Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Tim
    Tim
    from KCMO
    Awesome! I’ve really been thinking about buying one of those for a while
    loudbang and Blue One like this.
  2. flt-blk
    flt-blk
    from IL
    lines are looking great. I borrowed my buddy's Eastwood flare tool when I re-did a set of Dunlop Brake calipers with the transfer tubes, lots of flaring. I liked it so much I had to get my own. The next best brake tool was the pressure bleeder I made with a bug sprayer bottle. one man show to bleed them.
    Keep up the good work.
  3. Blue One
    Blue One
    from Alberta
    The brake line from the drivers side frame through bulkhead fitting to the p***enger side across the rear of the front crossmember gave me fits :D
    It was tough but it turned out well.
    It is the first line I made the flares for using the Eastwood Pro Flaring Tool, everyone should have one. :cool:
    0FD22C67-633F-44C5-A7BB-42558D246527.jpeg 74BCAC77-225E-4097-BC6A-700FC20EA904.jpeg 83EC1207-06C3-4413-BC97-090E9BCCBE9F.jpeg
    brEad, Gotgas, OFT and 6 others like this.
  4. atch
    atch
    Blue,
    This is the only thing that comes up when I search this thread for "bender". What tubing bender are you using? Your bends come out better than mine.
  5. Blue One
    Blue One
    from Alberta
    I’ve got 3 Imperial lever type tubing benders.
    3/16”, 5/16”and 3/8”.
    They’re industrial quality and work great , they’re much better than the hardware store versions that bend multiple sizes of tubing.
    They usually don’t have a good tight bend radius.
    The Imperial benders are US made quality :cool:
    Shadow Creek, OFT, brad2v and 3 others like this.
  6. atch
    atch
    Thanx.
    Blue One likes this.
  7. Blue One
    Blue One
    from Alberta
    Whew :D That was fun. The small lines I had made from the master cylinder to the proportioning valve (with the previous terrible flares) have been replaced.
    New line bent up and properly flared.
    That ni cop line sure looks nice when you give it a little scrub down lightly with Red scotchbrite. :cool:
    43D3E464-271B-4EC3-B8C5-B28C4CBCDC3A.jpeg 56C40A20-F1AC-42FC-8C07-A02BC91E6A06.jpeg
    brEad, loudbang, OFT and 3 others like this.
  8. GASSERBOB
    GASSERBOB
    from USA
    They look really good.
  9. brad2v
    brad2v
    I'm kind of a plumbing geek, and I approve of the preceding messages :D. Nice job
  10. Nice work. Why the extra bends?
  11. Blue One
    Blue One
    from Alberta
    Thanks, all bends are for routing clearance to keep everything clean and neat, not touching or rubbing anything.
    It also makes future repairs such as changing a master cylinder easier.
    So, no extra or unnecessary bends.
  12. tfeverfred
    tfeverfred
    Looks great, Blue! Looking like a pro.
    loudbang, 26 T Ford RPU and Blue One like this.
  13. Blue One
    Blue One
    from Alberta
    Thanks Fred, there’s more coming guys
    I’ve wrapped up the front brake lines and I’ve installed my 3/8” ni-cop fuel line and started the rear brake line.
    I’m using some more of the Made for You T clamps but these ones are kinda neat having one side for the 3/8” line and the other side is for the 3/16” brake line.
    Looks really nice having the lines running together.
    I’ll post pictures when it’s ready to show :cool:
    tfeverfred, OFT and 26 T Ford RPU like this.
  14. loudbang
    Excellent work as usual.
  15. Blue One
    Blue One
    from Alberta
    Brake lines and fuel lines are progressing nicely.
    I had to route them around the hole in the frame for the exhaust.
    The Made for you line clamps with 3/8” on one side and 3/16” on the other side are pretty nice.
    I took a 3/8 “ Tee and silver brazed some mounting tabs to mount it to the frame.
    A section of hose and some fittings will tie it to the fuel pump. :cool:
    58C28C3A-27D3-4957-A25F-F0673DAB79E2.jpeg 79CAD3E2-7E21-4053-8F33-DF7A89505605.jpeg 45022A5B-664E-4D9C-AA03-C174C83C4811.jpeg 4F6FDEF9-C23A-4C9D-9F00-34A3A0944217.jpeg 0E5B4F05-F04A-4845-884B-472C56594D59.jpeg 4EA8BAAF-A0FE-44D2-972B-8B8733CE61D3.jpeg 107CF9B8-B533-4CD3-9513-B145484E3DA3.jpeg
  16. crminal
    crminal
    Okay, now you’re just plain showing off :rolleyes:
    :D
    brad2v, 26 T Ford RPU and Blue One like this.
  17. tfeverfred
    tfeverfred
    Very nicely done, Blue!
  18. Blue One
    Blue One
    from Alberta
    The fuel line connection to the fuel pump inlet.
    No hose clamps, I just have to have the ferrules crimped now.
    Inverted flare fittings, the top inverted flare size for the fuel pump inlet is 5/16” x3/8” hose the bottom is 3/8”x 3/8.
    Along with super good quality hose (Gates Barricade Greenshield), nice and clean. :cool:
    https://www.discounthydraulichose.com/product_p/38-874.htm
    F4975129-4A2E-4612-B2F4-297313090DFC.jpeg 2B627C7A-BA1F-4CAB-901C-CDCBB189D79C.jpeg 0A97B7DB-866D-4E42-87BD-3049EE80C61B.jpeg 6C2E69B1-92F0-40BC-B18E-F9DC653E81E2.jpeg
    F-ONE, Tim, The 39 guy and 5 others like this.
  19. tfeverfred
    tfeverfred
    Blue, I've NEVER seen that done on a home built car. Your attention to safety and detail is above the bar!
    F-ONE and Blue One like this.
  20. Blue One
    Blue One
    from Alberta
    Thanks Fred, it must be all the years I spent as an industrial pipe fitter / pressure welder.
    Working alongside instrument fitters you pick up a few things.
    I think it will be much better than the usual hose and clamps. :cool:
  21. goldmountain
    goldmountain
    I'm impressed with your 90 degree inverted flare fuel fittings. Do you know of a source for a similar fitting I can use on my brake lines?
  22. 57 Fargo
    57 Fargo
    Nice work as usual, may I suggest marking the fitting to the hose in case they turn on the way to getting them crimped. Unless they are swivels that is.
    brad2v, loudbang and Blue One like this.
  23. Blue One
    Blue One
    from Alberta
    I’m not sure. Do what I did and search every possible source online for fittings.
    It took a while to find what I needed.
    Good idea.
    They aren’t swivels and one is turned just slightly off square because of the taper of the frame.
    I’ll mark them before I head to the hose shop.
    brad2v, loudbang and porkshop like this.
  24. bobbytnm
    bobbytnm
    Awesome progress! The fuel line is amazing!
    Bobby
  25. Blue One
    Blue One
    from Alberta
    The fuel line is crimped and installed.
    And Summit came through with the final line clamps I need to secure the rear brake lines :cool:
    8B499E39-6DC6-487A-B510-12F43E9B779E.jpeg 059FF904-BBE2-482E-B0C8-C8C97A524816.jpeg
    brEad and loudbang like this.
  26. tfeverfred
    tfeverfred
  27. Tim
    Tim
    from KCMO
    Man, you know based on what you post I think your a real *** hole sometimes. But **** the way your plumbing this thing correctly will let me forget about it for a while. Lol
    Then I saw your a Pipefitter, your not just a part time ***hole! Lol this explains so much lol
    -said with the affection that only someone with plenty of ***hole Pipefitter friends could have-
    loudbang and cactus1 like this.
  28. Blue One
    Blue One
    from Alberta
    :D
    At least I'm not an ironworker :eek: :D:D:D:D
    loudbang and Tim like this.
  29. DDDenny
    :eek:
    Wow, wasn't quite sure where you were going with this Tim!!!
    Blue, looking good, bet you're glad the list is getting shorter.
    What's next when the plumbing is done?
  30. Blue One
    Blue One
    from Alberta
    I’m going to put gear oil in the quick change and bleed the brakes,
    Then I’ll install the pickup bed and mount the fuel tank and finish the back end of the fuel system.
    Then the body can go on and I can start wiring.
    In 7 weeks I’ll be off for the summer, :cool: :) so I’ll be able to devote more time, just like last summer which was a day to day marathon of bodywork and painting. :D
    loudbang, brad2v and tfeverfred like this.
