Hot Rods How good can you make a Windsor look?
Discussion in 'The Hokey Ass Message Board' started by ChoppaScott, May 6, 2018.
  1. ChoppaScott
    ChoppaScott
    Here's my conundrum. I bought my 30 coupe 3/4 finished and the previous owner put a Windsor in it. It's a good little motor. Lumpy cam, runs nice, no smoke. I've got no reason to swap it out.
    But
    It looks wrong. I don't know if it's the angular valve covers, the long water pump or the dizzy in the front but it just looks so nineties.
    I'm at the point now though where I need to make the decision whether to get rid of it or learn to live with it. Changing drivetrain/****** at this point in the build is going to absorb a lot of time and $.
    I'm hoping there might be a few die hard Windsor guys out there who can show me a few pics of cool looking engines to convince me to keep it. I've tried googling it and I just get pics of Mustang engine bays. I want to see a few Windsor's with chrome, metal flake blocks, polished tunnel rams etc.
    Do the exist?
    Sent from my Pixel XL using The H.A.M.B. mobile app
  2. blowby
    blowby
    from Nicasio Ca
  3. There's also FE valve cover adaptors, which to me look more 'natural'. Use pent-roof covers and there's no h***le putting oil in. Holman-Moody also makes a very attractive cover.
    powrshftr likes this.
  4. ChoppaScott
    ChoppaScott
    FE valve covers on a small block. Is that like putting a plastic rack on a size 8 **** star?
    I like that look! [emoji6]
  5. Boneyard51
    Boneyard51
    Keep the Windsor, too many sbc in old Fords. Bones
  6. Here's a pretty good looking Windsor.
  7. Some finned valve covers and cool air cleaner and call it done
    If ya really want to pull of the vintage vibe, add an oil fill timing cover and a generator.
  8. Hnstray
    Hnstray
    from Quincy, IL
    You are worried about how it looks and you want to see “metal flake painted blocks” :confused:
    Ray
    motorhead748, Deuces, zzford and 3 others like this.
  9. 53 ford
    53 ford
    Put a hood on it and don't open. Nothing better than a Ford in a Ford.
    King ford, Deuces, Okie Pete and 10 others like this.
  10. 63Compact
    63Compact
    You can run twin 4s, tripower an elusive manafre 4 x2 intake, theres quad webers or injection etc. theres plenty of rocker covers avail. finned sumps etc. I run a tripower, offy covers and a cal custom finned sump with lakes style headers on a winsdor in my A Coupe.
    Deuces, Malcolm and Hnstray like this.
  11. haileyp1014
    haileyp1014
    from so cal
    One way
  12. Phillips
    Phillips
    Don't try to make it something it isn't. Forget the finned aluminum and go for a Ford factory race look circa '64:
    junior 1957, Deuces, Oldb and 12 others like this.
  13. southcross2631
    southcross2631
    King ford, Deuces, Texas57 and 5 others like this.
  14. low budget
    low budget
    from Central Ky
  15. LM14
    LM14
    from Iowa
    I use an older timing cover, pre 70 water pump and early pulleys. Shortens up the engine. Lots of valve cover choices (I'm going 64 Fairlane/Galaxie on spacers so roller rockers fit better) tons of intake choices. If' it's a 302 it's easier, if it's a 351 you can still find several intake styles.
    3rd one down is my '88 roller 5.0/302 with a couple different looks. It will be painted with minimal chrome. Most likely where I am headed. Will also use Pertronix and stock looking wires from them.
    The 289 in my '57 in a couple different looks. Also Pertronix.
    SPark
  16. F-ONE
    F-ONE
    from Alabama
    There is only one Windsor, the 351.
    221, 260, 289 and 302 were called Challangers or the Ford Fairlane V8.
    Everybody call them Windsors when "small block" would be more appropriate.
    Deuces, djweaz, 5window and 1 other person like this.
  17. abe lugo
    abe lugo
    put a hood on it and drive.
  18. I like the early black blocks with the painted gold valve covers
    those look cool
    and this one as well
    Deuces, brjnelson and ChoppaScott like this.
  19. ChoppaScott
    ChoppaScott
  20. RmK57
    RmK57
    I personally like the "Power By Ford" oem rocker covers.
    hans mercman, Deuces and Terrible80 like this.
  21. jimmy six
    jimmy six
    Get rid of colored wires if you have them and use black. Make every thing neat and clean. I think they look great.
    Deuces and Hnstray like this.
  22. .... and make sure you use the small cap on the distributor.
  23. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    The 5.0 in my '31. Black metallic catalyzed urethane on the engine.
  24. 54HotRod
    54HotRod
    I have the Edlebrock dual quad set up for a 351W that I’m selling you’re interested. It’s still in the box, I only took it out to take pictures one day.
    Deuces and sandman460 like this.
  25. Drink lots of beer,it’s known to cure ugly!
  26. ChoppaScott
    ChoppaScott
    Thanks but if I keep the motor I'm thinking about going with a tunnel ram. It'll keep that 60s feel and apparently 302s run pretty well with them.
    Deuces likes this.
  27. NewGuyOldFord
    NewGuyOldFord
    Before you started this post I was thinking the same thing about how to get the ugly off a chevy motor so I just went with a ford. ;)
  28. hotrod428
    hotrod428
    This is the 351W thats going in my 53 Courier. I made adapters for the 66 390 covers.
      226.7 KB
    jimmy six, Trefl, Deuces and 10 others like this.
  29. okiedokie
    okiedokie
    from Ok
  30. Mechman_22
    Mechman_22
    from Nc
    following as I will be running the same engine in my sedan
