Event Coverage Welcome to the 2018 Meltdown Drags
Discussion in 'The Hokey Ass Message Board' started by Okiedoker, Oct 12, 2017.
  1. powrshftr
    powrshftr
    Don’t drag me into this....And before you go taking on any supercharged Hemi dragsters,you better get the bugs outta that new car.I remember a string of 12 second p***es out of your last highly anticipated “8 second car” the first half dozen or so times out...
    Now,I gotta get back to re-installing this pedal ***embly with the new roller bearings.
    Looks like I’m finally gonna have a clutch that works like it should.[emoji4]
    Motor comes out to verify bell housing alignment,and swap out old pressure plate for the newer,heavier unit.
    After that,it’s mostly re-***embly and making p***es at test n tune night til I can figure out how to drive it.
    On the p*** where it smoked the clutch last year,it caught a car on an 11.44 p*** by 1/8th mile before the clutch shat the bed,so I’m looking forward to making some full p***es.[emoji16]
    Scott
  2. Deuced Up!
    Deuced Up!
    Actually he might just be breaking his clutch in on a school parking lot. I hear that can take a while.....LMAO
    Sent from my SM-G930V using The H.A.M.B. mobile app
    saltflats and loudbang like this.
  3. powrshftr
    powrshftr
    loudbang and Deuced Up! like this.
  4. Tickety Boo
    Tickety Boo
    from Wisconsin
    DANG, TICKETY BURN!
    Swamp Rat 4, loudbang, Gammz and 5 others like this.
  6. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    God I missed Scott! He brings out the best in you guys!
  7. powrshftr
    powrshftr
    Thanks Man.[emoji4]
    I don’t know if “the best” is what I usually bring out in these apes,but I guess we all get what we deserve out of life,huh...?[emoji16]
    Scott
  8. saltflats
    saltflats
    from Missouri
    And no word of what ol Norb is bringing to the gun fight.o_O
    I am taking my rubber knife to the belt sander as we speak to get it razor sharp. ;)
  9. wrenchbender
    wrenchbender
    Well james don't feel bad I'll be lucky if I can shovel my pile on the trailer to just arrive and stink the place up I didn't think a simple engine swap could be so damn complicated every time I think I'm gonna get to start it I find another issue
  10. powrshftr
    powrshftr
    What did I miss?Is Norb not bringing the ol Tickety Boo this year???
    James: That ol “rubber knife” has “cut” a few very serious cars over the years,and I’m looking forward to seeing the latest version of it run.
    Jackson: Keep at it,Brother!Seeing that car run with that big whale in there is gonna make for some goooooooood watchin’![emoji16]
    If anybody can pull it off,you can!
    Scott
  11. saltflats
    saltflats
    from Missouri
    Start it!!!! hell I just set the crank in.
  12. wrenchbender
    wrenchbender
    Well Scott I appreciate the confidence man and james that ain't no rubber knife that there is a helluva bullet your putting together I'm sure I'll have mine back out again before then I am pretty sure I'm gonna have to step the gear ratio way back up according to the math it will be out of gear by the first 60 feet lol
  13. saltflats
    saltflats
    from Missouri
    Scott, I am truly blessed to have the opportunity to play with this car and engine with such a following (not me).
    And I am honored that you guys let me come and be a small part of the big show.
  14. Tickety Boo
    Tickety Boo
    from Wisconsin
    The ol nag Tickety Boo will be there entry #318, waiting to race a Mustang :D
    The only changes will be lighter wheels with smaller slicks and bigger MSD chips;)
    Thanks for the picture Salty:cool:
  15. saltflats
    saltflats
    from Missouri
    Norb is quite the pistol now ain't he. :D
    You may want to think about losing some pounds also.....the salt burn wont last as long. ;)
  16. powrshftr
    powrshftr
    The only thing I’m worried about burning is my clutch....again.[emoji15]
    chryslerfan55, rocketsled59 and Gammz like this.
  17. saltflats
    saltflats
    from Missouri
    With your new pivot bearings you will put your foot through the floor.
  18. wrenchbender
    wrenchbender
    Scott you have to quit riding the clutch cause we all know that ford doesn't have enough power to burn the clutch out lmao
  19. powrshftr
    powrshftr
    It had enough power to make your eyes get about as big as tennis balls when I took you for a little ride in it...lol
  20. saltflats
    saltflats
    from Missouri
    Jackson was just trying to make you feel good. ;)
    loudbang, enloe and powrshftr like this.
  21. Tickety Boo
    Tickety Boo
    from Wisconsin
    Did you put more bracing on the pedal ***embly? Last year when we found out you were having clutch adjustment trouble, I remember Bob told me he added extra bracing because his Falcon clutch would flex everything under the dash.
    Falcon/Mustang/Comet they all need more bracing weight cause they are too damn light.;)
    Use 3" angle iron :rolleyes: Then I will have a chance:D
  22. rocketsled59
    rocketsled59
    Yeah. Me too
  23. powrshftr
    powrshftr
    Mines really not that bad,Norb.The static pressure isn’t really enough to make your leg uncomfortable if you’re sitting at a stoplight for a while,I think most of the grip in this unit comes from decent sized counterweights,and insanely aggressive friction material.
    This one is 1 step above the last unit I ran,which was a pretty great setup until my ****ty adjustment and wore-out pedal ***embly killed it.
    I just didn’t wanna take any chances with it this year,so I went all the way to the bottom of the single disc page.lol
    Honestly,my biggest problem (aside from remembering how all this **** goes back together) is going to be launching the thing.This clutch is like a light switch;it’s either all the way on,or all the way off.Makes it tricky to find the sweet spot where it doesn’t bog,yet doesn’t smoke the hell outta the tires either..
    Scott
  24. saltflats
    saltflats
    from Missouri
    Look Out!!!!
    Better rods in the pump engine for this year. :cool:
  25. powrshftr
    powrshftr
  26. rocketsled59
    rocketsled59
    Which one were you running? I'm looking at the powergrip hd from ram or the 650 from hays. Both single sintered iron. This organic zoom has the same friction coefficient as a 78 LP. ... with a skip.
  27. rocketsled59
    rocketsled59
    TOO THE MOON ALICE! TOO THE MOON!!!
  28. powrshftr
    powrshftr
    Bob:
    I was running the Ram unit you mentioned,which is supposed to be rated for approx 650hp.
    I loved pretty much everything about it,and I’m pretty sure the only thing that killed it was my botched adjustment job,combined with a clutch pedal that didn’t wanna retract all the way,allowing it to ride on the throw out bearing,and cause all kinds of a mess.
    The pedal pressure was real reasonable,and it was easy to drive.
    I know I made it look hard,but it was easy...lol
    Scott
    I’m behind too..,Mr. Saline Solution! My current Sit E Asian..,
    Are gonna quit ****ing around, and hook up the secondaries?
