1952-59 Ford Rear End For Sale
Discussion in 'Off Topic Hot Rods & Customs' started by 50sboy, May 17, 2018.
  1. 50sboy
    50sboy
    Anyone need a good stock rear end? 56 Ranch Wagon with 312 auto...was running in the car...no big leaks or hitchs in the gears...backing plate to backing plate...or with OEM FoMoCo drums and relatively new brake job...located in SoCal...$250 or make an offer if you want it...
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Is the gear ratio tag on it ? This would be a good beefier upgrade for guys with a 1952-56 standard rear as this is the Dana 41 cousin to the Dana 44. From what I could look up ratio should be a 3:54 so better for cruising than the 3:90 or 4:10's.
  3. Goldchainer$$$
    Goldchainer$$$
    from L.A.
    Jeff would this be a good choice for a 1955 Ford Fairlane with a 302/C4
    JeffB2 likes this.
  4. 50sboy
    50sboy
    Sorry - no tag - just a '44' casting mark on the housing.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Anyone on the right coast want a '54 Ranch Wagon rear end for 50 bucks? HRP
  6. Paul2748
    Paul2748
    Probably a 3.31 if it's a automatic rear.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    ;) Yes it would,stronger than the standard 1949-56 car rear ends. Those had a rear gear slightly under 8" the Dana 44 rear has a 8.5 inch ring gear. It appears that this particular rear end is actually a better Dana 44 from the stamping and not the 41 used in early Ford Trucks. The rear end cover should look like the one shown below.
    Goldchainer$$$ likes this.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    H 1firewall.JPG ere is a chart to verify.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    Cover plate match the one above ? If so then it's a good rear.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
  11. Goldchainer$$$
    Goldchainer$$$
    from L.A.
  12. 56longroof
    56longroof
    It's a 19 spline Dana 44. Im pretty sure that was the only rear offered in wagons for 55-56.
  13. 50sboy
    50sboy
    yes...44. Thanks. Anyone need it? I'm listing on ebay...but I don't think it will ship priority mail!
  14. Goldchainer$$$
    Goldchainer$$$
    from L.A.
    Will you be available this weekend?
  15. 50sboy
    50sboy
    Sure - in between GiKids softball and baseball tourneys. Shoot me a text or call 562-881-4019
    JeffB2 likes this.
  16. Goldchainer$$$
    Goldchainer$$$
    from L.A.
    Cool, thanks. I’m thinking Sunday, I’ll let you know for sure by tomorrow.
    JeffB2 likes this.
  17. 50sboy
    50sboy
    SOLD - thanks!
    JeffB2 likes this.
  18. JeffB2
    JeffB2
    from Phoenix,AZ
    Glad to see a member scored it instead of it going to ebay.
  19. Goldchainer$$$
    Goldchainer$$$
    from L.A.
  20. JeffB2
    JeffB2
    from Phoenix,AZ
  21. Goldchainer$$$
    Goldchainer$$$
    from L.A.
  22. 50sboy
    50sboy
    Thank you! Glad it went to a member! Good luck with your project!
  23. Justin54FayCustomline
    from San Diego
    Do you still have it .
  24. JeffB2
    JeffB2
    from Phoenix,AZ
  25. Bleach
    Bleach
    "Rear End For Sale"
    Kinda sounds like a booty call. :rolleyes:
    54vicky and JeffB2 like this.
  26. scrap_metal
    scrap_metal
    Check craigslist. I believe there's accouple of maverick rear ends in your area that mostly work for 50s fords.
  27. okiedokie
    okiedokie
    from Ok
    Maverick rear ends are extremely hard to find around here.
