History The Ed Thompson '27
Discussion in 'Traditional Hot Rods' started by Ryan, May 14, 2018.
  1. Sweet & Low
    Sweet & Low
    I would see Thompsons T around San Diego with the Prowlers when I was a kid. He later put a Hemi in it. It was Bad ***.
    Back in the 50's the cops in San Diego were hard ***'s on guy's with no fenders and San Diego wasn't that big back then and they would find you. So if you were going to drive on the streets you ran fenders. Glad the finally lightened up. Younger Cops.
  2. Stan Back
    Stan Back
    "The 32 shells look out of proportion unchopped from the front in my worthless opinion
    otherwise, they are hot rod perfection"
    Whadda do I know? Only that early rods look better when their radiators or even with, or behind the front axle center.
    And the natural projection from the cowl should not intersect below the top of the radiator shell.
    anthony myrick likes this.
  3. Tim
    Tim
    from KCMO
    teach'm, Jet96, kidcampbell71 and 2 others like this.
  4. Tim
    Tim
    from KCMO
    Found a few better photos off Instagram real quick
    20620117-48FF-4E75-848B-6CE26D6F2F4F.jpeg CB6195B9-CEEC-40D6-9472-D624B5232330.jpeg
  5. Tim
    Tim
    from KCMO
    Dennis lacy also build anpretty good one 384EA7CA-0A2F-4646-828B-A31B3E0DF6F2.jpeg
  6. Squablow
    Squablow
    I'm all for full-height '32 shells on a 26-27 T, I guess I'm one of the few that doesn't like chopped '32 grilles or grille shells that sit low to line up with the pitch of the top of the cowl instead of straight out where a hood would line up square. At least there's proof that this was historically accurate.
    A '32 frame sure would be nice though, it would give a couple more inches that the seat bottom could drop into and also lower the pedal box.
    Here's mine.
  7. bct
    bct
    love em all.
    kidcampbell71 likes this.
  8. Gary Addcox
    Gary Addcox
    I totally agree with you, Firebug. It doesn't get any better than this.
  9. Gary Addcox
    Gary Addcox
    I FOUND A LIKE THINKER ! To be honest, I could run a flattie in a T roadster since I would not use it for long-distance, hence no need for a/c, o/d, or a top. Guess I just pussed out.
  10. Gary Addcox
    Gary Addcox
  11. The Ed Thompson T is awesome, love it! Fenders included. I would be disappointed if a feature car in 1958 didn't showcase a good stance & tyre rake. Check out where he drilled to mount the fender brackets... in the Kinmonts...:D:eek::D imagine doing that now, haha!
    I like this one from 1954-55, tyre rake not great but overall a good T on '32. Car still around, check it 50’S DRAG CAR BARN FIND 1927 T ROADSTER
  12. Below picture is a great reason why Deuce grilles need to be sectioned. Also sectioning helps with proportioning the grille to the smaller T dimensions.
    This is a perfect example of a 40s rake.
  13. should call it Jimmy Durante
    Jimmy B likes this.
  14. catdad49
    catdad49
  15. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    E69D52D2-0B24-4BD1-A713-EE62D70E2FF4.png Flip’s T-Ster has been a pretty timeless Hot Rod since Keith gave it life up in the “Shop in the Orchard” around 1998.
    There was quite a few good cars going together, one of them being Gary’s 29 “Sports-Roadster”.
    Keith’s gotta just have the right touch to make any Hot Rod have that”Just Right” look. That E.T.27 is no slouch either. Both great builds.!!!!!!
  16. kool 52
    kool 52
  17. kool 52
    kool 52
  18. catdad49
    catdad49
    This is the one that I really wanted to post the first time, just took a bit to find it. IMG_1429.JPG
    tb33anda3rd and kidcampbell71 like this.
  19. satan'schariot
    satan'schariot
    sc2.jpg sc1.jpg My dads built in 1958 and the one we built in 2017
    Jet96, 61cad, tb33anda3rd and 2 others like this.
  20. alchemy
    alchemy
    Your Dad aged well.
