayuuuum..!!!
    Jackson finally went and done it!
    Say hello to Mr Hemisphere....!!!!
    chryslerfan55 and saltflats like this.
  27. SLCK64
    SLCK64
    Ugh.....well the ol Ford 429 is superior to the actual Hemi. But such as life, the finer things cost a bit more amount of dollars.
  28. wrenchbender
    wrenchbender
    But us poor people have poor ways lol we have to drive those cheap ol willys powered by cheap ol dodge power plants lmao yeah I had to step up I blew up the expensive chevy last week this is the only junk I had laying in the dirt floor of the barn so it will have to do for now
  29. ahhh no. i will let the record book decide that one. time for some mopar trash talk on the eve of the hemis birthday. coming at ya with all eight barrels of cross ram trash talk wide open.
  30. wrenchbender
    wrenchbender
    So Brian are we gonna hear that nitro burning coupe of yours run on its birthday tomorrow I was hoping to hear mine run tomorrow evening but I don't think I'm gonna get things all finished up
