Projects 30 Chevy coupe, Need advice on new project
Discussion in 'Traditional Hot Rods' started by Roadsterturner, May 16, 2018.
  1. Roadsterturner
    Roadsterturner
    Hey guys,
    I know you guys have a wealth of knowledge so I figured I’d ask for some advice on me and my dad’s new project, 1930 Chevy coupe. I’m a ford guy and This is my first Chevy project so I’m a little lost on some stuff.
    Run down:
    Rust free cab but the wood needs some work.
    My dad wants to run fenders, no chops.
    Looking to put in a 350 and a good auto (not computer controlled)
    Looking to run a late model rear and either stock front end or mustang 2 or model a.
    My questions:
    1, Anyone know a good rear end swap that doesn’t require being chopped down and custom shafts.
    2. Best place for body parts
    3. Best auto transmission to run, not looking for speed records just a good cruiser setup
    4. Any advice on suspension front or rear.
    Any advice would be great. It’s not my first car to rebuild but I’m only thankful for help so I don’t have to do things twice.
    James
    South Austin, Texas
    kidcampbell71 likes this.
  2. 50John
    50John
    Regarding front suspension, ***uming you are staying traditional straight axle, my vote is stay parallel leaf and use a dropped a Chevy axle. Don't convert to a Ford buggy spring as is often done. The parallel leaves maintains the character of the Chevy. There are guys on the board that can drop the Chevy axles, and there are other years of Chevy axles that can also be used, and later brakes that can be retrofit to the spindles.
    RMR&C and tb33anda3rd like this.
  3. tb33anda3rd
    tb33anda3rd
    55-64 chevy rears will fit and so will the later s-10 4x4 rears. the ad chevy truck front axles that are dropped can used and fitted with 51-54 front brakes.
    can't go wrong with a 350 ****** you sure you don't want a stick shift? remember chevy made other motors than the 350, i hear good things about the 283's and 327's. sheet metal can be found and there are a few places that sell fibergl*** parts.
    here is my build thread for my '33, full fendered and unchopped.
    https://www.jalopyjournal.com/forum/threads/33-chevy-3w-time-for-a-cool-change.863287/
    kidcampbell71, TFoch and RMR&C like this.
  4. Bowtie Coupe
    Bowtie Coupe
    ^^That there's some good info, already. Regarding those '55-'64 Chevy rears, the center sections will swap for all those years. The '55-'57 rears were leaf suspended and the '58-'64 rears were coil suspended. '55-'64 full size p***enger rears are 55" from axle tube flange to axle tube flange. Yes, I've heard good things about those 283's and 327's, myself.;):) 350's are like belly****ons. Yet, parts are plentiful and relatively cheap. You'd be surprised what's available for those 283's and 327's though. You can't go wrong with a TH350 ****** is right, but there are other options such as a TH2004R OD trans. They have been fairly prevalent and cheap in the wrecking yards. You'd need to check dimensions. There is no "best" place for Chevy body parts. It's not like the early Fords where everyone is making repro parts. Being in Austin, you're probably in one of the best places for finding some good body parts. Regarding the wood, many guys replace it with square tubing. If you want to use new wood, there are several places making new wood, but be prepared to wait a considerable amount of time to get your wood as these places are in great demand.
    Autowood Restoration
    Hanna, IN
    Jim Rodman
    219-797-3775
    www.autowood.net./
    KC Wood Manufacturing
    Willis, VA
    Bill Cartwright
    540-789-8300
    info@ chevywood.com
    There are several threads on the HAMB regarding wood replacement. You can do a search on the HAMB for them, but here is one that is specific to your car, "1930 Chevy Replacing the Wood with Steel." You can search for that or here is the url: https://www.jalopyjournal.com/threads/1930-chevy-replacing-the-wood-with-steel.526069/
    Best of luck with your build.
    TFoch, tb33anda3rd and RMR&C like this.
  5. RMR&C
    RMR&C
    from NW Montana
    Great to see another "non Ford" being built! Lots of good info here...
    TFoch, tb33anda3rd and Doctorterry like this.
  6. TFoch
    TFoch
    I used a rear end out of a Chevy S10 2WD for my 33 Chevy. The width is 54" side to side where the wheels mount. They come in a variety of gear ratios to fit your needs. I used 3:42 gear ratio to go with my 350 and 700R4 trans. I'm happy with the combination but I have a 283 in the garage I eventually will rebuild and install in the car. Good luck with your build!
    Bowtie Coupe, RMR&C and tb33anda3rd like this.
  7. Król
    Król
    I'm building a 1936 Chevy pickup truck, to be a little different I'm using a 250 Chevy 6 with T-5 trans and a 3:73 S-10 Blazer rear end. I'm keeping stock leaf springs all around with dropped stock front axle. IMG_1887 (1).JPG IMG_1805.JPG IMG_1806.JPG
  8. Roadsterturner
    Roadsterturner
    Thank you for the help,Where did you get the drop axle? And what disc brake set up are you running on the front?
  9. RichFox
    RichFox
    Your car came with a straight six engine. You could install a 250 or 292 and T350 and have a fine driver. And a car that will draw more attention when the hood is open. Save some clearance issues also. You could even think bout the later Atlas engine that GM made for a while.
    TFoch likes this.
  10. 30dodge
    30dodge
    from Pahrump nv
    Chevy or GMC inline 6, split exhaust, twin carbs, just like back in "56.
  11. rtomss
    rtomss
    Keep the stock suspension....drop the front axle (Sids Axles) and 54' Brakes. There are different spindle options...several early 30's will work with just a swap of inner race and bearings. Use a tri five rear end and brakes. Just about any engine and th350 would work for a cruiser. Just need to add a crossmenber. Best place for parts is Filling Station, Chevs of the 40's, Jim Carter. I would suggest boxing the frame.
  12. DLRIDES
    DLRIDES
    from Newton NC
    As someone who has built a 32 Chevy,....................... WOOD !
    Get a plan and address this first ! If this is going to be a regular driver, replace with steel. If an occasional driver replace every piece of wood that is not perfect. Otherwise nothing will align or fit properly .................. for very long.
  13. Chappy444
    Chappy444
    Jet96, Król, Jiminy and 1 other person like this.
  14. Great car
    My Blue flame sorta
    Another 6 vote and 55-64 rears look better than s10s and both are cheap if your not looking for posi
    S10 will have g80 code in glove box for posi and ratio id codes 0517181141.jpg
  15. 6sally6
    6sally6
    Since your a Ford man....why not slap a nice 5.0 roller motor in it!!!!!!(That would go over like "a fart in church" ) with most of those "Chevy kids".
    See if you can talk your old Dad(who's prolly my age) to at least put a healthy cam in that 350(or whatever) engine.
    TO ME......nothing sounds much worse than a smooth idling, totally re-done, old cl***ic, like what ya'll are working on! Even if its brought back to totally original look......cam the **** out of it to get some "big-eyed-stares" from us old timers at the shows.
  16. tb33anda3rd
    tb33anda3rd
  17. AngleDrive
    AngleDrive
    from Florida
    From experience on the wood, p*** on Jim Rodman and go with KC. PM me if you want details.
