1936 Ford Ch***is, could also work for most 35-40 cars Almost a roller, includes: 1936 frame, fully boxed, stock front crossmember, rear has been set up for ch***is eng. parallel leaf springs. Includes new posies springs, ch***is eng. rear shock kit, shocks, ubolts. Two tubular crossmembers added for strength. At one time was C notched, but has been brought back to stock, with the notches removed. Has all its body boxes and rear body mounts. POR 15 inside the rails and boxing plates. It's straight and nice. Been sitting for a few years, will need some surface clean up here and there. All the suspension is new, never run, just been sitting in storage. Front end: 1939 axle and unsplit wishbone, ch***is eng. 1" lower new front spring, 37-41 front spindles, new kingpins, '39 brakes, ch***is eng. sway bar kit never installed, flat top perches, ch***is eng. shackles/lower shock mounts. Rear end: 1965/66 Ford Mustang 8", 2.90 gears, rebuilt and never run, stock axles, 5x4.5 pattern, new lug studs, new bearings and seals, new flex line, several pre bent, usable brake lines, backing plates and bolts. Hoping to sell as lot, pick up Austin TX.
