Hot Rods sbc with dipstick in oil pan
Discussion in 'The Hokey Ass Message Board' started by scott49mercury, May 5, 2017.
  1. scott49mercury
    scott49mercury
    I have a friend with a chevy 283 but it has a dipstick tube not in the block but going to the oil pan. I have never seen this before and wonder what it might have came out of and where to get a pan gasket for it.
    xnology likes this.
  2. landseaandair
    landseaandair
    from phoenix
    Is it a front sump? Could be Chevy II. Pan gasket shouldn't be anything special.
    jimmy six likes this.
  3. squirrel
    also used on (rear sump) Monzas and similar in the mid-late 70s.
    jimmy six, MO_JUNK and gimpyshotrods like this.
  4. 26Troadster
    26Troadster
    early 305's had them in the pan too. sorry didn't see squirrel's reply.
    jimmy six, gimpyshotrods and natas454 like this.
  5. bobss396
    bobss396
    130-012.JPG Mine is a slightly modified Chevy II dipstick.
    gimpyshotrods likes this.
  6. scott49mercury
    scott49mercury
    the motor is a rear sump so it cant be a chevy II but the Monza I could be but by all the numbers the motor is a 58 283 but I will look and se what comes up
  7. squirrel
    you can put the pan off any SBC up to 1979 on to a 283
    gimpyshotrods and olscrounger like this.
  8. blue 49
    blue 49
    from Iowa
    I bought a 305 that was said to have been in an '88 Chevy pick up with a dipstick in the pan, rear sump.
    Gary
  9. squirrel
    strange, 88 chevy pickup small block engines have the dipstick in the block, although it's on the p*** side, not the driver side. But big blocks, they're all in the pan.
    MO_JUNK likes this.
  10. c-10 simplex
    c-10 simplex
  11. squirrel
    I think it had to do with the exhaust manifold design.
  12. I think the 56 Corvette had the dip stick in the pan on the p*** side JB
  13. blue 49
    blue 49
    from Iowa
    It's been a good engine, but a lot of what I was told turned out to be untrue.
  14. xnology
    xnology
    from Idaho
    I am the friend in question...
    Pan in question:
    So figured a standard gasket would fit, but still wondering the iden***y of this little beast.
    Updated images
  15. squirrel
  16. Where the dipstick is going into the pan is too far forward of the sump? I don't think it would be viable? Possibly some kind of Photo shop?
  17. xnology
    xnology
    from Idaho
    The dipstick lines up with the hole in the baffle - pokes right through into the sump.
    $600?
    Anybody want a slightly used oil pan cheap? $400...
    Didn't realize my pan was made of gold.
  18. xnology
    xnology
    from Idaho
  19. k5ride
    k5ride
    Sorry to comment on an old thread..........but, did you ever figure out what engine this pan went to? I just picked up a 350, casting #3970010 and it has the exact same pan shape with the left side pan mounted dip stick. I'm having trouble figuring out what vehicle / year it came from. thanks,
  20. That is more like a 70s 305 pan. I have one from a 78 Buick Skylark. Dipstick slides in on the driver (left) side.
  21. RoyalRay
    RoyalRay
  22. RoyalRay
    RoyalRay
    Does the dipstick tube have a seal?
  23. lippy
    lippy
    from Ks
    K5ride, thats not the pan for that engine. Lippy
  24. Smooger409
    Smooger409
    It is from an early 283/327 powered big truck 2 1/2 ton viking C50 C60 etc 6 quart capacity, the dip stick attaches to the block using the 1/4-20 hole on the side of the block normally used for the spark plug heat shields
    427 sleeper likes this.
  25. Smooger409
    Smooger409
    Do you still have it ?
