Projects Almost Funny - AWB Barracuda Funny Car Build
Discussion in 'The Hokey Ass Message Board' started by squirrel, Nov 27, 2017.
  1. flatheadpete
    flatheadpete
    from Burton, MI
    Man that thing's so cool.
  2. dirty old man
    dirty old man
    Well, back in the days of dirt track cars that were built from 30s&40s cars and those in the "Sportsman" cl*** had to have a body that matched the engine, nothing was said about the front axle, and most of the cars running an SBC and an early to mid 30s Chevy body used a Ford front axle ***embly with transverse spring for better handing.
  3. squirrel
    not much cornering needed on this one!
    enloe likes this.
  4. dumprat
    dumprat
    from b.c.
    What about some 48 F1 springs? Pull out leaves you don't need
  5. squirrel
    they're way too long.
  6. dirty old man
    dirty old man
    Agreed, but still wonder if it wouldn't be a more positive location of the axleo_O:rolleyes:
  7. squirrel
    I don't need it to be more positive than leaf springs give me...so I'm not worried about it.
    AHotRod and pigfluxer like this.
  8. pprather
    pprather
    You guys are providing good feedback, but honestly Jim knows what he is doing and will ask for opinions if he needs help.
    Let's try to stick with following the build. Time is ticking away.
    Sent from my LGL158VL using The H.A.M.B. mobile app
  9. Remember this is a light weight race car with above average weight on the rear of the car. Truck springs are way to much spring. It needs enough spring to keep the pan from getting smashed after a wheelie and soft enough to keep the wheels on the ground going down the road. Shocks will be key items. Before I got mine right I could bounce the front wheels off the ground towing through the pits.
  10. Deuced Up!
    Deuced Up!
    So what do you suppose the Barracuda will change into just before hitting the dozers? Fast back mustang maybe...lol!
    Jim this thing is looking awesome!
    Sent from my SM-G930V using The H.A.M.B. mobile app
  11. Doctorterry
    Doctorterry
  12. squirrel
    been tinkering with suspension and engine. Expect an update in about two weeks :)
  13. suchadrag
    suchadrag
    I have marked my calendar.
  14. GASSERBOB
    GASSERBOB
    from USA
    Beautiful work Jim.......... Bob...................
  15. squirrel
    thanks!
    We got back from our Airstream trip to Yellowstone, and I've mostly recovered. And getting back into working on the car. I've been getting some parts for the engine, and started on the quarter panels. Still waiting for some engine parts I ordered, and need to order a bunch more, too. It's going to be iffy whether it gets done by September, but I'll keep after it.
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Like the Firewall! Looks like it would support a fire real well;)
  17. 392
    392
    Cut, grind, weld. Great thread.
    chryslerfan55 and enloe like this.
  18. 64 DODGE 440
    64 DODGE 440
    from so cal
    Hey...Wood was good enough for a Model - T, it still should work.
  19. squirrel
    Been slowly tinkering away. I have mostly finished putting on mounting tabs for the seats, harness, motor plates and limiter, and the parking brake stuff. And the rear end is put together. Still behind the 8 ball on the engine parts....one of these days, I might get a crank, rods, and pistons. And a blower. Need to get all the valvetrain stuff, and get some work done on the heads so the valves will fit them, etc. then there's the transmission, and all that bodywork, fenders, doors, on and on.
    But I did get my driver license, so that's a start.
  20. ClayMart
    ClayMart
    Coingrats on the Comp License. :cool: The ch***is work looks great. But for a man who still needs a crank, rods and pistons I'm still impressed that you've got the parking brakes sorted out already. A man's got to have his priorities straight. :p I'll admit I felt a little twinge when you started cutting up that incredibly solid, original early Barracuda. But I'm all better with it now. :D
    brad2v, Thor1, chryslerfan55 and 2 others like this.
  21. Stogy
    Stogy
    That's starting to get pretty complex...Safety
    and Pavement Pounding Strength​
  22. saltflats
    saltflats
    from Missouri
    It looks like your gettin some tig time. Looks Great!!!
  23. 48fordnut
    48fordnut
    License is a big deal. Good work.
  24. Runnin shine
    Runnin shine
  25. belair
    belair
    Keep pecking away at it!
    ironrodder and loudbang like this.
  26. Baumi
    Baumi
    Wow, you made some great progress ,my congratulations to your license too! You are doing excellent work as always. The tabs on top of the round tubing you clamped your ground to, are the seat mounts for driver´s and p***´s seats , ain´t they? Jim, are you going to do a bolt -in floor or weld it in? And are you going to bolt the body to the ch***is or weld it solid? Sorry for asking so many questions, I have never built a racecar and try to gather ideas for my 53 Chevy G***er project.
    loudbang and 1959Nomad like this.
  27. squirrel
    I'm planning to make an aluminum floor, and rivet it in. The body will bolt on to the frame. There are brackets to support the rockers, and I will make steel pieces inside the body to meet up with the aluminum pieces of the floor and firewall. Probably a strange way to do it, but there are some advantages to being able to remove the body.
  28. Chaz
    Chaz
    You do nice work. Well thought out!
  29. flatford39
    flatford39
    You don't have a frame table do you??? How did you keep it square???
  30. squirrel
    I put it together on a "sort of" frame table. So it's mostly square.
