1952-59 Ford 1956 Victoria Heater Temperature Regulator Valve question...
Discussion in 'Off Topic Hot Rods & Customs' started by kgdb, May 10, 2018.
  1. kgdb
    kgdb
    from The 60"s
    Can someone tell me where the two Vacuum lines ( one small and one bigger) that are on the heater temperature regulator valve go to? I have ordered a manual but it isnt here yet. The attached pic shows the valve and the vacuum lines that I am talking about. The Car is a 56 Victoria.. Thanks heater control valve.jpg
  2. buymeamerc
    buymeamerc
    from s.c.,usa
    y block vacumn.jpg manifold heat valve.jpg On my 54 - it runs from engine manifold thru f/wall to a "tee" fitting - "tee's" off to wiper motor and down to heater valve, from valve to goes back thru f/wall at upper rt corner of heat input duct back over to heat control valve on the engine(pic 2 ) where heater core hose attaches to motor. pic 1 shows 2 side by side va***n (hard )lines coming off of fuel pump
    right above left valve cover, 1 small runs to carb, 1 large runs to hose that goes thru f/wall to the "t" fitting under dash. hope that helps
  3. kgdb
    kgdb
    from The 60"s
    Thanks buymeamerc for the great and detailed reply. My 56 is far from original so I am not concerned so much with regulating the temperature etc, my main concern is having a working defrost system as it is a requirement here and will have to be working when I go for inspection prior to hitting the road. That said, is there a way to byp*** this valve and just have full heat when the heat is required? Or will I end up with a no heat situation if I byp*** it? Also I am running a Cleveland and I am not using the heat control valve on the engine.
  4. danman55
    danman55
    Clean as a whistle! Man that looks nice... we need updates or information on those modifications you have made.
  5. 56longroof
    56longroof
    I think if you leave it out you will have heat all the time.
  6. kgdb
    kgdb
    from The 60"s
    Thats what I was hoping for.
  7. kgdb
    kgdb
    from The 60"s
    Thanks, lots of elbow grease! I know I will miss something but here is a list:
    1959 TBird front bumper.
    Power rack and pinion.
    Chev van tilt column.
    Dual Master Cylinder and all brake parts new.
    351 Cleveland, mild cam, flat tops ....
    C6 with stall converter and shift kit.
    Fresh 9" with 3.5's
    New fuel tank and lines
    Lowered 3" (Aerostar springs and blocks)
    Merc Turnpike Cruiser skirts.
    57 Lincoln Premier hubcaps for now..
    60 Dodge Pioneer taillights.
    "Keep it Clean" harness (in progress with that now).
    I know there is more but I have been smelling primer fumes all afternoon and thats all I can think of for now! lol
    Rui and 56longroof like this.
  8. 56FORD390
    56FORD390
