350 chevy firing order
Discussion in 'The Hokey Ass Message Board' started by Hessler, May 7, 2018.
  1. Hessler
    Hessler
    Hi to all my name is Hessler, first I wanted to introduce myself and thank everyone for all the great support, inspiration, knowledge and I could go on, but I recently bought the car of my dreams, a 1937 ford slantback, but like any rod its got issues and Im trying to iron them out, one is the timing, when I first got the car I noticed the timing was bad and I figured easy fix, well yesterday I tried fixing it but soon realized that no change would fix the timing issue, then I got to think ok... what else could be wrong, I thought one cable must be on the wrong spot, then to my surprise I saw something I have not seen before, my firing order is this 1-2-4-6-8-7-5-3 clockwise and I was like what!!! Scratching my head, I had never seen this on a chevy engine, I know the engine has minor work, maybe a cam, the previous owner did not know much about the engine.
    Any thoughts? The car runs, starts, but sometimes the engine will not shut off immediately. IMG_3758.JPG
  2. Boyd Wylie
    Boyd Wylie
    Have you looked up the correct firing order? Initial timing a 8 BTC for a start.
  3. Just Gary
    Just Gary
    Those are all odd #s followed by all even #'s.
    I bet you have a "correct-a-cap". They were popular in the 1990's to make the spark plug wires look pretty and parallel.
    As you probably know, the order on a SBC should be 1-8-4-3-6-5-7-2.
    lothiandon1940 likes this.
  4. Mr48chev
    1-8-4-3-6-5-7-2 is the small block Chev firing order left bank (US driver's side being 1,3,5,6 front to back right bank being 2,4,6,8 front to back.
    Rotation is clockwise.
    You can tell the rotation of any distributor with a vacuum advance if you wrap your thumb around the vacuum advance an point your index finger around the distributor on the side it sits on. Your finger is pointing in the direction of rotation.
  5. squirrel
    edit:
    found the instructions...it's right...
    it will take me a minute to get the images posted
    Just Gary likes this.
  6. Just Gary
    Just Gary
  7. squirrel
    here goes...
  8. Hessler
    Hessler
    I have a feeling Just Gary nailed it LOL I had no idea those existed, I was like WTF and fixed all the cables and my car did not start, but now I gotta go check but now Im almost certain that is it, I still dont get why my timing is not getting any better, I might just change this cap and see if that helps, thanks to all!!!
  9. squirrel
    you fixed it to the wrong cap...maybe?
    But seriously, take a picture of your cap, so we can see what you see
    Just Gary and lothiandon1940 like this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Multi-meter will sort things out with that HEI cap
  11. saltflats
    saltflats
    from Missouri
    If it runs on when you shut if off.....set the idle down.
  12. Hessler
    Hessler
    Im gonna take some pictures and post it but Im sure its one of those caps that Just Gary mentioned, but Im gonna switch it, its playing tricks with my head
  13. milwscruffy
    milwscruffy
    I've been running a crossfire cap for over 20 years with no issues. The firing order you list is correct for it.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Does this help your head any?
    milwscruffy, Just Gary and Hessler like this.
  15. s55mercury66
    s55mercury66
    from SW Wyoming
    Flashback to the late 90's..
    A buddy picked up a distributor at a swap meet with one of those caps, without knowing it was on it, or even that there was such a thing. Short version says it wound up in little pieces after much frustration.
  16. Hessler
    Hessler
    LoL
  17. Hessler
    Hessler
    The initial issue was the timing, for some reason I cannot get my car to shut of correctly, it wants to stay on, is this only related to the timing? Could the cap be the culprit?
  18. milwscruffy
    milwscruffy
    Turn it off in gear next time.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Alternator feed back or electric fan feed back? Tell us about these set up's on the car.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Better yet. Unplug the things I've just mentioned and see what happens. edit-one at a time and not both at the same time.
  21. Hessler
    Hessler
    Would the timing be the same? 12 to 14?
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes
