Technical 1963 mercury monterey want to switch to electronic distributor
Discussion in 'The Hokey Ass Message Board' started by 63 breezeway, May 21, 2018.
  1. I have a 63 monterey with a 390 fe. I want to switch to electronic distributor.Any suggestions.I bought a MSD but because of the water tank is in front of the thermostat, the cap is to big.and I don't want to reroute the whole cooling system. Are their smaller distributors?
  2. squirrel
    why do you want to change it? Is it broken?
  3. F 150, 250, 350 with FE 360, 390 1974 - 76 with stock electronic ign dist will work.
    warhorseracing likes this.
  4. mikhett
    mikhett
    from jackson nj
    I put a pertronix in my 62 Galaxy .7 years and no problems.
  5. Couple that with a MSD 6A box and you'll have a all-but-bulletproof ignition.... You could use a Ford box, but they're harder to wire in.
  6. LM14
    LM14
    from Iowa
    Pertronix is a small cap. I get them with black with male terminals so I can use large diameter HEI style wires and not have to fight with getting them in the cap. I also use Pertronix coil and wires (black so they look stock and kind of disappear) so it's a complete system.
    MSD also makes a ready to run with a small cap that doesn't need a box.
    I'm going Pertronix on my FE and my 302 projects. Had food luck with them in the past.
    SPark
  7. I have used Pertronix successfully. Also have used a modified BIG cap GM HEI. Both worked well. Now have an original Buick back in it with an HEI pick up and reluctor inside. The GM module is on the firewall. This in/on the Straight Eight.
    Ben
  8. I actually have a Ford distributor wired to a GM module mounted on an aluminum heat sink at the rad support.
    firstinsteele likes this.
  9. FrozenMerc
    FrozenMerc
    I run a Pertronix setup in my '62 Merc, works great for a street car.
    As Center-of-the-Galaxie alluded to. It is hard to beat the DuraSpark II setup used in mid 70's pickups. Use an MSD box, or the correct Ford ignition control module ($25 at any parts store) for good street performance.
  10. jimmy six
    jimmy six
    Pertronics ll
    mikhett likes this.
  11. Jack E/NJ
    Jack E/NJ
    from NJ
  12. LM14
    LM14
    from Iowa
    ^^^ is this the Chinese knockoff of the MSD stuff? Don't think I could trust that.
    SPark
  13. leadsled
    leadsled
    i am a big fan of MSD, have it in the Lincoln and the Merc.
  14. I need a small cap. I tried a MSD to big. I think I might try the Top Street Performance Pro Series Ready to Run.It looks like a smaller cap
  15. MSD cap 5 1/2 TSP 4 1/8
  16. 62rebel
    62rebel
    Mid-70's DSII simple as dropping in the distributor and hooking up three wires. Mount a spare module next to the one in operation and you're set.
    Boneyard51 likes this.
  17. Boneyard51
    Boneyard51
    Yep, have done it several times, easy as pie. Works great, cheap, readily repairable. Looks stock. Bones
  18. Thanks for all your help. Went to Skip White out off Tennessee. Got a TSP small cap and coil for less than 125 bucks. When I call TSP they wanted 190 just for the distributor! I would recommend Skip White they were awesome
  19. Dropped in the distributor today. Easy install ready to run. works great.
