Technical GM BELL HOUSING QUESTION
Discussion in 'Traditional Hot Rods' started by lrs30, Apr 28, 2018.
  1. lrs30
    lrs30
    from Kentucky
    Does anybody know what later Model GM bell housing has a slave cylinder bracket embossed into the housing itself? If so what make model and years and what size clutch does it accept? Thanks in advance.
  2. 56sedandelivery
    56sedandelivery
    Camaro/Firebird would be my first guess; actually, my only guess. My parts book (E-BAY listings) say 82-94, and they are't cheap.I am Butch/56sedandelivery.
  3. lrs30
    lrs30
    from Kentucky
    But I think the camaro one has the trans at an angle. The one I am in search of has the trans straight not tilted
  4. Jmountainjr
    Jmountainjr
    Early 1960's Chevy pickup housing had two pads for a slave on the p***enger side of the housing.
  5. I've never had a problem with a bracket.
    Bleeding the crazy things is another story, but the brackets no issues.
    reagen likes this.
  6. 33essex
    33essex
  7. B.A.KING
    B.A.KING
  8. Jmountainjr
    Jmountainjr
    Looks like a Novak slave bracket kit.
  9. Yes it is but I make stuff.
  10. Mr48chev
  11. deathrowdave
    deathrowdave
    from NKy
    I’m thinking around pre 64 truck had cast iron with slave . It had no bottom just a sheet metal cover . Made clutch swap easy .
  12. neilswheels
    neilswheels
    from England
    What clutch fork are you using 31 Vicky, I've fabbed something similar for my 40, but had to shorten my fork, but as i have to remove the engine to remove the fork so i can fully weld and brace it, It would be easier to put a shorter fork in... Im running a 168 flywheel and 11" clutch, Thanks (after and before pics below)
  13. dirt t
    dirt t
  14. lrs30
    lrs30
    from Kentucky
    The 85-7 truck bellhousing is the one I’m looking for if anybody has one laying around, hit me up! I’m swapping out a new turbo 350 for a T5 so I have a fresh rebuilt 350 for sale if anybody is in the market!
  15. xlr8
    xlr8
    from Idaho
    Early to mid 90's 4WD pickups also had a hydraulic slave cylinder on the p***enger side because all of the front driveshaft stuff was on the drivers' side.
