Hot Rods 1965 Dodge van
Discussion in 'The Hokey Ass Message Board' started by falconvan, Nov 28, 2017.
  1. RodStRace
    RodStRace
    I only occasionally lurk over there now; a few members are perversely useless, and a big percentage just dash on, ask a simple question that has been answered 20 times, then dash off. I poured real effort into some of my posts and many of the 'community' couldn't be bothered to read. After too many "what tires fit?" posts and a certain member's baiting queries, I bailed...
    I found that the number of posts per week that actually interest me over there is around 2. Lots of good info in the old posts, but you have to dig through too many "I bought a 60s van, how can I make it as safe as a modern Honda?" I-D-10-T-S.
    While updating the amp gauge, go with the electronic regulator that matches a later, higher amp alternator or (gasp) an internal regulated alt. The old school points type regulators can be made to function well, but it's a dying art and not equal to higher output charging systems.
    brad2v, iwanaflattie and falconvan like this.
  2. falconvan
    falconvan
    from festus, Mo
    On my last couple of Mopar engines I used a mid 80s GM alternator and a mid 80s GM HEI ignition module with the Mopar electronic distributor. Works great, cheap, and you eliminate both the voltage regulator and the ballast resistor.
    iwanaflattie likes this.
  3. falconvan
    falconvan
    from festus, Mo
    I had a few days off so I cleaned up several more things and bolted them on the engine, primered the back doors, and cleaned up all the pieces of the doghouse and painted them. I was going to use bedliner on the floor but decided to go with a full rubber floor mat so I just painted the floor. I hope to get all the guide coat sanded off the back doors this weekend.
    [​IMG] Attached Images
  4. RodStRace
    RodStRace
    I would suggest coating the floor and especially the wall/floor corners with more than paint before laying a rubber mat over it.
    These things are killed by rust and having a rubber mat will allow moisture to collect and settle under it.
    Add a little dirt and the movement of the mat and you sand off the paint and allow the water to sit directly on bare metal.
    Spray undercoat, body schutz, or the bedliner you were thinking about would all be better than just a coat of paint.
    czuch likes this.
  5. falconvan
    falconvan
    from festus, Mo
    i think it will be OK; i've got two heavy coats of epoxy primer and I used some tractor paint I had over that.
  6. tb33anda3rd
    tb33anda3rd
    can that lean in the engine be fixed?:D;)
  7. Chaz
    Chaz
    Gives new meaning to the phrase "Its running lean."
  8. falconvan
    falconvan
    from festus, Mo
    Lol! They are a strange looking engine. The Mopar engine designers must have been on an acid trip the day they drew these up.
    czuch and Hnstray like this.
  9. falconvan
    falconvan
    from festus, Mo
    CDA24813-01C7-461B-97C8-9FA0750ABABD.jpeg 43F888C7-690F-487A-8668-DA7A84F77135.jpeg 4756E690-59CA-4C67-8702-836E191889AE.jpeg Finished sanding the back doors today, got all my shift linkage rebuilt with new grommets and put in, and put the heater together and back in. Should be starting on the wiring pretty soon.
    brad2v, 55Deso, Peanut 1959 and 2 others like this.
  10. Chaz
    Chaz
    That heater makes Rube Goldberg proud!
    czuch, Hnstray and falconvan like this.
  11. falconvan
    falconvan
    from festus, Mo
    5B1667A7-E305-44A3-A4FB-5C3A5E54722C.jpeg B23240C0-0195-4CEF-B74C-DE34E8EE762B.jpeg FAA7D625-2910-4837-A5D3-2E2E0310CE4E.jpeg I shot the rest of the doors with Slicksand today; now I need to sand them, shoot the whole van with 2k, wet sand, and it’s ready for color. I’m glad, I’m getting burned out on bodywork. Also started wiring the engine and the dash.
    brad2v, Hnstray, AndersF and 2 others like this.
  12. tb33anda3rd
    tb33anda3rd
    i am thinking that carpet could be a good inspiration for a paint scheme........
  13. falconvan
    falconvan
    from festus, Mo
    Yep, and a big peace sign on the front. Then I'll follow the Grateful Dead around for a while.......
    pat59 and tb33anda3rd like this.
  14. RodStRace
    RodStRace
    Lots of ways to go with paint
    https://www.vinvanco.com/paint-job-gallery.html
    But a fresh solid color is great looking .
    I did a solid color then added a large decal graphic.
    It got lots of thumbs ups, a couple trophies and was used in one event's advertising a couple years later.
  15. falconvan
    falconvan
    from festus, Mo
    Very cool!! If I didn’t have all the windows I’d probably do something different but since it does I’m going stock. Yours looks fantastic!
    Hnstray likes this.
  16. RodStRace
    RodStRace
    With windows, you can highlight the upper inset around the windows (White or Light Blue) or merge (Black with tinted windows). Easier to paint...
    or come up with a nice stripe design Decal is easier
    czuch, Latigo, falconvan and 2 others like this.
  17. RodStRace
    RodStRace
    falconvan and scotts52 like this.
  18. falconvan
    falconvan
    from festus, Mo
    Looks nice, thanks!
  19. falconvan
    falconvan
    from festus, Mo
  20. falconvan
    falconvan
    from festus, Mo
    Now for a trip around the whole thing with some wet 400 and she’s ready for color
    czuch, brad2v, 55Deso and 3 others like this.
  21. RodStRace
    RodStRace
    Lookin' good! Since you are going all out and doing such a nice job, I'd humbly suggest fitting at least the headlight rings, if not any other trim. Your door gaps are nice, and the rest (grille, turn signals, tail lights) is pretty much as it bolts on. Those pie pans have no welting and can vary and twist so the gap can be funky. They built these for commercial use on a budget, so they weren't 'tight' when new. Of course, anyone who has got this far this fast knows that....
    falconvan likes this.
  22. falconvan
    falconvan
    from festus, Mo
    Thanks! You're right; the fit and finish wasn't too great on these from the factory. Door gaps are OK but you can see the imperfections up close. I didn't want to get too crazy since its just getting some budget priced single stage enamel and going to be a fun cruiser.
    Hnstray likes this.
  23. falconvan
    falconvan
    from festus, Mo
    EF0D2E16-983A-430D-BA65-2E826DAE10C1.jpeg 3CB291FA-D5BF-4EE4-850D-895C0844FBDD.jpeg Thank you, Jesus! Sanding is done and I put the sealer in the drip rails today. My buddy Kyle is going to shoot the color for me next week.
    czuch, racer-x, AndersF and 3 others like this.
  24. Peanut 1959
    Peanut 1959
    That's got to be exciting! Hope all goes smoothly...pun intended!
  25. falconvan
    falconvan
    from festus, Mo
    43F8B3C1-923A-49BA-88A4-F0AAE1FF3375.jpeg 4FBD918A-0091-47D2-86A2-2DFD49ACD158.jpeg 4BA150DF-8B81-417A-AB8E-684CA473182C.jpeg So glad to get to this point
  26. Chaz
    Chaz
    That's gonna be nice! Congrats!
  27. falconvan
    falconvan
    from festus, Mo
    E7D8A7AD-335F-4B16-95EB-998BBFFAD332.jpeg 055DA790-52FE-4720-ACF9-947A41967748.jpeg 4B489D86-22CA-4A0D-A20C-A3228E72CC09.jpeg DFC16720-78A3-4396-B4C4-058B17E1C178.jpeg Some ***embly required
  28. Peanut 1959
    Peanut 1959
    Slick as snot...and a great shade, too! It'll look even better with the final rolling stock, gl***, and trim.
  29. falconvan
    falconvan
    from festus, Mo
    Thanks! Now is where it starts nickel and diming me to death. All that little finishing stuff adds up in a hurry.
    brad2v likes this.
  30. RodStRace
    RodStRace
