Projects Something from nothing. 29 roadster build
Discussion in 'Traditional Hot Rods' started by wheeldog57, Oct 8, 2016.
  1. mike bowling
    mike bowling
    Property values just dropped in THAT neighborhood! Invasion of the hot rods! (Lol)
  2. sloppy jalopies
    sloppy jalopies
    ronny with a roof... go wd 57 go !
    wheeldog57 likes this.
  3. wheeldog57
    wheeldog57
    The trunk was too wide at the bottom, I hated to do it but I ripped it and ripped it. Now it fits the hole 1524837893850.jpg
    Sent from my E6810 using The H.A.M.B. mobile app
  4. wheeldog57
    wheeldog57
  5. wheeldog57
    wheeldog57
  6. wheeldog57
    wheeldog57
  7. biggeorge
    biggeorge
    nunattax and Robert J. Palmer like this.
  8. nunattax
    nunattax
    what petrol tank are u using
    Stogy and chryslerfan55 like this.
  9. wheeldog57
    wheeldog57
    Stogy, chryslerfan55 and OFT like this.
  10. wheeldog57
    wheeldog57
    I felt the deck skin was going to need a ton of fabrication to make it work.
    The decklid that was on the car is f-ed too but less so. But it has hinges, inner skin, and it was already fitted.
  11. wheeldog57
    wheeldog57
    She's a bit wavy but . . .
  12. mike bowling
    mike bowling
    How soon are we having a garage add on party?? lol
    You're in tall cotton Brother! ( quote from Uncle Rick Camera 2-20-09 124.jpg y)
  13. biggeorge
    biggeorge
    You meant shapely right. She has all the right curves.
    Stogy, chryslerfan55 and wheeldog57 like this.
  14. wheeldog57
    wheeldog57
    Stogy likes this.
  15. wheeldog57
    wheeldog57
    I checked off a couple items on my list. Mounted up my now 12 volt generator KIMG0300.JPG
  16. wheeldog57
    wheeldog57
    Replaced the cable from solenoid to starter and moved the ballast resistor, put on the 97 carb and topped it off with one of Jere Sheehan's air cleaners KIMG0309.JPG
  17. wheeldog57
    wheeldog57
  18. greaser
    greaser
    Looking good Ron. Those guys in Jersey are all starting to feel your heat.
    Sorry I didn't get to meet up with you in Fitchburg this year, as I intended. Perhaps I'll see you in Epping, or at another event.
    Dennis
  19. sloppy jalopies
    sloppy jalopies
    Stopped to check out a '30 coupe 8 miles from home... previous owner set up a spring loaded belcrank to convert an under dash push pull knob to vertical motion... he ran a push ****on equipped solenoid upside down... when he pulls the knob the shaft pushes down on the ****on, starting his A... pretty cool...
  20. wheeldog57
    wheeldog57
    I had my brother wire up an ignition switch and a starter ****on. It feels like a racecar when I start it. Pretty cool
  21. wheeldog57
    wheeldog57
    Got an email from Flash,
    I need to cut out of work early and "number up" my car for the TROG race card. Going to be a busy afternoon. I will send pictures when I'm done.
  22. wheeldog57
    wheeldog57
    I had 3x on the car from last year. So I had to sand it off, and re brush the quarter. Then free-handed the new number. My wife's birthday KIMG0339.JPG KIMG0334.JPG
  23. wheeldog57
    wheeldog57
    tb33anda3rd, Stogy, Texas36 and 10 others like this.
  24. mike bowling
    mike bowling
    Nice job on the lettering, Pic***o!
    327 is a good luck number!
  25. onekoolkat1950
    onekoolkat1950
  26. sloppy jalopies
    sloppy jalopies
    ready to ROLL ! ... go wd57 go !
  27. greaser
    greaser
    Great job. You could be a sign painter.
    Many uninformed at the ROG will think your running a small block. HA!
  28. mike bowling
    mike bowling
    Ronnie DOES run a 327- in his '57! with tri-power and a 4 speed no less. ANOTHER car he saved from disappearing into the ground.
    Dust and Rust, turned DSCN3631.JPG into a BEAUTY.
    Stogy, chryslerfan55, brEad and 5 others like this.
  29. wheeldog57
    wheeldog57
    I am planning to put shocks on the roadster, I found these at the NED swap meet. I want to mount them on the cross member and attach to the top of the rear axle. KIMG0368.JPG
  30. wheeldog57
    wheeldog57
    Does anyone know what kind of shocks theses are
