hi everybody, I finally came accross a vintage Dixco 47 tach in decent shape. I guess that some parts inside are either missing or faulty because it lights up but doesn't show the revs when installed. After opening the case i saw that there are some new solder signs and guess that there are wrong parts used! Does anybody have a components list of the electronics or can send me a pic of them from a working tach? appreciate any and all help! Mustsed
Williamsons.com are the folks who rebuild Sun tachometers and instruments. Check with them to see if there's anything they can do for you. I am Butch/56sedandelivery.
Thanks Butch, I am overseas and the freight would kill the profit I got with the deal! Have to do it here by myself. Mustsed
Green - Sender to - side of coil White - Ground Black - to the + side of coil, THIS ONE HAS WRONG COLORED WIRING
Hi Ricks Garage, No problems with the wiring and the wires are still attached to the right points. I need the parts layout and the part numbers like condenser# (like the brown big one in the pic) and the green condenser part number below the circuit board. These parts do look like they are replaced with wrong ones! Thanks, Mustsed
