Customs Front Axle Identification
Discussion in 'The Hokey Ass Message Board' started by Rubrmat, May 17, 2018.
  1. Rubrmat
    Rubrmat
    Lakester3.JPG Lakester2.JPG Lakester1.JPG Can anyone identify this front axle for me? This is on a Lakester that is supposed to be a '27 Ford with a '37 V8-60. Since this project, naturally, is a hodgepodge of parts, I am having issues with finding the front hubs, backing plates, etc. We did have these parts but after sending them out they "went missing". Hoping to find another set but things are looking grim!
    Existing spindles measure:
    Backing plate bolt pattern- 3-1/4"Wx1-7/8"H
    Spindle OAL- 4-3/4"
    Spindle large bearing diameter- 1-3/16"
    Spindle small bearing diameter- 3/4"
    Spindle thread- 5/8"-18
    Spindle kingpin length- 5"
  2. alchemy
    alchemy
    Looks like Willys to me.
    X38 likes this.
  3. WTF really
    WTF really
    I'm new to this bit don't see anything ford there.
  4. Fordors
    Fordors
    Agreed^^^
    RonaldR likes this.
  5. kidcampbell71
    kidcampbell71
  6. Fordors
    Fordors
    See that tag riveted on the left frame rail just in front of the spring shackle? Looks like it has 77 stamped on it, I believe that is the serial number plate location for a Model 77 Willys , the 77's were produced from 1933-1936. What else is stamped on that tag?
  7. Atwater Mike
    Atwater Mike
    Willys 77, 'I' beam center bar, solid rounds on the ends.
    Body looks more like a '29, and that's an 'A'.
  8. Rubrmat
    Rubrmat
    Great everyone! This is looking promising. Now it will just be a matter of finding the appropriate hubs and backing plates. Thanks again!
  9. Rubrmat
    Rubrmat
    Well it looks like trying to find these hubs and backing plates will be more difficult than anticipated. Is there anyone out there who may have a lead on hubs and backing plates for a Willys Model 77 early (narrow) front axle? Although all I need are the hubs and backing plates, I understand they may need to come with a whole axle. It seems many folks had swapped their Willys axle for a narrowed Ford, so there must be some floating around there somewhere!
    HELP!
  10. Atwater Mike
    Atwater Mike
    Lots of those got pushed thru the 1/4 under Willys g***ers. Few had front brakes...
  11. 1934coupe
    1934coupe
    Definitely Willys. Willys had 2 different size KP diam. Not positive but early 11/16" or 3/4" and later (hyd. brake) 3/4" or 13/16". Its been a long time. On the expensive end there is Wilwood on the cheap end is looking through bearing books and trying to match up bearings with the hubs of other cars. If I find more info I'll p*** it on to you.
    Pat
  12. Rubrmat
    Rubrmat
    I have been considering the route of no front brakes as well. I just figured if I could get them, they'd be worth having, even if I don't use them!
    Thanks for the info.
  13. Rubrmat
    Rubrmat
    Thanks Pat, any information you find and can p*** along is greatly appreciated. I wish there were a Willys website with collections of specifications somewhere!
  14. 1934coupe
    1934coupe
    Rubrmat it's all homework, years of owning, building, trading and working in the auto parts, machinist, engineering. Having good friends and mentors.
    Pat
