Technical I was doubtful
Discussion in 'The Hokey Ass Message Board' started by seb fontana, May 15, 2018.
  1. seb fontana
    seb fontana
    from ct
    IMG_0461.JPG You ever hear tales of something being used in a weird application and think, " I wonder?"...I didn't have enough throat depth on my band saw and I wanted to save large pieces...1/2 " alum tooling plate...With an 18v Ryobi 5" saw..24 tooth C'bide blade..Actually cut very smooth, stringy chips so not a whole bunch of little chips flying around filling your shoes up..The blue on the blade is cause I miss calculated and cut into the bottom of the bucket [of course] !!
    Hnstray, The37Kid, '51 Norm and 14 others like this.
  2. oldsjoe
    oldsjoe
    NAPA KNOW HOW! Joe
    loudbang, Vanness and chryslerfan55 like this.
  3. NICE!!!- what's the adapter for? :D
  4. Squablow
    Squablow
    Damn, I would not have believed it. Well played.
    loudbang and kidcampbell71 like this.
  5. You can use routers with carbide bits to shape ally as well.
    Tim, Sporty45, loudbang and 1 other person like this.
  6. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Before I was able to splurge and buy expensive specialty tools, I did a lot with a circular saw. Metal and masonry blades can get a lot done. I've cut metal, brick, concrete, plastic and metal pipe, etc.
    I built my own home pretty much all by myself with a simple Craftsman circular saw, sabre saw, 1/2" drill and sawzall. It's was all hand nailed too. I finally bought a crown staple gun when it came down to doing jambs and baseboards.
    I recently replaced a couple single pane windows in my Parents house with double glazed. I used a masonry blade in a circular saw set at a 3/4" depth and cut right around the stucco'd in window in no time.
    Hnstray, The37Kid and pitman like this.
  7. F&J
    F&J
    Seb worked for Pratt & Whitney Aircraft as a machinist, so he has an "edge" over the rest of us..
  8. indyjps
    indyjps
    Nice tech. Wonder if a finer tooth trim blade would help or hurt the process.
  9. topher5150
    topher5150
    I think my dad would disown me if i used his router to cut metal
  10. alchemy
    alchemy
    Don't let the wife see this! She'll want billet crown molding in the living room.
    Chavezk21, raven, Rich S. and 5 others like this.
  11. seb fontana
    seb fontana
    from ct
    Crosley engine to Spriget [Sprite/MG Midget] trans....
    dana barlow, loudbang and mctim64 like this.
  12. seb fontana
    seb fontana
    from ct
    I would say it would help, especially if thinner material..I didn't have to push very hard, most of the effort was in starting the cut and keeping the saw straight..Can enlarge pic to see chip size/form better ..Next time I'm at H'pot I'll get a more tooth blade and be ready for the next time!
  13. 62rebel
    62rebel
    I hate to admit it but I've killed a couple of circular saws using cutoff saw blades in them to cut sheet metal.... cheap and old, they were probably due for replacement anyway. Never had a need to cut anything really thick like that, though!
  14. DDDenny
    Great tech Seb.
    My concern would be the carbide inserts coming loose due to abnormal heat buildup.
    Might not be an issue with high quality blades.
  15. thirtytwo
    thirtytwo
    I worked at a pattern shop a long time ago , made core boxes from aluminum plate we had a rip saw like Lowe’s or home depot has for cutting plywood to size and would cut 4x8 sheets of1/4 to 3/4 sheets of aluminum in same manner ,a little squirt bottle of alcohol makes it even easier
  16. I have been paranoid about cutting whatever I used to support the material I am cutting, and the other day, I was certain that I had double checked to insure the material was clear. As you are probably aware, when something is going to go wrong, there is always a witness, and in this case, my son asked, "Are you cutting your nice, adjustable, aluminium bench that you are going to p*** on to me someday?" (His voice was dripping with sarcasm.)
    I looked down, and horror of horrors, I had a one inch cut in my beautiful aluminium bench. I had to eat a lot of crow, and there were a lot of feathers.
    Bob
    Hnstray, '51 Norm and The37Kid like this.
  17. seb fontana
    seb fontana
    from ct
    To my surprise it did not get hot at all, warmed a little but wasn't enough to evaporate the alcohol I started to use at the beginning so I stopped using the alcohol to keep two hands on the saw....The blade put some heat into the pail when I cut into it, oops..
  18. DDDenny
    Looks like we are in good company Seb.
    I've had this shop garbage can for at least 30 years, one of my prized possessions too.
    Until I sawed into it.......twice:mad: 20180516_134426.jpg
  19. Since the 70s, I have used my table saw with a carbide blade to cut aluminium, including 7075, up to 1/2 inch, and never lost a tooth or had a problem.
    It is simply a matter of having a very sharp blade, having the metal secured properly with hold downs, and feeding gently using a push stick. You can easily feel when you are feeding the metal too quickly.
    It sure cut down the amount of time it took to rough out parts for machining or finishing.
    Bob
    seb fontana likes this.
  20. indyjps
    indyjps
    Ive run pvc and electrical conduit thru my miter saw while building. Try not to do the conduit too often to prevent wasting the blade but it all cuts just fine.
  21. I use my tablesaw with a carbide blade to cut aluminum all the time. The more teeth on the blade, the smoother the cut. Cut slow and steady for a clean cut. I've also got a carbide blade for my miter saw that I use occasionally for aluminum if I need a compound cut. And believe it or not, I've even used a chainsaw to cut castings and thicker extrusions, just don't expect a precision cut! Amazingly enough, it doesn't dull the chain, but it can tend to break the rivets holding it together...
    '51 Norm likes this.
  22. bct
    bct
    Use wax as blade lube it even makes the job quieter.
    dana barlow and '51 Norm like this.
  23. Used to cut 3/4 aluminum diamond plate with a worm drive circular saw all the time.
    That little battery operated unit pulled a big cart.
  24. seb fontana
    seb fontana
    from ct
    I would have gone with the 110v saw but wife lost it some where.:mad: Expected to go thru couple battery but one was more than enough.
  25. X-cpe
    X-cpe
    I don't know how many times my students did things, that from my "experienced" point of view said wouldn't work. Now when I go outside the box the main question is "Self, how can this hurt me?"
    Cliff Ramsdell and '51 Norm like this.
  26. seb fontana
    seb fontana
    from ct
    ^^^ Good point of view..I was expecting saw to kick back a bunch but that never happened so I kept going..
  27. My F.I.L has one of these. Cuts anything from tin roofing to steel. Super killer saw. Specifically designed for cutting metal.
  28. Six Ball
    Six Ball
    from Nevada
    Table saws work too but will eventually suc***b so I buy a cheap ones for this.
    Hnstray and patmanta like this.
  29. Kan Kustom
    Kan Kustom
    When I worked in a machine shop the key to cutting aluminum was how many flutes ,spindle and travel speed. I would have never had the balls to try this. Did your balls swell to twice the size right before the cut or after ?
    zzford likes this.
  30. gimpyshotrods
    gimpyshotrods
    Been using a Skil Mag77 for aluminum, for about 20-years.
    We cut aluminum on a compound miter saw, daily, at work.
